Kubota Excavators KH-191 Parts Manual
Type of Machine: Excavators
Model: Kubota KH-191 Excavators
Number of Pages: 391 Pages
Instructions For Parts Books
Kh-191
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Cylinder Head Cover Except [Swe]
Gear Case
Gear Case
Engine Stop Lever
Engine Bracket
Nozzle Holder Glow Plug
Nozzle Holder (Component Parts)
Speed Control Plate
Governor
Injection Pump Camshaft (1)
Injection Pump (Component Parts)
Injection Pump Camshaft (2)
Water Flange
Flywheel Starter
Starter (Component Parts)
Dynamo
Dynamo (Component Parts)
Air Cleaner Inlet Manifold
Muffler Exhaust Manifold Except [Swe]
Accel Lever Except [H.R.C.]
Accel Lever [H.R.C.]
Fuel Piping
Water Pipe Except [Swe]
Battery
Regulator Horn [Except H.R.C.]
Regulator Horn [H.R.C.]
Switch Meter [Except H.R.C.]
Switch Meter [H.R.C.]
Electrical Wiring [Except H.R.C.]
Electrical Wiring [H.R.C.]
Pump Housing
Gear Pump (1) & Component Parts
Gear Pump (2) & Component Parts
Drive Motor & Component Parts
Swivel Motor & Component Parts
Rotary Joint [Ktc Kcl]
Oil Tank
Control Valve (1) & Component Parts Except [Uae]
Control Valve (1) Spool Section (1)
Control Valve (1) Spool Section (2)
Control Valve (2) & Component Parts [Ktc Kcl]
Control Valve (2) Spool Section (1) [Ktc Kcl]
Control Valve (2) Spool Section (2) [Ktc Kcl]
Control Lever (Frame) [Ktc Kcl]
Control Lever (Lever Lh-1)
Control Lever (Lever Lh-2) [Ktc Kcl]
Control Lever (Lever Rh-1) [Ktc Kcl]
Control Lever (Lever Rh-2) [Ktc Kcl]
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal Except [Uae]
Control Lever (Safety Lock Lever)
Control Pedal (Swivel-Swing Change) [Ktc Kcl]
Control Lever (Dozer) (1) [Ktc Kcl]
Control Lever (Dozer) (2) [Ktc Kcl]
Control Lever (H Patern) [Ktc Kcl]
Control Lever (S-P) Except [Uae]
Oil Piping (Oil Tank) Except [Exp. Kuk Uae]
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return C-V Tank)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Dozer) [Ktc Kcl]
Oil Piping (Tilt Dozer) [Ktc]
Oil Piping (Confluence) [Ktc Kcl]
Oil Piping (S-P) [Ktc Kcl]
Boom Cylinder & Conponent Parts
Arm Cylinder & Component Parts
Bucket Cylinder & Component Parts
Dozer Cylinder & Component Parts
Dozer Cylinder & Component Parts (Tilt) [Ktc]
Tilt Cylinder [Ktc]
Swing Cylinder & Component Parts
Pump Housing
Hydraulic Pump & Component Parts
Drive Motor & Component Parts Except [Swe]
Swivel Motor & Component Parts Except [Swe]
Oil Tank
Control Valve (2) Spool Section (3) [Ktc Kcl]
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Lever Rh)
Control Lever (S-P)
Oil Piping (Oil Tank) Except [Kuk Swe]
Oil Piping (Delivery) Except [Swe]
Oil Piping (Return C-V Tank) Except [Swe]
Oil Piping (Travel Lh) Except [Swe]
Oil Piping (Travel Rh) Except [Swe]
Oil Piping (Swivel)
Oil Piping (Swivel) Except [Swe]
Oil Piping (Swing)
Oil Piping (Lock)
Unload Valve (Component Parts)
Oil Piping (Boom 1) (H Pattern) [Ktc Kcl]
Oil Piping (Boom 2)
Oil Piping (Arm 1) (H Pattern) [Ktc Kcl]
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Boom Cylinder & Conponent Parts Except [Swe]
Tilt Cylinder [Ktc]
Swing Cylinder & Component Parts Except [Ke. S. Ke-S Ke-A]
Swing Bracket Except [Ke-H.R.C. S. Ke-S Ke-A Swe]
Boom
Arm
Bucket Link
Bucket
Dozer
Dozer (Tilt) [Ktc]
Truck Frame
Drive Gear
Drive Gear Case
Idler
Truck Roller
Crawler (Bolt Type) Except [Exp.]
Swivel Frame [Kta(Rops) Ktc Kcl]
Swivel Gear Case
Swivel Gear
Swivel Bearing
Floor Plate (1) Except [Uae]
Floor Plate (2) [Except H.R.C.]
Floor Plate (2) [H.R.C]
Hood Except [Swe]
Hood Sponge (1)
Hood Sponge (2)
Hood Sponge (3) Except [Swe]
Hood Sponge (4)
Heat Insulator [H.R.C.] [Ktc Kcl]
Weight
Rops Fops [Ktc]
Cabin (Body) [Kta(Rops) Ktc Kcl]
Cabin (Door) [Kta(Rops) Ktc Kcl]
Cabin (Front Door) [Kta(Rops) Ktc Kcl]
Cabin (Sponge) [Kta(Rops) Ktc Kcl]
Instrument Panel [Except H.R.C.] [Ktc Kcl]
Instrument Panel [H.R.C.] [Ktc Kcl]
Seat [Exp. Kuk Kta S. Ktc Kcl Uae]
Wiring Harness (Cabin)
Cabin (Wiper Motor)
Cabin (Heater)
Light
Label [Exp. Kuk Ke Kta S. Ktc Kcl Uae]
