Kubota Front Mower F2890E-EU Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota F2890E-EU Front Mover
Number of Pages: 140 Pages
Frequently Used It Ems / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control Pl Ate
Porte-Injecteur Et Bougie De Prechauffage / Nozz Le Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle H Older [Component Parts]
Bride A Eau Et Thermostat / Water Flange And The Rmostat
Pompe A Eau / Water Pump
Soupapes Et Culbuteurs / Valve / Rocker Arm
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur [Option] / Upper Gasket K It [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket K It [Option]
Levier D'accelerateur / Hand Accelerator Lever
Reservoir Carb. / Fuel Tank
Ventilateur / Fan
Radiateur / Radiato R
Plateall A Poussier E / Dustproof Plate
Reservoir Du Radiat Eur / Reserve Tank
Contact A Huile Thermome Tre / Oil Switch
Sonde De La Ratation / R Evolution Sensor
Alternateur Complet / Al Ternator
Alternateur [Parties Com Posantes] / Alternator [Component Parts]
Lanceur / Starter
Batterie / Battery
Batterie / Battery
Faisceau Electrique / El Ectrical Wiring
Jeu De Lampe [Option] / Light Kit [Option]
Embrayage / Clutch
Carter De Transmission / Transmissio N Case
Carter De Differentiel / Differentia L Gear Case
Hst (Arbre D'entree) [Parties Compos Antes] / Hst [Component Parts]
Joint De Cardan/Ventilateur / Univer Sal Joint/Fan
Arbre De Prise De Force / Pto Shaft
Differentiel Avant / Front Different Ial
Arbre D'entrainement Arriere / Rear Wheel Propeller Shaft
Pont Avant / Fron T Axle
Roue Avant (23*10 .5-12) / Front Wheel (23*10.5-12)
Frein / Brake
Pedale De Frien / Brake Pedal
Pedale De Verrouillage Du Differentiel / Different Ial Lock Pedal
Levier De Commande D'avance / Cruise Control Lever
Levier De Changement De Gamm E / Range Shift Lever
Levier Hydraulique / Hydraul Ic Lift Lever
Pedale De Commande De Vitess E / Speed Change Pedal
Jeu De Controle-Croisire [Op Tion] / Cruise Control Kit [Option]
Axe Arriere / R Ear Axle
Roue Arriere (1 6*6.5-8) / Rear Wheel (16*6.5-8)
Pompe Hydraulique (Direction Assistee) / Hy Draulic Pump (Ps)
Cylindre De Direction [Parties Composantes] / Steering Cylinder[Component Parts]
Pompe Hydraulique [Partie S Composantes] / Hydraulic Pump (Component Parts)
Circuit C'huile Hydrauliq Ue / Hydraulic Oil Line (Inlet)
Circuit D'huile Hydrauliq Ue (Refroidisseur) / Hydraulic Oil Line (Oil Cooler )
Cylindre Hydraulique / Hy Draulic Cylinder
Distributeur Hydraulique / Control Valve
Distributeur [Parties Com Posantes] / Control Valve [Component Parts]
Jeu De Distributeur (2sou Pape) [Option] / Control Valve Kit (2valve) [Option ]
Relevage De Tondeuse / Mower Link
Chassis Avant / Front Frame
Contrepoids / Weight
Capot Superieur / Bonnet (Hood) Cover
Capot Lateral / Side Cover
Colonne De Direction / Steering Post
Aile / Fender
Aile / Fender
Aile / Fender
Siege / Seat
Siege / Seat
Cadre Anti-Renversment / Rops
Cadre Anti-Renversment [Option] / Rops [Opti On]
Accessoires / Accessories
