Kubota Excavator U56-5 Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota U56-5 Excavator
Number of Pages: 455 Pages
U56-5
U56-5 Frequently Used Items Frequently Used Items Frequently Used Items Frequently
U56-5 Motor Engine Kurbelghaeuse Crankcase
U56-5 Motor Engine Oelwanne Oil Pan
U56-5 Motor Engine Oelmessstab Und Fuehrung Dipstick And Guide
U56-5 Motor Engine Zylinderkopf Cylinder Head
U56-5 Motor Engine Einlassventil Und Auslassventil Inlet Valve And Exhaust Valve
U56-5 Motor Engine Kippenarmwelle Rocker Arm Shaft
U56-5 Motor Engine Deckel Oben Head Cover
U56-5 Motor Engine Vorderdeckel Front Cover
U56-5 Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
U56-5 Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle Gear
U56-5 Motor Engine Schwungrad Flywheel
U56-5 Motor Engine Versorgungsmaterial-Pumpe Supply Pump
U56-5 Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow Plug
U56-5 Motor Engine Einspritzung-Rohr Injection Pipe
U56-5 Motor Engine Allgemeine Schiene Common Rail
U56-5 Motor Engine Lichtmaschine Alternator
U56-5 Motor Engine Lichtmaschine (Einzel-Teil) Alternator (Component Parts)
U56-5 Motor Engine Anlasser Starter
U56-5 Motor Engine Anlasser (Einzel-Teil) Starter (Component Parts)
U56-5 Motor Engine Oelschalter Thermometer Oil Switch Thermometer
U56-5 Motor Engine Wasserflansch Und Thermostat Water Flange And Thermostat
U56-5 Motor Engine Wasserpumpe Water Pump
U56-5 Motor Engine Wasserrohr (Carrosserie) Water Pipe (Body)
U56-5 Motor Engine Kuehler Radiator
U56-5 Motor Engine Ausgleichbehaelter Reserve Tank
U56-5 Motor Engine Ventilator Cooler Fan
U56-5 Motor Engine Einlasskruemmer Inlet Manifold
U56-5 Motor Engine Luftfilter-Flansch Und Drossel-Ventil Air Cleaner Flange And Throttle
U56-5 Motor Engine Auspuffrummer Exhaust Manifold
U56-5 Motor Engine Egr Ventil Egr Valve
U56-5 Motor Engine Luftfilter Air Cleaner
U56-5 Motor Engine Dieselpartikelfilter Auspuffdämpfer Diesel Particulate Filter
U56-5 Motor Engine Abblasdampfer-Sensor Diesel Particulate Filter Muffler Sensor
Motor Engine Differenzdruckleitung Des Dieselpartikelfilters Diesel Particulate Filter
U56-5 Motor Engine Kabelgeschirr Halter Wire Harness Bracket
U56-5 Motor Engine Schalldämpferrohr Des Dieselpartikelfilters Diesel Particulate Filter
5 Motor Engine Schalldämpferabdeckung Des Dieselpartikelfilters Diesel Particulate
U56-5 Motor Engine Ölabscheider Oil Separator
U56-5 Motor Engine Oelkuehler Oil Cooler
U56-5 Motor Engine Motor Traeger Engine Bracket
U56-5 Motor Engine Dichtungssatz (Oben) [Option] Upper Gasket Kit [Option]
U56-5 Motor Engine Dichtungssatz (Unten) [Option] Lower Gasket Kit [Option]
U56-5 Brennstoff System Fuel System Kraftstoffleitungen (1) Fuel Pump And Piping
U56-5 Brennstoff System Fuel System Kraftstoffleitungen (2) Fuel Pump And Piping
U56-5 Brennstoff System Fuel System Wasserabscheider (Einzel-Teil) Separator (Component
U56-5 Brennstoff System Fuel System Kraftstofftank Fuel Tank
U56-5 Elektrisch System Electrical System Batterie Battery
U56-5 Elektrisch System Electrical System Hupe Horn
