Kubota Excavator U55-4 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota U55-4 Excavator
Region: Australia
Number of Pages: 533 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Dipstick And Guide
Engine _ Cylinder Head ## Note _ Order By Ref No
Engine _ Inlet Valve And Exhaust Valve ## Note _ Order By Ref No
Engine _ Rocker Arm Shaft
Engine _ Head Cover
Engine _ Front Cover
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Injection Pump Unit
Engine _ Injection Pump Housing
Engine _ Fuel Camshaft
Engine _ Governor
Engine _ Fork Lever (Governor)
Engine _ Restriction Adjusting Bolt
Engine _ Fuel Piping
Engine _ Injection Pipe
Engine _ Alternator
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Stop Solenoid
Engine _ Oil Switch And Thermometer
Engine _ Water Pump
Engine _ Water Pipe (Body)
Engine _ Radiator
Engine _ Reserve Tank
Engine _ Fan
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler ## S.No._=21712 S.No.;_=21712
Engine _ Muffler ## S.No._=21713 S.No.;_=21713
Engine _ Oil Cooler
Engine _ Engine Bracket
Engine _ Upper Gasket Kit ## [Option]
Engine _ Lower Gasket Kit ## [Option]
Fuel System _ Auto Idle Motor
Fuel System _ Fuel Pump And Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Water Separator (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Travel Alarm
Electrical System _ Switch And Meter
Electrical System _ Light
Electrical System _ Anti-Theft Alarm System ## S.No._=22191 S.No.;_=22191
Electrical System _ Anti-Theft Alarm System ## S.No._=22192 S.No.;_=22192
Pump_Motor System _ Pump Housing
Pump_Motor System _ Piston Pump
Pump_Motor System _ Piston Pump (Component Parts)
Pump_Motor System _ Drive Motor
Pump_Motor System _ Drive Motor (Component Parts)
Pump_Motor System _ Swivel Motor
Pump_Motor System _ Swivel Motor (Component Parts) ## S.No._=20288 S.No.;_=20288
Pump_Motor System _ Swivel Motor (Component Parts) ## S.No._=20289 S.No.;_=20289
Pump_Motor System _ Rotary Joint ## [Except Angle Blade]
Pump_Motor System _ Rotary Joint ## [Angle Blade]
Pump_Motor System _ Rotary Joint (Component Parts) ## [Except Angle Blade]
Pump_Motor System _ Rotary Joint (Component Parts) ## [Angle Blade]
Pump_Motor System _ Oil Tank (1)
Pump_Motor System _ Oil Tank (2)
Pump_Motor System _ Oil Filter
Control Valve _ Control Valve (1)
Control Valve _ Control Valve (2)
Control Valve _ Control Valve (3)
Control Valve _ Control Valve (4) ## [Angle Blade]
Control Valve _ Control Valve (Component Parts) ## [Except Angle Blade]
Control Valve _ Control Valve (Component Parts) ## [Angle Blade]
Control Valve _ Spool Section (Outlet)
Control Valve _ Spool Section (Ax1)
Control Valve _ Spool Section (Swivel)
Control Valve _ Spool Section (Bucket)
Control Valve _ Spool Section (Arm)
Control Valve _ Spool Section (Boom)
Control Valve _ Spool Section (Travel)
Control Valve _ Spool Section (Travel Rh)
Control Valve _ Spool Section (Travel Lh)
Control Valve _ Spool Section (Lead)
Control Valve _ Spool Section (Swing)
Control Valve _ Spool Section (Blade)
Control Valve _ Spool Section (Ax2)
Control Valve _ Spool Section (Angle) ## [Angle Blade]
Control Valve _ Unload Valve ## S.No._=27288 S.No.;_=27288
Control Valve _ Unload Valve ## S.No._=27289 S.No.;_=27289
Control Valve _ Unload Valve (Component Parts)
Control Valve _ S_P Solenoid Valve
Control Valve _ Angle Change Valve ## [Angle Blade]
Control Valve _ TPSS Valve
Control Lever _ Control Lever (Lever Lh)
Control Lever _ Pilot Valve (Lh) (Component Parts)
Control Lever _ Control Lever (Lever Rh)
Control Lever _ Pilot Valve (Rh) (Component Parts)
Control Lever _ Control Lever (Travel)
Control Lever _ Pilot Valve (Travel)
Control Lever _ Pilot Valve (Travel) (Component Parts) ## Note_ Order By Part No.Rd451-9786-3 And Ref
Control Lever _ Swing Pedal
Control Lever _ Pilot Valve (Swing)
Control Lever _ Pilot Valve (Swing) (Component Parts)
Control Lever _ Control Lever (Safety Lock Lever)
