Kubota Front Mower F251E-EU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Front Mower
Model: Kubota F251E-EU Front Mower
Number of Pages: 181 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Dipstick
Volante / Flywheel
Speed Control Plate
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Acelerador Palanca / Hand Accelerator Lever
Ventilador / Fan
Agua Tubo / Water Pipe
A Prueba De Polvo Placa / Dustproof Plate
Interruptor Del Aceite Y Sensor Thermo / Oil Switch
Sensor De Rotacion / Revolution Sensor
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Electrical Wiring
Embrague / Clutch
Hst (Bloque De Cilindro) [Componente Piezas] / Hst [Component Parts]
Universal Junta/Ventilador / Universal Joint/Fan
Pto Eje / Pto Shaft
Trasero Rueda Helice Eje / Rear Wheel Propeller Shaft
Adelante Eje / Front Axle
Rueda Delantera (23*10.5-12) / Front Wheel (23*10.5-12)
Freno / Brake
Freno Pedal / Brake Pedal
Gama Engranaje Cambio Palanca / Range Shift Lever
Hidraulico Ascenso Palanca / Hydraulic Lift Lever
Eje Trasero / Rear Axle
Rueda Trasera (16*6.5-8) / Rear Wheel (16*6.5-8)
Hidraulico Bomba(Potencia Direccion) / Hydraulic Pump (Ps)
Direccion Cilindro [Componente Piezas] / Steering Cylinder[Component Parts]
Hidraulico Bomba [Componente Piezas] / Hydraulic Pump (Component Parts)
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Hidraulico Aceite Linea(Aceite Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Cortacespedes Varillaje / Mower Link
Peso / Weight
Adelante Bastidor / Front Frame
Capo / Bonnet (Hood) Cover
Lado Cubierta / Side Cover
Direccion Poste / Steering Post
Guardabarros / Fender
Hoja / Seat
Arco De Seguridad / Rops
Etiquetas / Labels
Accesorios / Accessories
Volante / Flywheel
Speed Control Plate
Ventilador / Fan
Conmutador / Switch
Electrical Wiring
Embrague / Clutch
Pto Eje / Pto Shaft
Freno / Brake
Peso / Weight
Hoja / Seat
Etiquetas / Labels
