Kubota Front Mower F2000ELW Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota F2000ELW Front Mover
Number of Pages: 110 Pages
Carter Moteur / Crankcase
Carter D'huile / Oil Pan
Pistons/Vilebrequin / Piston/Crankshaft
Volant Moteur/Deamrreur / Flywheel/Starter
[Componen T Parts]
Culasse / Cylinder Head
Soupapes/Culbuteurs / Valve/Rocker Arm
Injecteurs Et Tuyauteries / Nozzle Holder
[Component Parts]
Couvre Culbuteurs / Head Cover
Collecteur / Inlet Manifold
Arbre A Cames / Camshaft
Pompe A Eau / Water Pump
Bride / Water Flange
Arbre A Cames De Carburant / Fuel Camshaft
[Component Parts]
[Component Parts]
Levier D'arret Du Moteur Pompe A Engrenage / Engi Ne Stop Lever Gear Pump
[Component Parts]
[Component Parts]
Plaque De Limteur De Vitesse / Speed Control Plat E
Regulateur De Regime / Governor
Arret De Solenoide / Stop Solenoid
Alternateur / Dynamo
[Compone Nt Parts]
Filtre A Air / Air Clea Ner
Silencieux / Muffler
Bielle De Debrayage / Release Rod
Tuy. Carburant / Fuel Pipe
[Component Parts]
[Component Parts]
Radiateur / Radiator
Filtre A Poussieres / Dustproof Net
Systeme Electrique 1 / El Ectrical System 1
Systeme Electrique 2 / El Ectrical System 2
Embrayage / Clutch
Embrayage / Clutch
Bielle / Diff. Lock Clutch Rod
Tige D'embrayage / Clutch Rod
Carter D'embrayage / Clutch Housing Frame
Hst / Hst
[Compon Ent Parts]
Carter Couvre / Case Cover
Deuxieme Arbre / Second Shaft
Troisieme Cinquieme Arbre / Third F Ifth Shaft
Quatrieme Arbre / Fourth Shaft
Fourchette De C Hangement De Vitesse / Speed Change Fork And Pto Le Ver
Levier De Chang Ement / Aux. Speed Change And Front Drive Lever
Changement De V Itesse 1 / Speed Change 1
Changement De V Itesse 2 / Speed Change 2
Changement De V Itesse 3 / Speed Change 3
Differentiel / Dif Ferential
Carter Pont / Axle Case
Pont Avant / Front Axle
(23 X 10.5-12)
Frein / Brake
Frein / Brake
Pedale / Pedal
Tige De Frein / Brake Rod
Carter Pont Arri Ere / Rear Axle Arm
Arbre D'entrain / Drive Shaft
Bras D'essieu Ar Riere / Rear Axle Case
Differentiel / D Ifferential
Moyeu De Roue / Wheel Hub
Roue Arriere (16 X6.50-8) / Rear Wheel (16x6.50-8)
Chassis D'essieu Arriere / Rear Axle Frame
Bras De Pivot / Knuckle Arm
Direction / Steering
Servodirection / Power Steering
[Component Parts]
Tuy. Hydraulique 1 / Hydra Ulic Pipe 1
Distributeur / Control Val Ve
[Component Parts]
[Component Parts]
Soupape De Controle / Cont Rol Valve Kit
[Component Parts]
[Component Parts]
Refroidisseur / Oil Cooler
Carter Interm / Mid Case
Ch Ainon / Link
[Component Parts]
Jo Int De Cardan / Universal Joint
Ca Pot / Hood
Chassis Avant / Fro Nt Frame
S Iege / Seat
Etiquette / Label
Accessoires Et Pieces De Service / Acce Ssories And Service Parts
