Kubota Front Mower F3890-EU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Front Mower
Model: Kubota F3890-EU Front Mower
Number of Pages: 243 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Superior Junta Kit [Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit [Opcion] / Lower Gasket Kit [Option]
Acelerador Palanca / Hand Accelerator Lever
Ventilador / Fan
Agua Tubo / Water Pipe
A Prueba De Polvo Placa / Dustproof Plate
Interruptor Del Aceite Y Sensor Thermo / Oil Switch
Sensor De Rotacion / Revolution Sensor
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Cableado Eléctrico / Electrical Wiring
Kit Del Luz [Opcion] / Light Kit [Option]
Embrague / Clutch
Hst (Bloque De Cilindro) [Componente Piezas] / Hst [Component Parts]
Universal Junta/Ventilador / Universal Joint/Fan
Pto Eje / Pto Shaft
Trasero Rueda Helice Eje / Rear Wheel Propeller Shaft
Uno-Via Embrague[Componente Piezas] / One-Way Clutch [Component Parts]
Adelante Eje / Front Axle
Rueda Delantera (24*12.00-12) / Front Wheel (24*12.00-12)
Freno / Brake
Freno Pedal / Brake Pedal
Gama Engranaje Cambio Palanca / Range Shift Lever
Hidraulico Ascenso Palanca / Hydraulic Lift Lever
Velocidad De Crucero Control Kit[Opcion] / Cruise Control Kit [Option]
Embrague Cerradura Palanca / Clutch Lock Lever
Trasero Diferencial / Rear Differential Case
Diferencial Trasero / Rear Wheel Differential
Diferencial Eje Del Engranaje / Differential Gear Shaft
Trasero Rueda Accionar Eje / Rear Wheel Drive Shaft
Rueda Trasera (18*9.5-8) / Rear Wheel (18*9.5-8)
Atar Varilla / Tie Rod
Hidraulico Bomba(Potencia Direccion) / Hydraulic Pump (Ps)
Direccion Cilindro [Componente Piezas] / Steering Cylinder[Component Parts]
Hidraulico Bomba [Componente Piezas] / Hydraulic Pump (Component Parts)
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Control Valvula Kit(2 Valvula)[Opcion] / Control Valve Kit (2valve) [Option]
Cortacespedes Varillaje / Mower Link
Adelante Bastidor / Front Frame
Peso / Weight
Capo / Bonnet (Hood) Cover
Lado Cubierta / Side Cover
Direccion Poste / Steering Post
Guardabarros / Fender
Hoja / Seat
Hoja / Seat
Arco De Seguridad / Rops
Arco De Seguridad [Opcion] / Rops [Option]
Etiquetas / Labels
Accesorios / Accessories
