Kubota Front Mower F3890-EU Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota F3890-EU Front Mover
Number of Pages: 143 Pages
Frequently Used Ite Ms / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control Pla Te
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Ho Lder [Component Parts]
Bride A Eau Et Thermostat / Water Flange And Ther Mostat
Pompe A Eau / Water Pump
Soupapes Et Culbuteurs / Valve And Rocker Arm
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket Ki T [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Ki T [Option]
Levier D'accelerateur / Hand Accelerator Lever
Reservoir Carb. / Fuel Tank
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiator
Plateall A Poussiere / Dustproof Plate
Reservoir Du Radiate Ur / Reserve Tank
Contact A Huile Thermomet Re / Oil Switch
Sonde De La Ratation / Re Volution Sensor
Alternateur Complet / Alt Ernator
Alternateur [Parties Comp Osantes] / Alternator [Component Parts]
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Commutateur / Switch
Faisceau Electrique / Ele Ctrical Wiring
Jeu De Lampe [Option] / L Ight Kit [Option]
Embrayage / Clutch
Carter De Differentiel / Differential Gear Case
Hst (Arbre D'entree) [Parties Composa Ntes] / Hst [Component Parts]
Joint De Cardan/Ventilateur / Univers Al Joint/Fan
Arbre De Prise De Force / Pto Shaft
Differentiel Avant / Front Differenti Al
Arbre D'entrainement Arriere / Rear W Heel Propeller Shaft
Embrayage D'entrainement [Parties Com Posantes] / One-Way Clutch [Component Parts]
Pont Avant / Front Axle
Roue Avant (24*12. 00-12) / Front Wheel (24*12.00-12)
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Differentiel / Differenti Al Lock Pedal
Levier De Commande D'avance / Cruise Control Lever
Levier De Changement De Gamme / Range Shift Lever
Levier De Chengement De Vites Se Pdf / Pto Gear Shift Lever
Levier Hydraulique / Hydrauli C Lift Lever
Pedale De Commande De Vitesse / Speed Change Pedal
Jeu De Controle-Croisire [Opt Ion] / Cruise Control Kit [Option]
Levier De Bloc Embrayage / Cl Utch Lock Lever
Differentiel Arr Iere / Rear Differential Case
Differentiel Arr Iere / Rear Wheel Differential
Demi Arbre De Po Nt Avant / Differential Gear Shaft
Carter Pont Arri Ere / Rear Axle Case
Arbre D'entrainm Ent Arriere / Rear Wheel Drive Shaft
Roue Arriere (18 *9.5-8) / Rear Wheel (18*9.5-8)
Pompe Hydraulique (Direction Assistee) / Hyd Raulic Pump (Ps)
Cylindre De Direction [Parties Composantes] / Steering Cylinder[Component Parts]
Support Avant Droit / Hydr Aulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump (Component Parts)
Circuit C'huile Hydrauliqu E / Hydraulic Oil Line (Inlet)
Circuit D'huile Hydrauliqu E (Refroidisseur) / Hydraulic Oil Line (Oil Cooler)
Cylindre Hydraulique / Hyd Raulic Cylinder
Distributeur Hydraulique / Control Valve
Distributeur [Parties Comp Osantes] / Control Valve [Component Parts]
Jeu De Distributeur (2soup Ape) [Option] / Control Valve Kit (2valve) [Option]
Relevage De Tondeuse / Mower Link
Chassis Avant / Front Frame
Contrepoids / Weight
Capot Superieur / Bonnet (Hood) Cover
Capot Lateral / Side Cover
Colonne De Direction / Steering Post
Aile / Fender
Aile / Fender
Siege / Seat
Siege / Seat
Siege / Seat
Cadre Anti-Renversment / Rops
Cadre Anti-Renversment [Option] / Rops [Optio N]
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
