Kubota Excavator U55-4 Illustrated Parts List 97899-10980
Type of Machine: Excavator
Model: Kubota U55-4 Excavator
Part Number: 97899-10980
Publication Date: 2010
Number of Pages: 266 Pages
COVER 1
COVER 2
INSTRUCTIONS
ENGLISH
FRENCH
GERMAN
SERIAL NUMBER
NUMERO DE SERIE
SERIENNUMMER
SECTION CONTENTS
CONTENUS DE LA SECTION
ABSCHNITTSINHALT
How to read contents with illustrations
Comment lire les contenus avec les illustrations
Lesens des Inhalts der Abbildungen
ENGINE
FUEL SYSTEM
ELECTRICAL SYSTEM
PUMP/MOTOR SYSTEM
CONTROL VALVE
CONTROL LEVER
OIL PIPING
CYLINDER
FRONT ATTACHMENTS
TRACK FRAME
SWIVEL FRAME
EXTERNAL/UPHOLSTERY
CABIN
LABELS
ACCESSORIES
ALPHABETICAL INDEX
ALPHABETICAL INDEX
ALPHABETICAL INDEX
ALPHABETICAL INDEX
ALPHABETICAL INDEX
INDEX ALPHABETIQUE
INDEX ALPHABETIQUE
INDEX ALPHABETIQUE
INDEX ALPHABETIQUE
ALPHABETISCH INDEX
ALPHABETISCH INDEX
ALPHABETISCH INDEX
ALPHABETISCH INDEX
500000 CRANK CASE
501000 OIL PAN
501200 DIPSTICK AND GUIDE
502000 CYLINDER HEAD
503000 INLET VALVE AND EXHAUST VALVE
504000 ROCKER ARM SHAFT
505000 HEAD COVER
510000 FRONT COVER
511000 PISTON AND CRANKSHAFT
512000 CAMSHAFT AND IDLE GEAR SHAFT
515000 FLYWHEEL
520000 INJECTION PUMP UNIT
520200 INJECTION PUMP HOUSING
521000 INJECTION PUMP
522000 FUEL CAMSHAFT
523000 GOVERNOR
524000 FORK LEVER (GOVERNOR)
525000 RESTRICTION ADJUSTING BOLT
531000 FUEL PIPING
540000 NOZZLE HOLDER AND GLOW PLUG
545000 INJECTION PIPE
550000 ALTERNATOR
551000 ALTERNATOR (COMPONENT PARTS)
554000 STARTER
555000 STARTER (COMPONENT PARTS)
555500 STOP SOLENOID
556000 OIL SWITCH/THERMOMETER
560000 WATER FLANGE AND THERMOSTAT
561000 WATER PUMP
561500 WATER PIPE (BODY)
565000 RADIATOR
565500 RESERVE TANK
567000 FAN
571000 INLET MANIFOLD
572000 EXHAUST MANIFOLD
573000 AIR CLEANER
575000 MUFFLER
582000 OIL COOLER
586000 ENGINE BRACKET
591000 UPPER GASKET KIT
592000 LOWER GASKET KIT
A20100 AUTO IDLE MOTOR
A30000 FUEL PUMP AND PIPING
A30100 FUEL FILTER (COMPONENT PARTS)
A30200 WATER SEPARATOR (COMPONENT PARTS)
A30300 FUEL TANK
B40000 BATTERY
B40200 HORN
B40400 SWITCH AND METER
B40600 LIGHT
B40801 ELECTRICAL WIRING
B40802 ELECTRICAL WIRING
B41000 ANTI-THEFT ALARM SYSTEM
C00000 PUMP HOUSING
C20000 PISTON PUMP
C20100 PISTON PUMP (COMPONENT PARTS)
C30000 DRIVE MOTOR
C30101 DRIVE MOTER (COMPONENT PARTS)
C30102 DRIVE MOTER (COMPONENT PARTS)
C40000 SWIVEL MOTOR
C40101 SWIVEL MOTOR (COMPONENT PARTS)
C40102 SWIVEL MOTOR (COMPONENT PARTS)