U56-5 Elektrisch System Electrical System Schalter, Zaehler Switch And Meter
U56-5 Elektrisch System Electrical System Lampe Light
U56-5 Elektrisch System Electrical System Kabelgeschirr Wire Harness
U56-5 Elektrisch System Electrical System Diebstahlwarnanlage Anti-Theft Alarm
U56-5 Pumpe Motor System Pump Motor System Pumpengehaeuse Housing Pump
U56-5 Pumpe Motor System Pump Motor System Kolbenpumpe Piston Pump
U56-5 Pumpe Motor System Pump Motor System Kolbenpumpe (Einzel-Teil) Piston Pump (
U56-5 Pumpe Motor System Pump Motor System Motor Drive Moter
U56-5 Pumpe Motor System Pump Motor System Fahrmotor (Einzel-Teile) Drive Motor (
U56-5 Pumpe Motor System Pump Motor System Schwingungmotor Swivel Motor
5 Pumpe Motor System Pump Motor System Schwingungmotor (Einzel-Teil) Swivel Motor (
U56-5 Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary Joint
5 Pumpe Motor System Pump Motor System Drehgelenkstueck (Einzel-Teil) Rotary Joint (
U56-5 Pumpe Motor System Pump Motor System Oeltank (1) Oil Tank (1)
U56-5 Pumpe Motor System Pump Motor System Oeltank (2) Oil Tank (2)
U56-5 Pumpe Motor System Pump Motor System Ölfilter Oil Filter
U56-5 Regelungsventil Control Valve Regelungsventil (1) Control Valve (1)
U56-5 Regelungsventil Control Valve Regelungsventil (2) Control Valve (2)
U56-5 Regelungsventil Control Valve Regelungsventil (3) Control Valve (3)
U56-5 Regelungsventil Control Valve Kontrollventil (Einzel-Teil) Control Valve (Component
U56-5 Regelungsventil Control Valve Spulensektion (Ausfluss) Section (Outlet)
U56-5 Regelungsventil Control Valve Spulensektion (Ax1) Section (Ax1)
U56-5 Regelungsventil Control Valve Spulensektion (Drehen) Section (Swivel)
U56-5 Regelungsventil Control Valve Spulensektion (Loeffel) Section (Bucket)
U56-5 Regelungsventil Control Valve Spulensektion (Arm) Section (Arm)
U56-5 Regelungsventil Control Valve Spulensektion (Ausleger) Section (Boom)
U56-5 Regelungsventil Control Valve Spulensektion (Fahren) Section (Travel
U56-5 Regelungsventil Control Valve Spulensektion (Fahren Rs) Section (Travel
U56-5 Regelungsventil Control Valve Spulensektion (Fahren Ls) Section (Travel
U56-5 Regelungsventil Control Valve Spulensektion (Blei) Section (Lead)
U56-5 Regelungsventil Control Valve Spulensektion (Schwung) Section (Swing)
U56-5 Regelungsventil Control Valve Spulensektion (Planierschild) Section (Blade)
U56-5 Regelungsventil Control Valve Spulensektion (Ax2) Section (Ax2)
U56-5 Regelungsventil Control Valve Entladerventil Unload Valve
U56-5 Regelungsventil Control Valve Entladerventil (Einzel-Teil) Unload Valve (Component
U56-5 Regelungsventil Control Valve S P Solenoidventil S P Solenoid Valve ## [Aux1]
U56-5 Regelungsventil Control Valve S P Solenoidventil S P Solenoid Valve ## [Aux1&2]
U56-5 Regelungsventil Control Valve Zylinderspulenventil (A2) Solenoid Valve (
Regelungsventil Control Valve Zylinderspulenventil (A2) (Einzel-Teil) Solenoid Valve (A2)
U56-5 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Ls) Control Lever (Lever
Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Lh) (Component
Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Lh) (Component Parts)
