Kubota Garden Tractor G18HD Spare Parts Catalog EN FR
Language: French, English
Model: Kubota G18HD Garden Tractor
Number of Pages: 128 Pages
Frequently Used Items / Frequently Used Items
B Loc Moteur / Crankcase
C Arter D'huile / Oil Pan
C Ulasse / Cylinder Head
K It D'accouplements Rapides [Option] / Gear Case
C Ouvre-Culasse / Head Cover
F Iltre D'huile / Oil Filter
J Auge D'huile Et Guide / Dipstick And Guide
P Ompe D'huile / Oil Pump
P Aliers De Principal / Main Bearing Case
A Rbre A Cames Et Arbre De Pignon Fou / Camshaft And Idle Gear Shaft
P Istons Et Vilebrequin / Piston And Crankshaft
V Olant Du Moteur / Flywheel
A Rbre A Cames De Carburant Et Arbre Regulateur / Fue L Camshaft And Governor Shaft
D Ispositif De Ralentisseur / Idle Apparatus
S Olenoide D'arret / Stop Solenoid
P Ompe D'injection / Injection Pump
R Egulateur De Vitesses / Governor
P Laque De Limiteur De Vitesse / Speed Control Plate
P Orte-Injecteur Et Bougie De Prechauffage / Nozzle H Older And Glow Plug
C Ouvercle De Pumpe D'alimentation / Fuel Pump Cover
C Ontact A Huile Et Obturateur / Oil Switch And Plug
K It D'accouplements Rapides [Option] / Water Flange And Thermostat
P Ompe A Eau / Water Pump
T Uyau D'eau / Water Pipe
S Oupapes Culbuteurs / Valve And Rocker Arm
C Ollecteur D'admission / Inlet Manifold
C Ollecteur D'echappement / Exhaust Manifold
F Ilter A Air / Air Cleaner
S Ilencieux / Muffler
J Eu De Joint Superieur [Option] / Upper Gasket Kit [ Option]
J Eu De Joint Inferieur [Option] / Lower Gasket Kit [ Option]
Reservoir Carb. / Fuel Tank
Tuyau A Carburant/Filtre A Carburant / Fuel Pipe/Fuel Filter
Ventilateur / Fan
Radiateur / Radiator
Alternateur Complet / Altern Ator
Alternateur [Parties Composa Ntes] / Alternator [Component Parts]
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Composant Es] / Starter [Component Parts]
Batterie / Battery
Pieces Electrique / Electric Al Parts
Phare / Head Light
Faisceau Electrique / Electr Ical Wiring
Carter De Transmission / Transmission Ca Se
Arbre De Pignon Frein/Arbre De Fou / Bra Ke Gear-Shaft/Idler Shaft
Hst / Hst
Hst [Parties Composantes] / Hst [Compone Nt Parts]
Joint De Caldan/Hst Ventilateur / Univer Sal Joint/Hst Fan
Arbre Prise De Forse / Pto Shaft
Poulie De Tension / Pto Tension Pulley
Arbre De Differentiel Arriere / Rear Differ Ential Shaft
Carter D'essieu Arriere / Rear Axle Case
Axe Arriere / Rear Axle
Roue Arriere(23*10,50-12) / Rear Wheel(23* 10.50-12)
Fre In De Prise De Force [Type Nouveau] / Pto Brake [Ne W Type]
Fre In / Brake
Fre In / Brake
Ped Ale De Frien / Brake Pedal
Tig E De Frein / Brake Rod
Pedale De Commande De Vitesse / Speed Change Pedal
Bras De Vitesse-Commande / Speed Control Arm
Levier De Hydraulique-Commande / Hydraulic Control Lever
Levier D'embrayage De Pdf/Cable / Pto Clutch Control Lever/Wire
Support De Pdf Cable [Type Nouve Au] / Pto Wire Bracket [New Type]
Pont Avant / Front Axle
Chassis/Support De Direction / Main Frame/ Steering Support
Roue Avant(16*6,5-8) / Front Wheel(16*6.5-8 )
Servo De Direction/Colonne De Direction / Power Steering/Steering Handle
Distributeur Hydraulique / Co Ntrol Valve
Distributeur Hydraulique (Pie Ces Composantes) (Nouveau) / Control Valve [Compone Nt Parts] [New Type]
Circuit D'huile Hydraulique(A Spiration) / Hydraulic Oil Line(Suction)
Circuit D'huile Hydraulique(R Eniflard) / Hydraulic Oil Line(Breather)
Circuit D'huile Hydraulique(D Rainage) / Hydraulic Oil Line(Drain)
Cylindre De Relevage Hydrauli Que / Hydraulic Lift Cylinder
Chainon / Lift Link
Capot / Hood(Bonnet)
Tableau De Bord / Panel
Aile / Fender
Siege / Seat
Siege / Seat
Etiquette / Label
Accessories Et Piece De Service / Accessories And Service Parts
Ventilateur / Fan
Lanceur / Starter
Lanceur / Starter
Batterie / Battery
Phare / Head Light
Hst / Hst
Fre In / Brake
Fre In / Brake
Chainon / Lift Link
Aile / Fender
Siege / Seat
Siege / Seat
Etiquette / Label
