Kubota Front Mower F1900E(UK) Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Front Mower
Model: Kubota F1900E(UK) Front Mower
Number of Pages: 178 Pages
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Resguardo / Cover
Dimano E Poli [Fr] / Dynamo And Pulley [Fr]
Dinamo [Peças Componentes] [Fr] / Dynamo [Comp Onent Parts] [Fr]
Alternado E Poli [Uk][Fr] / Alternator And Pull Ey [Uk][Fr]
Alternador [Peças Componentes] [Uk][Fr] / Alter Nator [Component Parts] [Uk][Fr]
Interruptor E Termómetro / Oil Switch And Thermo Meter
Acessorios / Water Pump
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Deposito Combustivel / Fue L Tank
Filtro Gasoleo / Fuel Filt Er
Placa À Prova De Poeiras / Dustproof Plate
Filtro Gasoleo / Stop Sol Enoid
Motor Arranque / Starter
Comutador / Switch
Interruptor De Capot / Bo Nnet Switch
Bomba Hidraulico / Light
Cabalagem Eletrica / Elec Trical Wiring
Caixa Velocidades / Transmission Cas E
Caica De Carretos De Tdf / Pto Gear Case
One-Way Eixo / One-Way Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [Compo Nent Parts]
Ventoinha/Junta Universal / Universa L Joint/Fan
Alavanca Tdf / Pto Lever
Veio Tdf / Pto Clutch/Pto Shaft
Diferencial Dianteiro / Front Differ Ential
Alavanca / Differential Lo Ck Shaft
Prato De Controlo Da Veloc Idade De Cruzeiro / Cruise Control Plate
Control Velocidade / Cruis E Control Lever
Pedal Acelarador / Speed C Ontrol Pedal
Carter E Ixo / Front Axle Case
Eixo Dia Nteiro / Front Axle
Eixo / Brake Shaft
Travão / Brake
Tirante Travao / Brake Rod
Pedal Travao / Brake Pedal
Eixo Traseir O/Braço / Rear Axle/Knuckle Arm
Roda Traseir A (16x6.50-8) / Rear Wheel (16x6.50-8)
Ligação / Drag Link
Caica De Carretos Da Direcção / Steering Ge Ar Case
Linha Aspiração / Hydraul Ic Oil Line (Suction)
Tubo Oleo / Hydraulic Oil Line (Hst)
Tubo Oleo (Tdf) / Hydraul Ic Oil Line (Pto)
Braco Hidraulico / Contro L Valve
Valvula Control / Control Valve [Component Parts]
Valvula Hidraulico / Hydraulic Valve [Component Parts]
Ligação Do Cortador De Relva / Mower Link
Peso / Weight
Estrutura / Main Frame
Capot / Hood (Bonnet)
Guarda Lamas / Fender
Banco / Seat
Arco [Opção] / Rops [Option]
Etiqueta Frente / Label
Acessorios / Accessories
Carreto / Gear Case
Resguardo / Cover
Ventilador / Fan
Escpae / Muffler
Comutador / Switch
Hst / Hst
Eixo / Brake Shaft
Travão / Brake
Ligação / Drag Link
Peso / Weight
Banco / Seat
