Kubota Front Mower F3060 Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Front Mower
Model: Kubota F3060 Front Mower
Number of Pages: 188 Pages
Itens Uso Frequente / Fr Equently Used Items
Bl Oco Motor / Crank Case
Ca Rter Oleo / Oil Pan
Ca Beca Motor / Cylinder Head
Ca Rreto / Gear Case
Ta Mpa Cabeça / Head Cover
Fi Ltro Oleo / Oil Filter
Ar Vore Cames E Veio / Camshaft And Idle Gear Shaft
Pi Ston E Cambota / Piston And Crankshaft
Vo Lante Motor / Flywheel
Ve Io / Fuel Camshaft And Governor Shaft
Po Nto Neutro / Idle Apparatus
Bo Mba Injectora / Injection Pump
Re Gulador / Governor
Re Gulador Velocidade / Speed Control Plate
Va Lvula Solenoide / Nozzle Holder And Glow Plug
Su Porte Bico [Peças Componentes] / Nozzle Holder [Com Ponent Parts]
Bo Mba Agua E Termostacto / Water Flange And Thermosta T
Ac Essorios / Water Pump
Vá Lvula E Veio Do Balanceiro / Valve And Rocker Arm
Co Lector Admissao / Inlet Manifold
Co Lector Escape / Exhaust Manifold
Fi Ltro Ar / Air Cleaner
Es Cpae / Muffler
Bo Mba Hidraulico / Hydraulic Pump
Bo Mba Hidraulico[Peças Componentes] / Hydraulic Pump [Component Parts]
Ac Elarador Mao / Accelerator Lever
Deposito Combustivel / Fuel Tan K
Filtro Gasoleo / Fuel Filter
Ventilador / Fan
Radiador / Ra Diator
Placa À Prova De Poeiras / Dustproof Plate
Sensor Térmico E Interruptor D O Óleo / Oil Switch And Thermo Sensor
Filtro Gasoleo / Stop Solenoid
Alternador / Alternator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Comutador / Switch
Cabalagem Eletrica(Cabine)[Ec] [G] / Electrical Wiring
Kit De Tacómetro [Opção] / Tac Hometer Kit [Option]
Kit De Luzes [Opção] / Light K It [Uk]
Compensador / Clutch
Diferencial / Differental Gear Case
Hst [Peças Componentes] / Hst [Component Parts]
Ventoinha/Junta Universal / Universal Joi Nt/Fan
Veio Tdf / Pto Shaft
Diferencial Dianteiro / Front Differentia L
Veio Eixo Traseiro / Rear Wheel Propeller Shaft
Embreagem Uni Direcional[Peças Componentes] / One-Way Clutch [Com Ponent Parts]
Carter Eixo / Front Axle Case
Eixo Dianteir O / Front Axle
Bloqueio Dife Rencial / Differential Lock Pedal
Opção Assiste Ncia Travagem / Turn Assist Brake Pedals [Option]
Roda Frente / Front Wheel (24*8.5-12)
Roda Frente / Front Wheel (23*10.5-12) [Option]
Tr Avão / Brake
Pe Dal Travao / Brake Pedal
Control Velocidade / Cruise Con Trol Lever
Control Velocidade / Cruise Con Trol Lever [Option]
Alavanca Velocidades / Range Ge Ar Shift Lever
Alavanca Tdf / Pto Gear Shift L Ever
Alavanca De Elevação Hidráulica / Hydraulic Lift Lever
Pedal Acelarador / Speed Contro L Pedal
Kit De Controlo Da Velocidade D E Cruzeiro [Opção] / Cruise Control [Option]
Alavanca De Bloqueio Da Embraia Gem / Clutch Lock Lever
Diferencial Carte R / Rear Differential Case
Grupo Conico / Be Vel Gear Shaft
Carter Grupo Coni Co / Bevel Gear Case
Carter Eixo / Rea R Axle Case
Roda Traseira / R Ear Wheel (18*7.0-8)
Roda Traseira / R Ear Wheel (18*7.0-8) [Option]
Direcção Assistida / Tie Rod
Bomba Hidráulica(Ps) / Hydraulic Pump (Ps)
Bomba Hidraulico[Peças Componentes] / Hydraulic Pump (Ps) [Component Parts]
Cilindro Direcção[Peças Componentes] / Steering Cylinder [Component Parts]
Linha De Óleo Hidráulico (Entr Ada) / Hydraulic Oil Line (Inlet)
Circuito Oleo Radiador / Hydra Ulic Oil Line (Oil Cooler)
Cilindro Hidraulico / Hydrauli C Cylinder
Braco Hidraulico / Control Val Ve
Valvula Control / Control Valv E [Component Parts]
Kit De Válvula De Controlo (1 Válvula) [Opção] / Control Valve Kit (1valve) [Opti On]
Kit De Válvula De Controlo (2 Válvulas) [Opção] / Control Valve Kit (2valve) [Opt Ion]
Ligação Do Co Rtador De Relva / Mower Link
Tampa Da Junt A / Joint Cover
Peso / Weight
Estrutura / Main Frame
Capot Superior / H00d (Bonnet)
Guarda Lamas / Fender
Banco / Seat Except [G]
Arco / Rops [Option]
Etiqueta Frente / Label
Acessorios / Accessories
Es Cpae / Muffler
Ventilador / Fan
Comutador / Switch
Tr Avão / Brake
Peso / Weight
