Kubota Excavators S Series KX41-2 Parts Manual
Type of Machine: Excavators
Model: Kubota S Series KX41-2 Excavators
Number of Pages: 286 Pages
Instructions For Parts Books
All Product Index
Crankcase
Oil Pan
Piston,Crankshaft
Main Bearing Case
Camshaft
Valve And Rocker Arm
Head Cover
Gear Case
Nozzle Holder,Glow Plug
Nozzle Holder [Component Parts]
Speed Control Plate
Stop Solenoid
Governor
Fuel Camshaft
Water Flange
Flywheel,Starter
Starter [Component Parts]
Alternator [Component Parts]
Engine Bracket
Air Cleaner,Inlet Manifold
Muffler,Exhaust Manifold
Accel Lever
Fuel Piping
Fuel Filter [Component Parts]
Water Pipe
Battery
Timer,Horn
Switch,Meter
Light
Electrical Wiring
Pump Housing
Grar Pump And Component Parts
Hydraulic Pump And Component Parts
Drive Motor And Component Parts (1)
Drive Motor And Component Parts (2)
Swivel Motor And Component Parts
Rotary Joint
Rotary Joint [Kx41-2v]
Oil Tank
Control Valve
Control Valve [Kx41-2v]
Control Valve [Component Parts]
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Travl Rh)
Spool Section (Travel Straight)
Spool Section (S-P)
Spool Section (Travel Lh)
Spool Section (Arm)
Spool Section (Spacer-Swing)
Spool Section (Blade)
Spool Section (Swivel)
Unloader Valve
Unloader Valve [Component Parts]
Tpss Valve
Tpss Valve [Component Parts]
Change Valve [Kx41-2v]
Change Valve [Component Parts] [Kx41-2v]
Control Lever (Frame)
Control Lever (Lever Lh)
Control Lever (Lever Rh)
Pilot Valve [Component Parts]
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel-Swing Change)
Control Lever (Tpss)
Control Lever (Blade)
Control Lever (S-P 1)
Control Lever (S-P 2)
Oil Piping (Suction,Delivery)
Oil Piping (Oil Return)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Lh) [Kx41-2v]
Oil Piping (Travel Rh)
Oil Piping (Travel Rh) [Kx41-2v]
Oil Piping (Swivel 1)
Oil Piping (Swivel 2)
Oil Piping (Swing)
Oil Piping (Look)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Blade)
Oil Piping (Blade) [Kx41-2v]
Oil Piping (Track) [Kx41-2v]
Oil Piping (Clamp)
Oil Piping (S-P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Blade Cylinder And Component Parts [Kx41-2v]
Swing Cylinder And Component Parts
Track Cylinder And Component Parts [Kx41-2v]
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Blade [Kx41-2v]
Track Frame
Track Frame [Kx41-2v]
Idler
Idler [Kx41-2v]
Track Roller
Track Roller [Kx41-2v]
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Step
Cover (Left)
Bonnet
Sponge (1)
Sponge (2)
Weight
Canopy
Instrument Panel
Label
Weight Kit [Option]
Label Kit [Option]
