Kubota Front Mower F2400 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Front Mower
Model: Kubota F2400 Front Mower
Number of Pages: 265 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Volante / Flywheel
Nozzle Holder
Portainyector [Componentes] / Nozzle Holder [Component Parts]
Head Cover
Air Cleaner [F2400]
Muffler [F2400]
Camshaft
Agua Bomba / Water Pump
Water Flange
Bomba Inyección / Injection Pump
Engine Stop Solenoid
Placa De Control De Velocidad / Speed Control Plate
Fuel Pipe [F2400]
Filtro De Combustible [Componentes] / Fuel Filter [Component Parts]
Fan [F2400]
Radiator [F2400]
Dustproof Plate [F2400]
Alternator [F2400]
Alternador [Componentes] / Alternator [Component Parts]
Starter [F2400]
Motor De Arranque [Componentes] / Starter [Component Parts]
Electrical System 1
Electrical System 2
Light Kit [Option]
Clutch [F2400]
Propeller Shaft [F2400]
Differential Lock Rod And Clutch Rod
Cluch Rod
Clutch Housing Frame
Transmission Case Cover
Hst [F2400]
Hst [Component Parts]
Second Shaft
Third Shaft And Fifth Shaft
Fourth Shaft
Pto Lever
Range Shift Lever And Rear Wheel Drive Lever
Speed Change 1
Speed Change 2
Speed Change 3
Adelante Eje / Front Axle
Front Wheel (23x10.5-12)
Freno / Brake
Clutch Pedal And Brake Pedal
Brake Rod
Rear Wheel Hub
Rear Axle Case
Rear Axle Arm
Drive Shaft
Mid Case
Universal Joint
Rear Wheel (16x6.50-8)
Rear Axle Frame [F2400]
Knuckle Arm
Steering
Handle Post
Power Steering
Power Steering [Component Parts]
Power Cylinder [Component Parts]
Hydraulic Pump [F2400]
Bomba Hidraulica [Componentes] / Hydraulic Pump [Component Parts]
Hydraulic Pipe [F2400]
Oil Cooler [F2400]
Control Valve [Component Parts]
Lift Cylinder [Component Parts]
Control Valve Kit [Option]
Control Valve 2 [Component Parts]
Ascenso Brazo / Lift Arm
Hood(Bonnet)
Fender
Front Frame
Hoja / Seat
Seat [Component Parts] [Except F2400-Elw,Glw,Slw]
Label
