Kubota Garden Tractor G18HD Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G18HD Garden Tractor
Number of Pages: 107 Pages
Itens Uso Frequente / Fr Equently Used Items
Bl Oco Motor / Crankcase
Ca Rter Oleo / Oil Pan
Ca Rreto / Gear Case
Ta Mpa Cabeça / Head Cover
Fi Ltro Oleo / Oil Filter
Va Reta Nivel E Guia / Dipstick And Guide
Bo Mba Oleo / Oil Pump
Ra Diador / Main Bearing Case
Ar Vore Cames E Veio / Camshaft And Idle Gear Shaft
Pi Ston E Cambota / Piston And Crankshaft
Vo Lante Motor / Flywheel
Ve Io / Fuel Camshaft And Governor Shaft
Po Nto Neutro / Idle Apparatus
Fi Ltro Gasoleo / Stop Solenoid
Bo Mba Injectora / Injection Pump
Re Gulador / Governor
Re Gulador Velocidade / Speed Control Plate
Va Lvula Solenoide / Nozzle Holder And Glow Plug
Ta Mpa Bomba Combustivel / Fuel Pump Cover
In Terruptor E Termómetro Do Óleo / Oil Switch And Plu G
Bo Mba Agua E Termostacto / Water Flange And Thermosta T
Ac Essorios / Water Pump
Ra Diador / Water Pipe
Vá Lvula E Veio Do Balanceiro / Valve And Rocker Arm
Co Lector Admissao / Inlet Manifold
Co Lector Escape / Exhaust Manifold
Fi Ltro Ar / Air Cleaner
Es Cpae / Muffler
Ki T De Junta Superior [Opção] / Upper Gasket Kit [Opt Ion]
Ki T De Junta Inferior [Opção / Lower Gasket Kit [Opti On]
Acelarador Mao / Accelerator Le Ver
Deposito Combustivel / Fuel Tan K
Tubo Gasoleo/ Filtro / Fuel Pip E/Fuel Filter
Ventilador / Fan
Radiador / Ra Diator
Alternador / Alternator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Componenetes Electricos / Elec Trical Parts
Farol Dianteiro / Head Light
Cabalagem Eletrica(Cabine)[Ec] [G] / Electrical Wiring
Veio Travao / Brake Gear-Shaft/Idler Shaf T
Hst / Hst
Hst [Peças Componentes] / Hst [Component Parts]
Rotula Universal / Universal Joint/Hst Fa N
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Carter / Rear Differential
Veio Diferencial Traseiro / Rear Different Ial Shaft
Carter Eixo / Rear Axle Case
Eixo Traseiro / Rear Axle
Rear Wheel(23*10.50-12) / Re Ar Wheel(23*10.50-12)
Tr Avao Pto / Pto Brake [New Type]
Tr Avão / Brake
Pe Dal Travao / Brake Pedal
Ti Rante Travao / Brake Rod
Tirante Veio Acelarador / Speed Control Arm
Alavamca De Controle / Hydrauli C Control Lever
Cabo Embraiagem / Pto Clutch Co Ntrol Lever/Wire
Cabo Tdf / Pto Wire Bracket [Ne W Type]
Eixo Dianteiro / Front Axle
Estrutra Principal / Suporte Direccao / Main Frame/Steering Support
Front Wheel(16*6.5-8) / Front Wheel(16*6.5-8)
Braco Hidraulico / Control Val Ve
Valvula Control[Peças Componen Tes] / Control Valve [Component Parts] [New Type]
Linha Aspiração / Hydraulic Oi L Line(Suction)
Tubo Oleo Hidraulico / Hydraul Ic Oil Line(Breather)
Tubo Oleo Hidraulico / Hydraul Ic Oil Line(Drain)
Cilindro Hidraulico Elevação / Hydraulic Lift Cylinder
Tirante / Lift Link
Capot / Hood(Bonnet)
Painel / Panel
Guarda Lamas / Fender
Acessorios / Seat
Etiqueta Frente / Label