C50000 ROTARY JOINT
C50000 ROTARY JOINT
C50100 ROTARY JOINT (COMPONENT PARTS)
C50200 OIL TANK (1)
C50200 OIL TANK (1)
C50300 OIL TANK (2)
C50400 OIL FILTER
C60001 CONTROL VALVE (1)
C60002 CONTROL VALVE (2)
C60003 CONTROL VALVE (3)
C60100 CONTROL VALVE (COMPONENT PARTS)
C60201 SPOOL SECTION (OUTLET)
C60202 SPOOL SECTION (AX1)
C60203 SPOOL SECTION (SWIVEL)
C60204 SPOOL SECTION (BUCKET)
C60205 SPOOL SECTION (ARM)
C60206 SPOOL SECTION (BOOM)
C60207 SPOOL SECTION (TRAVEL INDEPENDENCE)
C60208 SPOOL SECTION (TRAVEL RH)
C60209 SPOOL SECTION (TRAVEL LH)
C60210 SPOOL SECTION (LEAD)
C60211 SPOOL SECTION (SWING)
C60212 SPOOL SECTION (BLADE)
C60213 SPOOL SECTION (AX2)
C70600 UNLOAD VALVE
C70700 UNLOAD VALVE (COMPONENT PARTS)
C81001 S/P SOLENOID VALVE
C81002 S/P SOLENOID VALVE
D10000 CONTROL LEVER (LEVER LH)
D20000 CONTROL LEVER (LEVER RH)
D30000 CONTROL LEVER (TRAVEL)
D31000 PILOT VALVE (TRAVEL)
D31100 PILOT VALVE (TRAVEL) (COMPONENT PARTS)
D51000 SWING PEDAL
D52000 PILOT VALVE (SWING)
D52100 PILOT VALVE (SWING) (COMPONENT PARTS)
D60000 CONTROL LEVER (SAFETY LOCK LEVER)
D80000 CONTROL LEVER (BLADE)
D81000 PILOT VALVE (BLADE)
D81100 PILOT VALVE (BLADE) (COMPONENT PARTS)
E00000 OIL PIPING (SUCTION)
E00200 OIL PIPING (DELIVERY)
E00400 OIL PIPING (RETURN)
E00600 OIL PIPING (OIL COOLER)
E10000 OIL PIPING (CONTROL LH)
E10200 OIL PIPING (CONTROL RH)
E10600 OIL PIPING (PILOT P)
E10800 OIL PIPING (PILOT T)
E20000 OIL PIPING (TRAVEL LH)
E20200 OIL PIPING (TRAVEL RH)
E20400 OIL PIPING (SWIVEL)
E30000 OIL PIPING (SWING)
E30400 OIL PIPING (BOOM)
E30500 HOLDING VALVE (COMPONENT PARTS)
E40000 OIL PIPING (ARM)
E50000 OIL PIPING (BUCKET)
E60000 OIL PIPING (BLADE)
E70000 OIL PIPING (CLAMP)
E80000 OIL PIPING (S/P 1)
E80200 OIL PIPING (S/P 2)
E82000 OIL PIPING (THIRD LINE HYDRAULIC RETURN)
F00000 BOOM CYLINDER
F10000 ARM CYLINDER
F10000 ARM CYLINDER
F20000 BUCKET CYLINDER
F30000 BLADE CYLINDER
F40000 SWING CYLINDER
G00000 SWING BRACKET
G10000 BOOM
G10400 CYLINDER COVER (BOOM)
G20000 ARM
G30000 BUCKET LINK
G30000 BUCKET LINK
G50000 BLADE
H00000 TRACK FRAME
H10000 IDLER
H10000 IDLER
H20000 TRACK ROLLER
H30000 CRAWLER
J00001 SWIVEL FRAME (1)
J00002 SWIVEL FRAME (2)
J00101 ARCH FRAME (1)
J00102 ARCH FRAME (1)
J00200 ARCH FRAME (2)
J10000 SWIVEL BEARING
J20000 SEAT SUPPORT
J30000 STEP
K00000 COVER (LH)
K00100 COVER (RH)
K10100 BONNET (LH)
K10201 BONNET (RH 1)
K10202 BONNET (RH 2)
