Kubota Front Mower F2000 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota F2000 Front Mover
Number of Pages: 105 Pages
C Arter Moteur / Crankcase
C Arter D'huile / Oil Pan
P Istons/Vilebrequin / Piston/Crankshaft
P Aliers De Principal / Main Bearing Case
V Olant Moteur/Deamrreur / Flywheel/Starter
[Component P Arts]
C Ulasse / Cylinder Head
S Oupapes/Culbuteurs / Valve/Rocker Arm
I Njecteurs Et Tuyauteries / Nozzle Holder
[Component Parts]
C Ouvre Culbuteurs / Head Cover
C Ollecteur / Inlet Manifold
A Rbre A Cames / Camshaft
C Arter De Distribution / Gear Case
P Ompe A Eau / Water Pump
B Ride / Water Flange
A Rbre A Cames De Carburant / Fuel Camshaft
[Component Parts]
L Evier D'arret Du Moteur Pompe A Engrenage / Engine Stop Lever Gear Pump
[Component Parts]
P Laque De Limteur De Vitesse / Speed Control Plate
R Egulateur De Regime / Governor
A Rret De Solenoide / Stop Solenoid
A Lternateur / Dynamo
[Component Parts]
Filtre A Air / Air Cleaner
Silencieux / Muffler
Bielle De Debrayage / Release Rod
Tuy. Carburant / Fuel Pipe
[Component Parts]
Radiateur / Radiator
Filtre A Poussieres / Dustproof Ne T
Systeme Electrique 1 / Elect Rical System 1
Systeme Electrique 2 / Elect Rical System 2
[Udw]
Embrayage / Clutch
Embrayage / Clutch
Bielle / Diff. Lock Clutch Rod
Tige D'embrayage / Clutch Rod
Carter D'embrayage / Clutch Housing Frame
Carter De Transmission / Transmission Ca Se
Hst / Hst
[Component Parts]
Carter Couvre / Case Cover
Deuxieme Arbre / Second Shaft
Troisieme Cinquieme Arbre / Third Fift H Shaft
Quatrieme Arbre / Fourth Shaft
Fourchette De Chan Gement De Vitesse / Speed Change Fork And Pto Lever
Levier De Changeme Nt / Aux. Speed Change And Front Drive Lever
Changement De Vite Sse 1 / Speed Change 1
Changement De Vite Sse 2 / Speed Change 2
Changement De Vite Sse 3 / Speed Change 3
Differentiel / Differ Ential
Carter Pont / Axle Ca Se
Pont Avant / Front Ax Le
(23 X 10.5-12)
Fre In / Brake
Ped Ale / Pedal
Tig E De Frein / Brake Rod
Carter Pont Arriere / Rear Axle Arm
Arbre D'entrain / D Rive Shaft
Bras D'essieu Arrie Re / Rear Axle Case
Differentiel / Diff Erential
Moyeu De Roue / Whe El Hub
Chassis D'essieu Ar Riere / Rear Axle Frame
Bras De Pivot / Knuckle Arm
Direction / Steering
Servodirection / Power Steering
[Component Parts]
Tuy. Hydraulique 1 / Hydrauli C Pipe 1
Distributeur / Control Valve
[Component Parts]
[Component Parts]
Soupape De Controle / Control Valve Kit
[Component Parts]
[Component Parts]
Refroidisseur / Oil Cooler
Carter Interm / Mid Case
[Component Parts]
Bras De Relevage / Lift Arm
Joint De Cardan / Universal Joint
Capot / Hood
Capot / Hood
Aile / Fender
Chassis Avant / Front Frame
Sieg E / Seat
Etiquette / Label
Accessoires Et Pieces De Service / Accesso Ries And Service Parts
