Kubota Front Mower F251-EU Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota F251-EU Front Mover
Number of Pages: 130 Pages
Frequently Used Item S / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Tête / Head Cover
Filtre D'huile / Oil Filter
Jauge D'huile / Dipstick
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carburant Et Arbre Regulateur / F Uel Camshaft And Governor Shaft
Plaque De Limiteur De Vitesse / Speed Control Plat E
Porte-Injecteur [Parties Composantes] / Nozzle Hol Der [Component Parts]
Bride A Eau Et Thermostat / Water Flange And Therm Ostat
Pompe A Eau / Water Pump
Soupape / Culbuteur / Valve And Rocker Arm
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints Supérieur / Upper Gasket Kit
Jeu De Joints Inférieur / Lower Gasket Kit
Levier D'accelerateur / Hand Accelerator Lever
Reservoir Carb. / Fuel Tank
Ventilateur / Fan
Tuyau D'eau / Water P Ipe
Radiateur / Radiator
Plateall A Poussiere / Dustproof Plate
Reservoir Du Radiateu R / Reserve Tank
Contact A Huile Thermometr E / Oil Switch
Sonde De La Ratation / Rev Olution Sensor
Solenoide D'arret / Stop S Olenoid
Alternateur Complet / Alte Rnator
Alternateur [Parties Compo Santes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Composa Ntes] / Starter [Component Parts]
Batterie / Battery
Commutateur / Switch
Faisceau Electrique / Elec Trical Wiring
Embrayage / Clutch
Embrayage / Clutch
Carter De Differentiel / Differential Gear Case
Hst (Arbre D'entree) [Parties Composan Tes] / Hst [Component Parts]
Arbre De Prise De Force / Pto Shaft
Differentiel Avant / Front Differentia L
Arbre D'entrainement Arriere / Rear Wh Eel Propeller Shaft
Embrayage D'entrainement [Parties Comp Osantes] / One-Way Clutch [Component Parts]
Pont Avant / Front Axle
Roue Avant (24*12.0 0-12) / Front Wheel (24*12.00-12)
F Rein / Brake
P Edale De Frien / Brake Pedal
P Edale De Verrouillage Du Differentiel / Differentia L Lock Pedal
Levier De Changement De Gamme / Range Shift Lever
Levier De Chengement De Vitess E Pdf / Pto Gear Shift Lever
Pedale De Commande De Vitesse / Speed Change Pedal
Differentiel Arri Ere / Rear Differential Case
Differentiel Arri Ere / Rear Wheel Differential
Demi Arbre De Pon T Avant / Differential Gear Shaft
Carter Engre-Coni Que / Bevel Gear Case
Carter Pont Arrie Re / Rear Axle Case
Arbre D'entrainme Nt Arriere / Rear Wheel Drive Shaft
Roue Arriere (18* 9.5-8) / Rear Wheel (18*9.5-8)
Pompe Hydraulique (Direction Assistee) / Hydr Aulic Pump (Ps)
Cylindre De Direction [Parties Composantes] / Steering Cylinder[Component Parts]
Support Avant Droit / Hydra Ulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump (Component Parts)
Circuit C'huile Hydraulique / Hydraulic Oil Line (Inlet)
Circuit D'huile Hydraulique (Refroidisseur) / Hydraulic Oil Line (Oil Cooler)
Cylindre Hydraulique / Hydr Aulic Cylinder
Distributeur Hydraulique / Control Valve
Distributeur [Parties Compo Santes] / Control Valve [Component Parts]
Relevage De Tondeuse / Mower Link
Contrepoids / Weight
Capot Superieur / Bonnet (Hood) Cover
Capot Lateral / Side Cover
Colonne De Direction / Steering Post
Aile / Fender
Siege / Seat
Siege / Seat
Cadre Anti-Renversment / Rops
Etiquettes / Labels
Etiquettes / Labels
Accessoires / Accessories
