Kubota Front Mower F2880-EC Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota F2880-EC Front Mover
Number of Pages: 175 Pages
Articles Fréquemmen T Utilisés / Frequently Used Items
Bloc Moteur / Crank Case
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control Pla Te
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzle Ho Lder [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Silencieux / Muffler
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraul Ic Pump [Component Parts]
Jeu De Joints Superieur [Option] / Upper Gasket K It [Option]
Jeu De Joints Inferieur [Option] / Lower Gasket K It [Option]
Reservoir Carb. / Fuel Tank
Ventilateur / Fan
Radiateur / Radiator
Plateall A Poussiere / Dustproof Plate
Jeu De Poussiere [Op Tion] / Dustproof Kit [Option]
Contact A Huile Et Thermo Metre / Oil Switch And Thermo Sensor
Alternateur Complet / Alt Ernator
Alternateur [Parties Comp Osantes] / Alternator [Component Parts]
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Compos Antes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Interrupteur / Switch
Faisceau Electrique / Ele Ctrical Wiring
Jeu De Compte-Tours [Opti On] / Tachometer Kit [Option]
Jeu De Pieces Electrique [Option] / Electrical Parts Kit [Option]
Jeu De Lampe [Option] / L Ight Kit [Option]
Embrayage / Clutch
Carter De Differentiel / Differental Gear Case
Hst [Parties Composantes] / Hst [Comp Onent Parts]
Joint De Cardan/Ventilateur / Univers Al Joint/Fan
Arbre De Prise De Force / Pto Shaft
Differentiel Avant / Front Differenti Al
Arbre D'entrainement Arriere / Rear W Heel Propeller Shaft
Embrayage D'entrainement [Parties Com Posantes] / One-Way Clutch [Component Parts]
Pont Avant / Front Axle
Roue Avant(24*12.0 -12) / Front Wheel(24*12.0-12)
Frein / Brake
Frein / Brake
Pedale De Frien / Brake Pedal
Jeu De Freinage [Option] / Turn Assist Brake Kit [O Ption]
Pedale De Verrouillage Du Differentiel / Differenti Al Lock Pedal
Levier De Control-Croisiere / Cruise Control Lever
Levier De Changement De Gamme / Range Gear Shift Lever
Levier De Chengement De Vites Se Pdf / Pto Gear Shift Lever
Levier Hydraulique / Hydrauli C Lift Lever
Pedale De Commande De Vittess E / Speed Control Pedal
Jeu De Controle-Croisire [Opt Ion] / Cruise Control Kit [Option]
Levier De Bloc Embrayage / Cl Utch Lock Lever
Carter Different Iel Arriere / Rear Differential Case
Differentiel Arr Iere / Rear Differential
Arbre D'engrenag E Conique / Bevel Gear Shaft
Carter Engrenage Conique / Bevel Gear Case
Carter De Pont A Rriere / Rear Axle Case
Arbre D'entrainm Ent Arriere / Rear Drive Shaft
Roue Arriere(18* 9.5-8) / Rear Wheel(18*9.5-8)
Pompe Hydraulique (Direction Assistee) / Hyd Raulic Pump (Ps)
Circuit C'huile Hydrauliqu E / Hydraulic Oil Line (Inlet)
Circuit D'huile Hydrauliqu E (Refroidisseur) / Hydraulic Oil Line (Oil Cooler)
Cylindre Hydraulique / Hyd Raulic Cylinder
Distributeur Hydraulique / Control Valve
Distributeur [Parties Comp Osantes] / Control Valve [Component Parts]
Jeu De Distributeur (1soup Ape) [Option] / Control Valve Kit (1valve) [Option]
Jeu De Distributeur (2soup Ape) [Option] / Control Valve Kit (2valve) [Option]
Relevage De Tondeuse / Mower Link
Couvercle De Joint / Joint Cover
Contrepoids / Weight
Capot / Hood (Bonnet)
Couvercle Lateral / Side Cover
Colonne De Direction / Steering Post
Aile / Fender
Aile / Fender
Aile / Fender
Siege / Seat
Siege / Seat
Cadre Anti-Renversement [Option] / Rops [Opti On]
Etiquette / Label
Accessoires / Accessories
