Kubota Excavators KH41 Parts Manual
Type of Machine: Excavators
Model: Kubota KH41 Excavators
Number of Pages: 213 Pages
Instructions For Parts Books
All Product Index
Crankcase [D950-Bh-1(-Sw)]
Oil Pan [D950-Bh-1(-Sw)]
Piston, Crankshaft [D950-Bh-1(-Sw)]
Main Bearing Case [D950-Bh-1(-Sw)]
Camshaft [D950-Bh-1(-Sw)]
Cylinder Head [D950-Bh-1(-Sw)]
Valve, Rocker Arm [D950-Bh-1(-Sw)]
Cylinder Head Cover [D950-Bh-1(-Sw)]
Gear Case [D950-Bh-1(-Sw)]
Pump Base [D950-Bh-1(-Sw)]
Nozzle Holder, Glow Plug [D950-Bh-1(-Sw)]
Nozzle Holder (Component Parts)
Speed Control Plate
Governor
Injection Pump, Camshaft (1) [D950-Bh-1(-Sw)]
Injection Pump, Camshaft (2) [D950-Bh-1(-Sw)]
Injection Pump (Component Parts) [D950-Bh-1(-Sw)]
Water Flange
Flywheel,Starter [D950-Bh-1(-Sw)]
Starter (Component Parts)
Dynamo
Dynamo (Component Parts)
Engine Bracket [Kh-41(H)]
Muffler, Exhaust Manifold [Kh-41(H)] Except [Swe] Include [Swe-Std]
Accel Lever
Fuel Piping
Radiator [Kh-41(H)]
Water Pipe [Kh-41(H)]
Battery
Regulator, Horn
Switch, Meter Except [Swe]
Electrical Wiring
Pump Housing [Kh-41(H)]
Gear Pump (1) & Component Parts
Gear Pump (2) & Component Parts [Kh-41(H)]
Drive Motor & Component Parts Except [Swe]
Swivel Motor & Component Parts Except [Swe]
Rotary Joint
Oil Tank (1)
Oil Tank (2)
Control Valve (3)(S-P) & Component Parts [Kh-41(H)]
Control Valve (3)(S-P) Spool Section [Kh-41(H)]
Control Lever (Travel Lh-1) Except [Exp.2]
Control Lever (Safety Lock Lever) Except [Exp.2]
Control Pedal (Swivel-Swing Change 1)
Control Lever (Frame) [Kh-41(H)] Except [Exp.2]
Control Lever (Travel Lh-2) [Kh-41(H)] Except [Exp.2]
Control Lever (Travel Rh-1) [Kh-41(H)]
Control Lever (Travel Rh-2) [Kh-41(H)]
Control Lever (Front Lh) [Kh-41(H)]
Control Lever (Front Rh) [Kh-41(H)]
Control Pedal (Swivel-Swing Change 2) [Kh-41(H)]
Control Lever (Dozer) [Kh-41(H)]
Control Lever (H Patern) [Ktc Kcl]
Control Lever (S-P) [Kh-41(H)]
Oil Piping (Oil Tank) [Ke (Ke-A) Ke-(S) Kdg Kta P. Ktc Kcl]
Oil Piping (Suction) [Kh-41(H)]
Oil Piping (Return C-V Tank) Except [Swe]
Oil Piping (Travel Lh)
Oil Piping (Travel Rh) [Kh-41(H)]
Oil Piping (Swivel) [Kh-41(H)] Except [Swe]
Oil Piping (Swing)
Oil Piping (Boom) [Kh-41(H)]
Oil Piping (Arm) [Kh-41(H)]
Oil Piping (Bucket)
Oil Piping (Dozer)
Oil Piping (S-P) [Kh-41(H)]
Boom Cylinder & Component Parts Except [Swe]
Arm Cylinder & Component Parts
Bucket Cylinder & Component Parts
Dozer Cylinder & Component Parts
Swing Cylinder & Component Parts
Swing Bracket Except [Swe]
Boom [Kh-41(H)]
Cylinder Cover (Boom) Except [Swe]
Arm
Bucket Link
Bucket
Dozer
Track Frame Except [Kdg Swe]
Drive Gear
Drive Gear Case
Idler
Track Roller
Crawler
Swivel Frame [Kta (Rops) Ktc Kcl]
Swivel Gear Case
Swivel Gear [Kh-41(H)]
Swivel Bearing
Floor Plate
Bonnet [Exp. Kuk Kta Ktc Kcl]
Sponge [Kta (Rops) Ktc Kcl]
Weight [Kh-41(H)] Except [Kdg Swe]
Rops Fops [Kta (Rops) Ktc Kcl]
Instrument,Panel Except [Swe]
Seat [Exp.Kuk Kta Nor P. Ktc Kcl]
Water Pipe [Canopy Type Ke (Ke-A) Ke-(S) Kdg S. Ktc Kcl]
Light
Label Except [(Ke-A) Ke-(S) Kdg Swe]
All Product Index
Speed Control Plate
Governor
Water Flange
Dynamo
Accel Lever
Fuel Piping
Radiator [Kh-41(H)]
Battery
Regulator, Horn
Electrical Wiring
Rotary Joint
Oil Tank (1)
Oil Tank (2)
Oil Piping (Swing)
Oil Piping (Bucket)
Oil Piping (Dozer)
Boom [Kh-41(H)]
Arm
Bucket Link
Bucket
Dozer
Drive Gear
Drive Gear Case
Idler
Track Roller
Crawler
Swivel Gear Case
Swivel Bearing
Floor Plate
Light
