Kubota Front Mower F3060 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Front Mower
Model: Kubota F3060 Front Mower
Number of Pages: 285 Pages
Artículos De Uso Frecuente / Frequently Used Items
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Volante / Flywheel
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Ventilador / Fan
A Prueba De Polvo Placa / Dustproof Plate
Alternador / Alternator
Motor De Arranque / Starter
Interruptor Interno Del Cabina / Switch
Tacometro Kit[Opcion] / Tachometer Kit [Option]
Kit Del Luz [Uk] / Light Kit [Uk]
Embrague / Clutch
Caja De Diferencial / Differental Gear Case
Hst (Bloque De Cilindro) [Componente Piezas] / Hst [Component Parts]
Universal Junta/Ventilador / Universal Joint/Fan
Pto Eje / Pto Shaft
Trasero Rueda Helice Eje / Rear Wheel Propeller Shaft
Uno-Via Embrague[Componente Piezas] / One-Way Clutch [Component Parts]
Adelante Eje / Front Axle
Pedales De Freno [Opcion] / Turn Assist Brake Pedals [Option]
Adelante Rueda / Front Wheel (24*8.5-12)
Adelante Rueda / Front Wheel (23*10.5-12) [Option]
Freno / Brake
Freno Pedal / Brake Pedal
Control Valvula / Cruise Control Lever
Control Valvula [Opcion] / Cruise Control Lever [Option]
Hidraulico Ascenso Palanca / Hydraulic Lift Lever
Velocidad Cambio Pedal / Speed Control Pedal
Velocidad De Crucero Control Kit [Opcion] / Cruise Control [Option]
Embrague Cerradura Palanca / Clutch Lock Lever
Trasero Diferencial / Rear Differential Case
Eje De Engranaje Diferencial / Bevel Gear Shaft
Trasero Rueda Accionar Eje / Rear Drive Shaft
Trasero Rueda / Rear Wheel (18*7.0-8)
Trasero Rueda / Rear Wheel (18*7.0-8) [Option]
Atar Varilla / Tie Rod
Mango De Direccion / Steering Wheel
Hidraulico Bomba(Potencia Direccion) / Hydraulic Pump (Ps)
Hidraulico Bomba(Potencia Direccion)[Componente Piezas] / Hydraulic Pump (Ps) [Component Parts]
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Control Valvula Kit(1 Valvula)[Opcion] / Control Valve Kit (1valve) [Option]
Control Valvula Kit(2 Valvula)[Opcion] / Control Valve Kit (2valve) [Option]
Cortacespedes Varillaje / Mower Link
Junta Cubierta / Joint Cover
Peso 1 / Weight
Capo Superior[Tipo Arco] / H00d (Bonnet)
Direccion Poste / Steering Post
Guardabarros / Fender
Asiento Excepto [G] / Seat Except [G]
Arco De Seguridad [G] [Uk] / Rops [Option]
Etiquetas / Label
Accesorios Y Servicio Piezas / Accessories
Volante / Flywheel
Ventilador / Fan
Embrague / Clutch
Pto Eje / Pto Shaft
Freno / Brake
Peso 1 / Weight
Etiquetas / Label
