Kubota Front Mower FZ2400 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota FZ2400 Front Mover
Number of Pages: 115 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Pistons / Vilebrequin / Piston / Crankshaft
Volant Moteur / Flywheel
Culasse / Cylinder Head
Soupapes / Culbuteurs / Valve / Rocker Arm
Porte-Injecteur / Nozzle Holder
[Component Parts]
[Component Parts]
Couvre-Culasse / Head Cover
Filtre A Air / Air Cleaner
Silencieux / Muffler
Arbre A Cames / Camshaft
Pompe A Eau / Water Pump
Bride / Water Flange
Arbre A Cames De Carburant / Fuel Camshaft
[Component Parts]
Solenoide / Solenoid
Levier D'arret Du Moteur / Engine Stop Lever
Regulateur De Regime / Governor
Tuyau A Carburant / Fuel Pipe
[Component Parts]
Ventilateur / Fan
Radiateur / Radiator
Alternateur / Dynamo
[Component Parts]
Demarreur / Starter
[Component Parts]
Batterie / Battery
Faisceau Electrique / Phare / Wire Harness / Head Light
Metre / Interrupteur / Mete R / Switch
Embrayage 1 / Clutch 1
Embrayage 2 / Clutch 2
Tige D'embrayage / Clutch Rod
Carter De Transmission / Transmission C Ase
Hst / Hst
[Co Mponent Parts]
[Co Mponent Parts]
[Co Mponent Parts]
Premier Arbre / Deuxieme Arbre / First Shaft / Second Shaft
Differentiel / Auto Assist Differential
Troisieme Arbre G. / Third Shaft Lh
Troisieme Arbre D. / Third Shaft Rh
Bielle Neutre / N Eutral Arm
Levier De Changem Ent / Aux.Speed Change Lever
Embrayage De Pdf / Pto Clutch
Bielle De Pdf Ten Sion / Pto Tension Arm
Poulie De Moteur / Engine Pulley
Levier De Changem Ent De Vitesse Pdf / Pto Lever
Differentiel Avant / Fr Ont Differential
Pont Avant / Front Axle
Roue Avant (23x10.5-12) / Front Wheel (23x10.5-12)
Pont Arriere / Rear Axl E
[Component Parts]
Roue Arriere (20x8.00-1 0) / Rear Wheel (20x8.00-10)
Carter D'essieu Arriere / Rear Axle Case (Inside Outside)
Carter D'essieu Arriere / Rear Axle Case (Input)
Arbre Menant / Rear Axl E Drive Shaft
Fr Ein / Brake
Ti Ge De Frein / Brake Rod
Pe Dale / Pedal
Levier Incline / Steering Lock Lever
Cylindre Servo Direction / Power Steering Cyli Nder
[Component Parts]
Poteau De Manette / Handle Post
Direction Assistee / Power Steering
[Component Parts]
Refroidisseur / Oil Cooler
Pompe Hydraulique / Hydrauli C Pump
[Component Parts]
[Component Parts]
Tuyau D'aspirat / Suction Pi Pe
Tuyau De Hydraulique (Hst) / Hydraulic Pipe (Hst)
Distributeur / Control Valve
[Component Parts]
Soupape De Controle (Option) / Control Valve Kit (Option)
Cylindre De Levage / Lift Cy Linder
[Component Parts]
Chai Non / Mower Link
Capot / Bonnet (Hood)
Aile / Fender
Couvercle / Cover
Couvercle / Cover
Support De Moteur / Eng Ine Bracket
Fr Ein / Brake
Chassis / Marche / Fron T Frame / Step
Siege / Seat
Siege / Seat
[Component Parts]
Cadre Anti-Renversement / Rops
Etiquette / Label
Etiquette / Label
Accessoires Et Pieces Service / Accessori Es And Aervice Parts
[Component Parts]
[Component Parts]
[Component Parts]
[Component Parts]
Ventilateur / Fan
[Component Parts]
Demarreur / Starter
[Component Parts]
Batterie / Battery
Hst / Hst
[Co Mponent Parts]
[Co Mponent Parts]
[Co Mponent Parts]
[Component Parts]
Fr Ein / Brake
Pe Dale / Pedal
[Component Parts]
[Component Parts]
[Component Parts]
[Component Parts]
[Component Parts]
[Component Parts]
Aile / Fender
Couvercle / Cover
Couvercle / Cover
Fr Ein / Brake
Siege / Seat
Siege / Seat
[Component Parts]
Etiquette / Label
Etiquette / Label