K10300 BONNET (REAR)
K10400 BONNET (CENTER)
K20000 SPONGE (1)
K20100 SPONGE (2)
K20200 SPONGE (3)
K30000 WEIGHT
K40000 SEAT
L10000 CABIN (BODY)
L20000 CABIN (DOOR)
L20000 CABIN (DOOR)
L30000 CABIN (WINDOW 1)
L30100 CABIN (WINDOW 2)
L40000 CABIN (SPONGE)
L40100 CABIN (LINING)
L40200 CABIN (SEAL RUBBER)
L42000 CABIN (REARVIEW MIRROR)
L50000 CABIN (WIPER MOTOR)
L50200 CABIN (ELECTRICAL WIRING)
L60000 CABIN (HEATER)
L60201 CABIN (AIR CONDITIONER 1)
L60202 CABIN (AIR CONDITIONER 1)
L60300 CABIN (AIR CONDITIONER 2)
L60400 CABIN (AIR CONDITIONER 3)
M00000 LABEL
M00000 LABEL
N00000 ACCESSORIES
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
COVER 3
COVER 4
COVER 1
COVER 2
INSTRUCTIONS
ENGLISH
FRENCH
GERMAN
SERIAL NUMBER
NUMERO DE SERIE
SERIENNUMMER
SECTION CONTENTS
ABSCHNITTSINHALT
ENGINE
FUEL SYSTEM
ELECTRICAL SYSTEM
PUMP/MOTOR SYSTEM
CONTROL VALVE
CONTROL LEVER
OIL PIPING
CYLINDER
FRONT ATTACHMENTS
TRACK FRAME
SWIVEL FRAME
EXTERNAL/UPHOLSTERY
CABIN
LABELS
ACCESSORIES
ALPHABETICAL INDEX
ALPHABETICAL INDEX
ALPHABETICAL INDEX
ALPHABETICAL INDEX
ALPHABETICAL INDEX
INDEX ALPHABETIQUE
INDEX ALPHABETIQUE
INDEX ALPHABETIQUE
INDEX ALPHABETIQUE
ALPHABETISCH INDEX
ALPHABETISCH INDEX
ALPHABETISCH INDEX
ALPHABETISCH INDEX
500000 CRANK CASE
501000 OIL PAN
505000 HEAD COVER
510000 FRONT COVER
515000 FLYWHEEL
523000 GOVERNOR
531000 FUEL PIPING
550000 ALTERNATOR
554000 STARTER
561000 WATER PUMP
565000 RADIATOR
565500 RESERVE TANK
567000 FAN
573000 AIR CLEANER
575000 MUFFLER
582000 OIL COOLER
A30300 FUEL TANK
B40000 BATTERY
B40200 HORN
B40600 LIGHT
C00000 PUMP HOUSING
C20000 PISTON PUMP
C30000 DRIVE MOTOR
C40000 SWIVEL MOTOR
C50000 ROTARY JOINT
C50000 ROTARY JOINT
C50200 OIL TANK (1)
C50200 OIL TANK (1)
C50300 OIL TANK (2)
C50400 OIL FILTER
C70600 UNLOAD VALVE
D51000 SWING PEDAL
F10000 ARM CYLINDER
F10000 ARM CYLINDER
G10000 BOOM
G20000 ARM
G30000 BUCKET LINK
G30000 BUCKET LINK
G50000 BLADE
H00000 TRACK FRAME
H10000 IDLER
H10000 IDLER
H20000 TRACK ROLLER
H30000 CRAWLER
J20000 SEAT SUPPORT
J30000 STEP
K00000 COVER (LH)
K00100 COVER (RH)
K10100 BONNET (LH)
K20000 SPONGE (1)
K20100 SPONGE (2)
K20200 SPONGE (3)
K30000 WEIGHT
K40000 SEAT
L10000 CABIN (BODY)
L20000 CABIN (DOOR)
L20000 CABIN (DOOR)
M00000 LABEL
M00000 LABEL
N00000 ACCESSORIES
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
NUMERICAL INDEX
COVER 3
COVER 4
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