Control Lever _ TPSS Lever
Control Lever _ Control Lever (Blade) ## [Except Angle Blade]
Control Lever _ Control Lever (Blade) ## [Angle Blade]
Control Lever _ Pilot Valve (Blade)
Control Lever _ Pilot Valve (Blade) (Component Parts)
Oil Piping _ Oil Piping (Suction)
Oil Piping _ Oil Piping (Delivery)
Oil Piping _ Oil Piping (Return)
Oil Piping _ Oil Piping (Oil Cooler) ## S.No._=28182 S.No.;_=28182
Oil Piping _ Oil Piping (Oil Cooler) ## S.No._=28183 S.No.;_=28183
Oil Piping _ Oil Piping (Control Lh)
Oil Piping _ Oil Piping (Control Rh)
Oil Piping _ Oil Piping (Pilot P)
Oil Piping _ Oil Piping (Pilot T)
Oil Piping _ Oil Piping (Travel Lh) ## [Except Angle Blade]
Oil Piping _ Oil Piping (Travel Lh) ## [Angle Blade]
Oil Piping _ Oil Piping (Travel Rh) ## [Except Angle Blade]
Oil Piping _ Oil Piping (Travel Rh) ## [Angle Blade]
Oil Piping _ Oil Piping (Swivel)
Oil Piping _ Oil Piping (Swing)
Oil Piping _ Oil Piping (Boom)
Oil Piping _ Oil Piping (Arm)
Oil Piping _ Oil Piping (Bucket)
Oil Piping _ Oil Piping (Blade) ## [Except Angle Blade]
Oil Piping _ Oil Piping (Blade) ## [Angle Blade]
Oil Piping _ Oil Piping (Angle Blade) ## [Angle Blade]
Oil Piping _ Oil Piping (Clamp)
Oil Piping _ Oil Piping (S_P 1)
Oil Piping _ Oil Piping (S_P 2)
Oil Piping _ Oil Piping (Third Line Hydraulic Return)
Cylinder _ Boom Cylinder ## Note_Order By Ref.No.010 New Part & Fig No.E30400 Ref No
Cylinder _ Arm Cylinder
Cylinder _ Bucket Cylinder
Cylinder _ Blade Cylinder ## S.No._=21580 S.No.;_=21580
Cylinder _ Blade Cylinder ## S.No._=21581 S.No.;_=21581
Cylinder _ Angle Blade Cylinder ## [Angle Blade]
Cylinder _ Swing Cylinder
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade
Front Attachments _ Angle Blade ## [Angle Blade]
Track Frame _ Track Frame ## Note_Order By Ref.No.040,045,050 New Parts(Set)
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame (1) ## Note_ Order By Ref.No.200 And Fig.No.J30000 Ref.No
Swivel Frame _ Swivel Frame (2)
Swivel Frame _ Arch Frame (1) ## [Canopy]
Swivel Frame _ Arch Frame (1) ## [Cabin]
Swivel Frame _ Arch Frame (2)
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step
External_Upholstery _ Cover (Lh)
External_Upholstery _ Cover (Rh) [Canopy] ## Note 1_Order By Ref.No.010 & Ref.No
External_Upholstery _ Cover (Rh) [Cabin] ## Note 1_Order By Ref.No.010 & Ref.No
External_Upholstery _ Bonnet (Lh)
External_Upholstery _ Bonnet (Rh 1)
External_Upholstery _ Bonnet (Rh 2) ## Note_ Order By Ref.No.150 And Fig.No.K10201 Ref.No
External_Upholstery _ Bonnet (Rear)
External_Upholstery _ Bonnet (Center)
External_Upholstery _ Sponge (1)
External_Upholstery _ Sponge (2)
External_Upholstery _ Sponge (3)
External_Upholstery _ Weight
External_Upholstery _ Seat [Canopy] ## S.No._=21161 S.No.;_=21161
External_Upholstery _ Seat [Canopy] ## S.No._=21162 S.No.;_=21162
External_Upholstery _ Seat [Cabin] ## S.No._=21026 S.No.;_=21026
External_Upholstery _ Seat [Cabin] ## S.No._=21027 S.No.;_=21027
Operator's Platform _ Canopy
Operator's Platform _ Canopy (Electrical Wiring)
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door) ## S.No._=22011 S.No.;_=22011
Operator's Platform _ Cabin (Door) ## S.No._=22012 S.No.;_=22012
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Cover And Trim)
Operator's Platform _ Cabin (Lining)
Operator's Platform _ Cabin (Seal Rubber)
Operator's Platform _ Cabin (Rear View Mirror)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Heater)
Operator's Platform _ Cabin (Air Conditioner 1)
Operator's Platform _ Cabin (Air Conditioner 2)
Operator's Platform _ Cabin (Air Conditioner 3)
Labels _ Label
Accessories _ Accessories
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Head Cover
Engine _ Flywheel
Engine _ Governor
Engine _ Alternator
Engine _ Starter
Engine _ Water Pump
Engine _ Radiator
Engine _ Fan
Engine _ Oil Cooler
Track Frame _ Idler
Swivel Frame _ Step
Labels _ Label
