702,019
Kubota Excavators KH61H Parts Manual
Type of Machine: Excavators
Model: Kubota KH61H Excavators
Number of Pages: 217 Pages
Instructions For Parts Books
All Product Index
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Nozzle Holder Glow Plug
Nozzle Holder (Component Parts)
Speed Control Plate
Governor
Injection Pump Camshaft (1)
Injection Pump Camshaft (2)
Injection Pump (Component Parts)
Water Flange
Fly Wheel Starter
Starter (Component Parts)
Dynamo
Dynamo (Component Parts)
Engine Bracket
Air Cleaner Inlet Manifold
Muffler Exhaust Manifold
Accel Lever
Fuel Piping
Water Pipe
Battery
Regulator Horn
Switch Meter Except [Kdg Ke-(S)]
Electrical Wiring
Pump Housing
Gear Pump & Component Parts
Drive Motor & Component Parts
Swivle Motor & Component Parts
Rotary Joint
Oil Tank
Control Valve (1) & Component Parts
Control Valve (1) Spool Section
Control Valve (1) (S-P) & Component Parts
Control Valve (1) (S-P) Spool Section
Control Valve (2) & Component Parts
Control Valve (2) Spool Section
Control Lever (Frame)
Control Lever (Travel Lh-1)
Control Lever (Travel Lh-2)
Control Lever (Travel Rh-1)
Control Lever (Travel Rh-2)
Control Lever (Front Lh)
Control Lever (Front Rh)
Control Lever (Safety Lock Lever)
Control Pedal (Swivel-Swing Change)
Control Lever (Dozer)
Control Lever (H Pattern) [Ktc]
Control Lever (S-P)
Oil Piping (1) (Oil Tank) Except [Exp. Kuk]
Oil Piping (2) (Suction & Delivery)
Oil Piping (3) (Return C-V Tank)
Oil Piping (4) (Travel Lh)
Oil Piping (5) (Travel Rh)
Oil Piping (6) (Swivel)
Oil Piping (7) (Swing)
Oil Piping (8) (Boom)
Oil Piping (9) (Arm)
Oil Piping (10) (Bucket)
Oil Piping (11) (Dozer)
Oil Piping (12) (S-P)
Boom Cylinder & Component Parts
Arm Cylinder & Component Parts
Bucket Cylinder & Component Parts [Kh-61(H)]
Dozer Cylinder & Component Parts
Swing Cylinder & Component Parts
Swing Bracket
Boom [Kh-61(H)]
Cylinder Cover (Boom)
Arm [Kh-61(H)]
Bucket Link [Kh-61(H)]
Bucket [Kh-61(H)]
Dozer
Track Frame [Kh-61(H)]
Drive Gear
Drive Gear Case
Idler
Track Roller [Kh-61(H)]
Crawler
Swivel Frame Except [Kta(Rops) Ktc]
Swivel Frame [Kta(Rops) Ktc]
Swivel Gear Case
Swivel Gear
Swivel Bearing
Floor Plate
Bonnet
Bonnet Sponge Except [Kta(Rops) Ktc]
Bonnet Sponge [Kta(Rops) Ktc]
Weight [Kh-61(H)]
Canopy [Exp. Kuk Ke Kdg S. Kta]
Rops Fops [Kta(Rops) Ktc]
Instrument Panel
Seat [Exp. Kuk S. Kta P. Ktc]
Light
Label Except [Kdg Ke-(S)]
