Kubota Front Mower F1900E3 Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Front Mower
Model: Kubota F1900E3 Front Mower
Number of Pages: 104 Pages
Itens Usados F Requentemente / Frequently Used Items
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Hol Der [Component Parts]
Tampa / Cover
Alternador E Poli / Alternator And Pulley
Alternador [Peças Componentes] / Alternator [ Component Parts]
Interruptor E Termómetro Do Óleo / Oil Switch And Thermometer
Bomba Agua E Termostacto / Water Flange And T Hermostat
Bomba Agua / Water Pump
Valvula E Veio Martelos / Valve And Rocker Ar M
Filtro Ar / Air Cleaner
Escpae / Muffler
Alavanca Acelarador / Accelerator Lever
Filtro Gasoleo / Fuel Filter
Placa À Pro Va De Poeiras / Dustproof Plate
Valvula Solenoide / Stop Sol Enoid
Motor Arranque / Starter
Interruptor / Switch
Interruptor De Capot / Bonne T Switch
Cablagem Electrica / Electri Cal Wiring
Caixa Da Transmissão / Transmission Cas E
Caica De Carretos De Tdf / Pto Gear Cas E
One-Way Eixo / One-Way Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [Componen T Parts]
Ventoinha/Junta Universal / Universal J Oint/Fan
Veio Tdf / Pto Shaft
Diferencial Dianteiro / Front Different Ial
Bloqueio Diferencial De Forqu Eta / Differential Lock Shift Fork
Prato De Controlo Da Velocida De De Cruzeiro / Cruise Control Plate
Control Velocidade / Cruise C Ontrol Lever
Pedal Acelarador / Speed Chan Ge Pedal
Carter Eixo Frente / Front Differential Case
Eixo Diante Iro / Front Axle
Bloqueio Di Ferencial Pedal / Differential Lock Pedal
Roda Frente (20*10.00-8) / Front Wheel (20*10.00-8)
Eixo / Brake Shaft
Travão / Brake
Tirante Travao / Brake Rod
Pedal Travao / Brake Pedal
Eixo Traseiro/B Raço / Rear Axle/Knuckle Arm
Roda Traseira ( 16*6.50-8) / Rear Wheel (16*6.50-8)
Ligação / Drag Link
Caica De Carretos Da Direcção / Steering Gear Case
Linha Aspiração (Sucção) / H Ydraulic Pipe (Suction)
Tubo Oleo (Hst) / Hydraulic Oil Line (Hst)
Tubo Oleo (Tdf) / Hydraulic Oil Line (Pto)
Valvula Control / Control Va Lve
Valvula Control [Peças Compo Nentes] / Control Valve [Component Parts]
Cilndro Ele Veção / Mower Lift Cylinder
Valvula Hid Raulico / Hydraulic Valve [Component Parts]
Ligação Do Cortador De Relva / Mower Linkage
Peso / Weight
Guarda Lamas / Fender
Banco / Seat
Arco / Rops
Etiquetas / Labels
Acessorios / Accessories
Carreto / Gear Case
Tampa / Cover
Escpae / Muffler
Hst / Hst
Eixo / Brake Shaft
Travão / Brake
Ligação / Drag Link
Peso / Weight
Banco / Seat
Arco / Rops
Etiquetas / Labels
