Kubota Front Mower F2880-EC Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Front Mower
Model: Kubota F2880-EC Front Mower
Number of Pages: 279 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivel / Dipstick And Guide
Volante / Flywheel
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Superior Junta Kit [Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit [Opcion] / Lower Gasket Kit [Option]
Ventilador / Fan
A Prueba De Polvo Placa / Dustproof Plate
Kit A Prueba De Polvo [Opcion] / Dustproof Kit [Option]
Alternador / Alternator
Motor De Arranque / Starter
Interruptor / Switch
Tacometro Kit[Opcion] / Tachometer Kit [Option]
Electrico Piezas Kit [Opcion] / Electrical Parts Kit [Option]
Luz Kit [Opcion] / Light Kit [Option]
Embrague / Clutch
Caja De Diferencial / Differental Gear Case
Hst [Componente Piezas] / Hst [Component Parts]
Universal Junta/Ventilador / Universal Joint/Fan
Eje De Tdf / Pto Shaft
Trasero Rueda Helice Eje / Rear Wheel Propeller Shaft
Uno-Via Embrague[Componente Piezas] / One-Way Clutch [Component Parts]
Adelante Eje / Front Axle
Rueda Delantera(24*12.0-12) / Front Wheel(24*12.0-12)
Freno / Brake
Freno Pedal / Brake Pedal
Kit Del Freno [Opcion] / Turn Assist Brake Kit [Option]
Control Valvula / Cruise Control Lever
Hidraulico Ascenso Palanca / Hydraulic Lift Lever
Velocidad Cambio Pedal / Speed Control Pedal
Velocidad De Crucero Control Kit [Opcion] / Cruise Control Kit [Option]
Embrague Cerradura Palanca / Clutch Lock Lever
Trasero Diferencial / Rear Differential Case
Eje De Engranaje Diferencial / Bevel Gear Shaft
Trasero Rueda Accionar Eje / Rear Drive Shaft
Rueda Posterior(18*9.5-8) / Rear Wheel(18*9.5-8)
Atar Varilla / Tie Rod
Mango De Direccion / Steering Wheel
Hidraulico Bomba(Potencia Direccion) / Hydraulic Pump (Ps)
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Control Valvula Kit(1 Valvula) [Opcion] / Control Valve Kit (1valve) [Option]
Control Valvula Kit(2 Valvula)[Opcion] / Control Valve Kit (2valve) [Option]
Cortacespedes Varillaje / Mower Link
Junta Cubierta / Joint Cover
Peso / Weight
Peso / Weight
Capo / Hood (Bonnet)
Lado Cubierta / Side Cover
Direccion Poste / Steering Post
Guardabarros / Fender
Hoja / Seat
Arco De Seguridad [Opcion] / Rops [Option]
Etiqueta / Label
Accesorios / Accessories
Volante / Flywheel
Ventilador / Fan
Embrague / Clutch
Freno / Brake
Peso / Weight
Peso / Weight
Hoja / Seat
Etiqueta / Label
