Kubota Front Mower F2400 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota F2400 Front Mover
Number of Pages: 171 Pages
B Loc Moteur / Crankcase
C Arter D'huile / Oil Pan
P Istons Et Vilebrequin / Piston And Crankshaft
P Aliers De Principal / Main Bearing Case
V Olant Du Moteur / Flywheel
C Ulasse / Cylinder Head
S Oupapes Culbuteurs / Valve And Rocker Arm
P Orte-Injecteur / Nozzle Holder
[Component Parts]
[Component Parts]
[Component Parts]
C Ouvre Culbuteurs / Head Cover
C Ollecteur D'admission / Inlet Manifold
[F2400]
[F2400]
[F2400]
[F2400]
A Rbre A Cames / Camshaft
K It D'accouplements Rapides [Option] / Gear Case
P Ompe A Eau / Water Pump
B Ride A Eau / Water Flange
A Rbre A Cames Dalimentation / Fuel Camshaft
P Ompe D'injection / Injection Pump
S Olenoide D'arret Du Moteur / Engine Stop Solenoid
P Laque De Limiteur De Vitesse / Speed Control Plate
R Egulateur De Vitesses / Governor
L Evier D'accelerateur / Accelerator Lever
Reservoir Carb. / Fuel Tank
[F2400]
[Component Parts]
[F2400]
[F2400]
[F2400]
[F2400]
[Component Parts]
[F2400]
[Component Parts]
Systeme Electrique 1 / Elect Rical System 1
Systeme Electrique 2 / Elect Rical System 2
[Option]
[Option]
[Option]
[F2400]
Arbre De Transmission [F2400] / Propeller Shaft [ F2400]
Bielle De Verrouillage Du Differentiel / Differen Tial Lock Rod And Clutch Rod
Tige D'embrayage / Cluch Rod
Carter D'embrayage / Clutch Housing Frame
Carter De Transmission / Transmission Ca Se
Couvercle De Carter De Transmission / Tr Ansmission Case Cover
[F2400]
[F2400]
[F2400]
[Com Ponent Parts]
Deuxieme Arbre / Second Shaft
Troisieme Arbre Et Cinquieme Arbre / Thi Rd Shaft And Fifth Shaft
Quatrieme Arbre / Fourth Shaft
Levier De Pdf / Pto Lever
Levier De Change Ment De Gamme Et Traction Arriere / Range Shift Lev Er And Rear Wheel Drive Lever
Changement De Vi Tesse 1 / Speed Change 1
Changement De Vi Tesse 2 / Speed Change 2
Changement De Vi Tesse 3 / Speed Change 3
Differentiel Avant / Front Differential
Carter Reducteur / Fr Ont Axle Case
Pont Avant / Front Ax Le
Roue Avant (23x10,5-1 2) / Front Wheel (23x10.5-12)
Fre In / Brake
Fre In / Brake
Fre In / Brake
Ped Ale D'embrayage Et Pedale De Frein / Clutch Pedal A Nd Brake Pedal
Tig E De Frein / Brake Rod
Moyeu De Roue Arrie Re / Rear Wheel Hub
Carter De Pont Arri Ere / Rear Axle Case
Bras De Pont Arrier E / Rear Axle Arm
Differentiel Arrier E / Rear Differential
Carter Intermediair E / Mid Case
Joint De Cardan / U Niversal Joint
Roue Arriere (16x6, 50-8) / Rear Wheel (16x6.50-8)
[F2400]
Bras De Pivot / Knuckle Arm
Direction / Steering
Poteau De Manette / Handle Post
Servo Direction / Power Steer Ing
[Component Parts]
[Component Parts]
[F2400]
[Component Parts]
[Component Parts]
[Component Parts]
[F2400]
[F2400]
[F2400]
[F2400]
[F2400]
[F2400]
[F2400]
Distributeur Hydraulique / Co Ntrol Valve
[Component Parts]
[Component Parts]
[Component Parts]
[Option]
[Option]
[Component Parts]
Chainon / Lin K
Chainon / Lin K
Bras De Relev Age / Lift Arm
Capot / Hood(Bonnet)
Aile / Fender
Aile / Fender
Aile / Fender
Chassis Avant / Front Frame
Siege / Seat
Siege / Seat
[Component Parts] [Except F2400-Elw,Glw ,Slw]
Etiquette / Label
Acc Essories Et Piece De Service / Accessories And Serv Ice Parts