U56-5 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Rs) Control Lever (Lever
U56-5 Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Rh) (Component
U56-5 Kontrollrahmen Control Lever Kontrollrahmen (Fahren Ls) Control Lever (
U56-5 Kontrollrahmen Control Lever Vordusenventil(Fahren) Pilot Valve (Travel)
Kontrollrahmen Control Lever Vordusenventil (Fahren) (Enzel-Teil) Pilot Valve (Travel) (
U56-5 Kontrollrahmen Control Lever Schwungpedal Swing Pedal
U56-5 Kontrollrahmen Control Lever Vordusenventil(Schwung) Pilot Valve (Swing)
Kontrollrahmen Control Lever Vordusenventil (Schwung) (Enzel-Teil) Pilot Valve (Swing)
5 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Von Schloss) Control Lever (
U56-5 Kontrollrahmen Control Lever Kontrollrahmen (Erdschieber) Control Lever
U56-5 Kontrollrahmen Control Lever Vordusenventil (Erdschieber) Pilot Valve (
Kontrollrahmen Control Lever Vordusenventil (Erdschieber) (Einzel-Teil) Pilot Valve (Blade)
U56-5 Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (Suction)
U56-5 Oelleitungen Oil Piping Oel Leitung (Befreitung) Oil Piping (Delivery)
U56-5 Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return)
U56-5 Oelleitungen Oil Piping Oel Leitung (Oelkuehler) Oil Piping (Oil Cooler)
U56-5 Oelleitungen Oil Piping Oel Leitung (Kontroll Ls) Oil Piping (Control Lh)
U56-5 Oelleitungen Oil Piping Oel Leitung (Kontroll Rs) Oil Piping (Control Rh)
U56-5 Oelleitungen Oil Piping Oel Leitung (Pilot P) Oil Piping (Pilot P)
U56-5 Oelleitungen Oil Piping Oel Leitung (Pilot T) Oil Piping (Pilot T)
U56-5 Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel Lh)
U56-5 Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel Rh)
U56-5 Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
U56-5 Oelleitungen Oil Piping Oel Leitung (Schwung) Oil Piping (Swing)
U56-5 Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
5 Oelleitungen Oil Piping Enthuelsungventil(Ausleger) (Einzel-Teil) Holding Valve (Boom) (
U56-5 Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
U56-5 Oelleitungen Oil Piping Enthuelsungventil(Arm) (Einzel-Teil) Holding Valve (Arm) (
U56-5 Oelleitungen Oil Piping Oel Leitung (Kuebel) Oil Piping (Bucket)
U56-5 Oelleitungen Oil Piping Oel Leitung (Erdschieber) Oil Piping (Blade)
U56-5 Oelleitungen Oil Piping Oel Leitung (Hubmagnet) Oil Piping (Solenoid)
U56-5 Oelleitungen Oil Piping Oel Leitung (Klammer) Oil Piping (Clamp)
U56-5 Oelleitungen Oil Piping Oel Leitung (S P1) Oil Piping (S P1) ## [Aux1] [Aux1]
U56-5 Oelleitungen Oil Piping Oel Leitung (S P1) Oil Piping (S P1) ## [Aux1&2] [Aux1&
U56-5 Oelleitungen Oil Piping Oel Leitung (S P2) Oil Piping (S P2) ## [Aux1&2] [Aux1&
Oelleitungen Oil Piping Oel Leitung (Dritte Ruecklaufleitung) Oil Piping (Third Line Hydraulic
U56-5 Zylinder Cylinder Auslegerzylinder Boom Cylinder
U56-5 Zylinder Cylinder Armzylinder Arm Cylinder
U56-5 Zylinder Cylinder Kuebelzylinder Bucket Cylinder
U56-5 Zylinder Cylinder Erdschieberzylinder Blade Cylinder
U56-5 Zylinder Cylinder Schwenkzylinder Swing Cylinder
U56-5 Anhaften Von Stirn Front Attachments Lagerung Ausleger Swing Bracket
