Kubota Excavators U35 Parts Manual
Type of Machine: Excavators
Model: Kubota U35 Excavators
Number of Pages: 302 Pages
Instructions For Parts Books
U35
Crank Case
Oil Pan
Gear Case
Head Cover
Head Cover
Engine Bracket
Main Bearing Case
Main Bearing Case
Camshaft And Idle Gear Shaft
Piston And Crankshaft
Flywheel
Fuel Camshaft And Governor Shaft
Engine Stop Lever
Governor
Speed Control Plate
Nozzle Holder And Glow Plug
Alternator (Component Parts)
Starter
Starter (Component Parts)
Water Flange And Thermostat
Water Pipe
Valve And Rocker Arm
Inlet Manifold
Inlet Manifold
Exhaust Manifold
Air Cleaner
Muffler
Accel Lever
Fuel Piping
Fuel Filter (Component Parts)
Battery
Timer And Horn
Switch And Meter
Light
Electrical Wiring
Pump Housing
Piston Pump(Component Parts)
Drive Motor And Component Parts
Swivel Motor And Component Parts
Rotary Joint
Oil Tank
Control Valve
Control Valve (Component Parts)
Spool Section (Swivel)
Spool Section (Swing)
Spool Section (Blade)
Spool Section (Travel Straight)
Spool Section (S-P)
Spool Section (Arm)
Spool Section (Travel Lh)
Spool Section (Travel Rh)
Spool Section (Boom)
Spool Section (Boom Lock)
Spool Section (Bucket)
Change Valve
Change Valve (Component Parts)
Tpss Valve
Tpss Valve (Component Parts)
Control Lever (Lever Lh)
Control Lever (Lever Rh)
Pilot Valve (Component Parts)
Control Lever (Travel Lh 1)
Control Lever (Travel Lh 2)
Control Lever (Travel Rh 1)
Control Lever (Travel Rh 2)
Control Lever (Travel Lock)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel-Swing Change 1)
Control Pedal (Swivel-Swing Change 2)
Tpss Lever
Control Lever (Blade)
Control Lever (S-P)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return 1)
Oil Piping (Return 2)
Oil Piping (Oil Cooler)
Oil Piping (Control Lh)
Oil Piping (Control Rh)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (S-P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Blade
Track Frame
Idler
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Cover (Lh)
Cover (Rh)
Bonnet Lh
Bonnet Rh
Bonnet Rear
Sponge 1
Sponge 2
Weight
Canopy
Cabin (Body)
Cabin (Door)
Cabin (Door Lock)
Cabin (Window)
Cabin (Window Front)
Cabin (Seal Rubber)
Cabin (Wiper Motor)
Cabin (Electrical Wiring)
Cabin (Heater)
Cabin (Defroster)
Label
U35
Crank Case
Oil Pan
Gear Case
Head Cover
Head Cover
Engine Bracket
Main Bearing Case
Main Bearing Case
Flywheel
Engine Stop Lever
Governor
Speed Control Plate
Starter
Water Pipe
Inlet Manifold
Inlet Manifold
Exhaust Manifold
Air Cleaner
Muffler
Accel Lever
Fuel Piping
Battery
Timer And Horn
Switch And Meter
Light
Electrical Wiring
Pump Housing
Rotary Joint
Oil Tank
Control Valve
Spool Section (S-P)
Spool Section (Arm)
Change Valve
Tpss Valve
Tpss Lever
Control Lever (S-P)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (S-P)
Swing Bracket
Boom
Arm
Bucket Link
Blade
Track Frame
Idler
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Cover (Lh)
Cover (Rh)
Bonnet Lh
Bonnet Rh
Bonnet Rear
Sponge 1
Sponge 2
Weight
Canopy
Cabin (Body)
Cabin (Door)
Cabin (Door Lock)
Cabin (Window)
Cabin (Seal Rubber)
Cabin (Wiper Motor)
Cabin (Heater)
Cabin (Defroster)
Label
