Kubota Garden Tractor G18 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota G18 Garden Tractor
Number of Pages: 117 Pages
Itens Uso Frequente / Freq Uently Used Items
Bloc O Motor / Crankcase
Cart Er Oleo / Oil Pan
Cabe Ca Motor / Cylinder Head
Carr Eto / Gear Case
Tamp A Cabeça / Head Cover
Filt Ro Oleo / Oil Filter
Vare Ta Nivel E Guia / Dipstick And Guide
Bomb A Oleo / Oil Pump
Radi Ador / Main Bearing Case
Arvo Re Cames E Veio / Camshaft And Idle Gear Shaft
Pist On E Cambota / Piston And Crankshaft
Vola Nte Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Pont O Neutro / Idle Apparatus
Filt Ro Gasoleo / Stop Solenoid
Bomb A Injectora / Injection Pump
Regu Lador / Governor
Regu Lador Velocidade / Speed Control Plate
Valv Ula Solenoide / Nozzle Holder And Glow Plug
Tamp A Bomba Combustivel / Fuel Pump Cover
Inte Rruptor E Termómetro Do Óleo / Oil Switch And Plug
Bomb A Agua E Termostacto / Water Flange And Thermostat
Aces Sorios / Water Pump
Radi Ador / Water Pipe
Válv Ula E Veio Do Balanceiro / Valve And Rocker Arm
Cole Ctor Admissao / Inlet Manifold
Cole Ctor Escape / Exhaust Manifold
Filt Ro Ar / Air Cleaner
Escp Ae / Muffler
Kit De Junta Superior [Opção] / Upper Gasket Kit [Optio N]
Kit De Junta Inferior [Opção / Lower Gasket Kit [Option ]
Acelarador Mao / Accelerator Leve R
Tubo Gasoleo/ Filtro / Fuel Pipe/ Fuel Filter
Ventilador / Fa N
Radiador / Radi Ator
Alternador / Alternator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / S Tarter [Component Parts]
Componenetes Electricos / Electr Ical Parts
Farol Dianteiro / Head Light
Cabalagem Eletrica(Cabine)[Ec] [ G] / Electrical Wiring
Veio Travao / Brake Gear-Shaft/Idler Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [Component Pa Rts]
Rotula Universal / Universal Joint/Hst Fan
Veio Tdf / Pto Shaft
Poli Tensora Tdf / Pto Tension Pulley
Diferencial Carter / Rear Differential
Veio Diferencial Traseiro / Rear Differentia L Shaft
Carter Eixo / Rear Axle Case
Eixo Traseiro / Rear Axle
Rear Wheel(23*10.50-12) / Rear Wheel(23*10.50-12)
Trav Ao Pto / Pto Brake [Old Type]
Trav Ao Pto / Pto Brake [New Type]
Trav Ão / Brake
Peda L Travao / Brake Pedal
Tira Nte Travao / Brake Rod
Tirante Veio Acelarador / Speed C Ontrol Arm
Alavamca De Controle / Hydraulic Control Lever
Cabo Embraiagem / Pto Clutch Cont Rol Lever/Wire
Eixo Dianteiro / Front Axle
Front Wheel(16*6.5-8) / Front W Heel(16*6.5-8)
Direcção Assistida / Direção Punho / Power Steerin G/Steering Handle
Braco Hidraulico / Control Valve
Valvula Control[Peças Componente S] / Control Valve [Component Parts] [Old Type]
Valvula Control[Peças Componente S] / Control Valve [Component Parts] [New Type]
Linha Aspiração / Hydraulic Oil Line(Suction)
Tubo Oleo Hidraulico / Hydraulic Oil Line(Breather)
Tubo Oleo Hidraulico / Hydraulic Oil Line(Drain)
Cilindro Hidraulico Elevação / H Ydraulic Lift Cylinder
Capot / Hood(Bonnet)
Painel / Panel
Guarda Lamas / Fender
Acessorios / Seat
Etiqueta Frente / Label
Acessorios / Accessories And Service Parts
