Kubota Front Mower F1900(UK) Spare Parts Catalog EN PT
Language: English, Portuguese
Type of Machine: Front Mower
Model: Kubota F1900(UK) Front Mower
Number of Pages: 188 Pages
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Resguardo / Cover
Dimano E Poli [Fr] / Dynamo And Pulley [Fr]
Dinamo [Peças Componentes] [Fr] / Dynamo [Compo Nent Parts] [Fr]
Alternado E Poli [Uk][Fr] / Alternator And Pulle Y [Uk][Fr]
Interruptor E Termómetro / Oil Switch And Thermom Eter
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Acessorios / Water Pump
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker A Rm
Filtro Ar / Air Cleaner
Escpae / Muffler
Filtro Gasoleo / Fuel Filte R
Placa À P Rova De Poeiras / Dustproof Plate
Filtro Gasoleo / Stop Sole Noid
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Comutador / Switch
Interruptor De Capot / Bon Net Switch
Bomba Hidraulico / Light
Cabalagem Eletrica / Elect Rical Wiring
Caica De Carretos De Tdf / Pto Gear C Ase
One-Way Eixo / One-Way Shaft
Hst / Hst
Hst [Peças Componentes] / Hst [Compon Ent Parts]
Ventoinha/Junta Universal / Universal Joint/Fan
Alavanca Tdf / Pto Lever
Veio Tdf / Pto Clutch/Pto Shaft
Diferencial Dianteiro / Front Differe Ntial
Prato De Controlo Da Veloci Dade De Cruzeiro / Cruise Control Plate
Control Velocidade / Cruise Control Lever
Pedal Acelarador / Speed Co Ntrol Pedal
Carter Ei Xo / Front Axle Case
Eixo Dian Teiro / Front Axle
Bloqueio Diferencial / Clutch Pedal
Roda Fren Te (20x10.00-8) / Front Wheel (20x10.00-8)
Eixo / Brake Shaft
Travão / Brake
Tirante Travao / Brake Rod
Pedal Travao / Brake Pedal
Carter Eixo / Rear Axle Case
Diferencial C Arter / Rear Differential
Eixo Traseiro / Rear Axle
Veio / Drive Shaft
Roda Traseira (16x6.50-8) / Rear Wheel (16x6.50-8)
Braço Da Articulação / Knuckle Arm
Direcção Assistida / Tie Rod
Caica De Carretos Da Direcção / Steering Gea R Case
Linha Aspiração / Hydrauli C Oil Line (Suction)
Tubo Oleo / Hydraulic Oil Line (Hst)
Tubo Oleo (Tdf) / Hydrauli C Oil Line (Pto)
Braco Hidraulico / Control Valve
Valvula Control / Control Valve [Component Parts]
Cilndro E Leveção / Lift Cylinder
Valvula H Idraulico / Hydraulic Valve [Component Parts]
Ligação D O Cortador De Relva / Mower Link
Peso / Weight
Estrutura / Main Frame
Capot / Hood (Bonnet)
Banco / Seat
Arco [Opção] / Rops [Option]
Guarda Lamas / Fender
Etiqueta Frente / Label
Acessorios / Accessories
Carreto / Gear Case
Resguardo / Cover
Ventilador / Fan
Escpae / Muffler
Comutador / Switch
Hst / Hst
Eixo / Brake Shaft
Travão / Brake
Veio / Drive Shaft
Peso / Weight
Banco / Seat
