Kubota Front Mower F1900E(UK) Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Front Mover
Model: Kubota F1900E(UK) Front Mover
Number of Pages: 186 Pages
Articles Fréquemm Ent Utilisés / Frequently Used Items
Bloc Moteur / Crank Case
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Filtre D'huile / Oil Filter
Pompe D'huile / Oil Pump
Volant Du Moteur / Flywheel
Plaque De Limiteur De Vitesse / Speed Control P Late
Porte-Injecteur Et Bougie De Prechauffage / Noz Zle Holder And Glow Plug
Couvercle / Cover
Dynamo [Fr] / Dynamo And Pulley [Fr]
Dynamo [Parties Composantes] [Fr] / Dynamo [Co Mponent Parts] [Fr]
[Uk][Fr] / Alternator And Pulley [Uk][Fr]
Alternateur [Parties Composantes] [Uk][Fr] / A Lternator [Component Parts] [Uk][Fr]
Contact A Huile Et Thermometre / Oil Switch And Thermometer
Bride A Eau Et Thermostat / Water Flange And Th Ermostat
Pompe A Eau / Water Pump
Ventilateur / Fan
Soupapes Et Culbuteurs / Valve And Rocker Arm # # Note : Order By Ref.No.080,090,170 New Parts & 10 0 Set / Note : Order By Ref.No.080,090,170 New Part S & 100 Set
Filter A Air / Air Cleaner
Silencieux / Muffler
Reservoir Carb. / Fuel Tank
Radiateur / Radiat Or
Plateall A Poussie Re / Dustproof Plate
Solenoide D'arret / Sto P Solenoid
Lanceur / Starter
Lanceur / Starter
Lanceur / Starter
Batterie / Battery
Interrupteur / Switch
Interrupteur De Capot / Bonnet Switch
Lampe / Light
Lampe / Light
Faisceau Electrique / E Lectrical Wiring
Carter De Transmission / Transmissi On Case
Carter De Distribution De Pdf / Pto Gear Case
Arbre D'entrainement / One-Way Shaf T
Hst / Hst
Hst [Parties Composantes] / Hst [Co Mponent Parts]
Joint De Cardan/Ventilateur / Unive Rsal Joint/Fan
Levier De Pdf / Pto Lever
Embrayage De Prise De Force/Arbre D E Prise De Force / Pto Clutch/Pto Shaft
Differentiel Avant / Front Differen Tial
Arbre De Blocage Differenti El / Differential Lock Shaft
Plaque De Controle-Croise / Cruise Control Plate
Levier De Control-Croisiere / Cruise Control Lever
Pedale De Commande De Vitte Sse / Speed Control Pedal
Pont Avant / Fro Nt Axle
Pedale De Verrou Illage Du Differentiel / Differential Lock Pedal
Roue Avant (20x1 0.00-8) / Front Wheel (20x10.00-8)
Arbre De Frein / Brake Shaft
Frein / Brake
Tige De Frein / Brake Rod
Pedale De Frien / Brake Pedal
Essieu Arriere /Bras De Pivot / Rear Axle/Knuckle Arm
Roue Arriere ( 16x6.50-8) / Rear Wheel (16x6.50-8)
Rotule De Direction / Drag Link
Carter De Direction / Steering Gear Case
Circuit D'huile Hydrauli Que (Aspirat) / Hydraulic Oil Line (Suction)
Circuit D'huile Hydrauli Que (Hst) / Hydraulic Oil Line (Hst)
Circuit D'huile Hydrauli Que (Pto) / Hydraulic Oil Line (Pto)
Distributeur Hydraulique / Control Valve
Distributeur [Parties Co Mposantes] / Control Valve [Component Parts]
Cylindr E De Relevage / Lift Cylinder
Soupape Hydraulique [Parties Composantes] / Hydraulic Valv E [Component Parts]
Chainon De Faucheur / Mower Link
Contrepoids / Weight
Capot Superieur / Hood (Bonnet)
Colonne De Direction / Steering Post
Aile / Fender
Aile / Fender
Siege / Seat
Siege / Seat
Siege / Seat
Siege / Seat
Cadre Anti-Renversement [Option] / Rops [Op Tion]
Etiquette / Label
Etiquette / Label
Accessoires / Accessories
