Kubota Front Mower F1900FR Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Front Mower
Model: Kubota F1900FR Front Mower
Number of Pages: 299 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivel / Dipstick And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Portainyector [Componentes] / Nozzle Holder [Component Parts]
Couvercle / Cover
Dinamo Y Polea [Fr] / Dynamo And Pulley [Fr]
Alternador [Componente Piezas] [Fr] / Dynamo [Component Parts] [Fr]
Alternador Y Polea [Uk][Fr] / Alternator And Pulley [Uk][Fr]
Alternador [Componente Piezas] [Uk][Fr] / Alternator [Component Parts] [Uk][Fr]
Aceite Conmutador Y Termometro / Oil Switch And Thermometer
Agua Bomba / Water Pump
Ventilador / Fan
Aire Limpiador / Air Cleaner
Silenciador / Muffler
A Prueba De Polvo Placa / Dustproof Plate
Motor De Arranque / Starter
Interruptor / Switch
Interruptor Interno Del Capo / Bonnet Switch
Cableado Eléctrico / Electrical Wiring
Pto Engranaje Caja / Pto Gear Case
Uno-Via Eje / One-Way Shaft
Hst
Hst [Componente Piezas] / Hst [Component Parts]
Universal Junta/Ventilador / Universal Joint/Fan
Palanca De Tdf / Pto Lever
Eje De Tdf / Pto Clutch/Pto Shaft
Velocidad De Crucero Control Placa / Cruise Control Plate
Control Valvula / Cruise Control Lever
Velocidad Cambio Pedal / Speed Control Pedal
Adelante Eje / Front Axle
Rueda Delantera (20x10.00-8) / Front Wheel (20x10.00-8)
Freno Eje / Brake Shaft
Freno / Brake
Varilla De Freno / Brake Rod
Freno Pedal / Brake Pedal
Trasero Rueda Accionar Eje / Drive Shaft
Rueda Posterior (16x6.50-8) / Rear Wheel (16x6.50-8)
Mangueta Brazo / Knuckle Arm
Atar Varilla / Tie Rod
Arrastre Vinculo / Drag Link
Caja De Engranajes De Direccion / Steering Gear Case
Mango De Direccion / Steering Wheel
Tubo Hidraulico(Aspiracion)[Tipo Arco] / Hydraulic Oil Line (Suction)
Hidraulico Aceite Linea(Hst) / Hydraulic Oil Line (Hst)
Hydraulico Aceite Linea (Tdf) / Hydraulic Oil Line (Pto)
Valvula Hidraulica [Componente Piezas] / Hydraulic Valve [Component Parts]
Cortacespedes Varillaje / Mower Link
Peso / Weight
Peso / Weight
Capo Superior / Hood (Bonnet)
Direccion Poste / Steering Post
Guardabarros / Fender
Asiento / Seat
Asiento / Seat
Arco De Seguridad [Opcion] / Rops [Option]
Etiqueta Excepto / Label
Accesorios / Accessories
Bisel Engranaje Caja [Opcion] / Bevel Gear Case [Option]
