Kubota Front Mower F1900D2 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Front Mower
Model: Kubota F1900D2 Front Mower
Number of Pages: 189 Pages
Bloque Motor / Crank Case
Carter / Oil Pan
Cilindro Ppal / Cylinder Head
Caja De Cambio / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivel / Dipstick And Guide
Aceite Bomba / Oil Pump
Caja De Cambios Ppal / Main Bearing Case
Piston Y Ciguenal / Piston And Crankshaft
Volante / Flywheel
Portainyector [Componentes] / Nozzle Holder [Component Parts]
Couvercle / Cover
Alternador Y Polea / Alternator And Pulley
Alternador [Componentes] / Alternator [Component Parts]
Aceite Conmutador Y Termometro / Oil Switch And Thermometer
Termostatoy Tapa / Water Flange And Thermostat
Bomba Agua / Water Pump
Ventilador / Fan
Valvulas Y Balancines / Valve And Rocker Arm
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Filtro Combustible / Fuel Filter
A Prueba De Polvo Placa / Dustproof Plate
Motor De Arranque / Starter
Motor De Arranque [Componentes] / Starter [Component Parts]
Conmutador / Switch
Interruptor Interno Del Capo / Bonnet Switch
Instalacion Electrica / Electrical Wiring
Pto Engranaje Caja / Pto Gear Case
Uno-Via Eje / One-Way Shaft
Hst (Bloque De Cilindro) / Hst
Hst (Bloque De Cilindro) [Componente Piezas] / Hst [Component Parts]
Universal Junta/Ventilador / Universal Joint/Fan
Eje De Tdf / Pto Clutch/Pto Shaft
Velocidad De Crucero Control Placa / Cruise Control Plate
Control Valvula / Cruise Control Lever
Velocidad Cambio Pedal / Speed Control Pedal
Rueda Delantera (20*10.00-8) / Front Wheel (20*10.00-8)
Freno Eje / Brake Shaft
Freno / Brake
Varilla De Freno / Brake Rod
Freno Pedal / Brake Pedal
Trasero Rueda Accionar Eje / Drive Shaft
Rueda Trasera (16*6.50-8) / Rear Wheel (16*6.50-8)
Mangueta Brazo / Knuckle Arm
Atar Varilla / Tie Rod
Vinculo,Arrastre / Drag Link
Caja De Engranajes De Direccion / Steering Gear Case
Tubo Hidraulico(Aspiracion)[Tipo Arco] / Hydraulic Oil Line (Suction)
Hidraulico Aceite Linea(Hst) / Hydraulic Oil Line (Hst)
Hydraulico Aceite Linea (Tdf) / Hydraulic Oil Line (Pto)
Distribuidor / Control Valve
Valvula Hidraulica [Componente Piezas] / Hydraulic Valve [Component Parts]
Cortacespedes Varillaje / Mower Link
Peso / Weight
Capo Superior / Hood (Bonnet)
Direccion Poste / Steering Post
Guardabarros / Fender
Asiento / Seat
Hoja / Seat
Etiquetas / Labels
Accesorios / Accessories
Carter / Oil Pan
Volante / Flywheel
Couvercle / Cover
Ventilador / Fan
Conmutador / Switch
Freno / Brake
Peso / Weight
Asiento / Seat
Hoja / Seat
Etiquetas / Labels