U56-5 Anhaften Von Stirn Front Attachments Ausleger Boom
U56-5 Anhaften Von Stirn Front Attachments Abdeckung (Ausleger) Cylinder Cover
U56-5 Anhaften Von Stirn Front Attachments Arm Arm
U56-5 Anhaften Von Stirn Front Attachments Kuebelverbindungestueck Bucket
U56-5 Anhaften Von Stirn Front Attachments Erdschieber Blade
U56-5 Spurrahmen Track Frame Spurrahmen Track Frame
U56-5 Spurrahmen Track Frame Spannrad Idler
U56-5 Spurrahmen Track Frame Laufrollen Track Roller
U56-5 Spurrahmen Track Frame Laufketten Crawler
U56-5 Rahmen Von Drehen Swivel Frame Rahmen Von Drehen Swivel Frame
U56-5 Rahmen Von Drehen Swivel Frame Bogenrahmen (1) Arch Frame (1) ## [Except A C] [
U56-5 Rahmen Von Drehen Swivel Frame Bogenrahmen (1) Arch Frame (1) ## [A C] [A
U56-5 Rahmen Von Drehen Swivel Frame Bogenrahmen (2) Arch Frame (2)
U56-5 Rahmen Von Drehen Swivel Frame Lager, Drehen Swivel Bearing
U56-5 Rahmen Von Drehen Swivel Frame Sitz Traeger Seat Support
U56-5 Rahmen Von Drehen Swivel Frame Tritt Step
U56-5 Aubere Bauteile Polsterung External Upholstery Deckel (Ls) Cover (Lh)
U56-5 Aubere Bauteile Polsterung External Upholstery Deckel (Rs) Cover (Rh)
U56-5 Aubere Bauteile Polsterung External Upholstery Motorhaube (Rs1) Bonnet (
U56-5 Aubere Bauteile Polsterung External Upholstery Motorhaube (Rs2) Bonnet (
U56-5 Aubere Bauteile Polsterung External Upholstery Motorhaube (Hinter1) Bonnet
U56-5 Aubere Bauteile Polsterung External Upholstery Motorhaube (Hinter2) Bonnet
U56-5 Aubere Bauteile Polsterung External Upholstery Motorhaube (Zentrum) Bonnet
U56-5 Aubere Bauteile Polsterung External Upholstery Schaumgummi (1) Sponge
U56-5 Aubere Bauteile Polsterung External Upholstery Schaumgummi (2) Sponge
U56-5 Aubere Bauteile Polsterung External Upholstery Schaumgummi (3) Sponge
U56-5 Aubere Bauteile Polsterung External Upholstery Gewicht Weight
U56-5 Aubere Bauteile Polsterung External Upholstery Sitz Seat
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Koerper) Cabin (Body)
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Tuer) Cabin (Door)
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Fenster) Cabin (Window)
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Deckel Und Trimm) Cabin (Cover
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Futter) Cabin (Lining)
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Gummiabdichtung) Cabin (Seal
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Rueckspiegel) Cabin (Rearview
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Scheibenwischermotor) Cabin (Wiper
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Kabelgeschirr) Cabin (Wire
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Heizkoerper) Cabin (Heater)
Fahrer Operator's Platform Kabine (Heizkoerper) (Einzel-Teil) Cabin (Heater) (Component
Buhne Von Fahrer Operator's Platform Kabine (Heizkoerper) (Einzel-Teil) Cabin (Heater) (
U56-5 Buhne Von Fahrer Operator's Platform Kabine (Klimaanlage) Cabin (Air Conditioner
U56-5 Aufkleber Labels Aufkleber Label
U56-5 Sontiges Zubehoer Accessories Sontiges Zubehoer Accessories
