118
6,911
Kubota Excavator U55-4 80001- Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota U55-4 Excavator
Serial Number: 80001-
Number of Pages: 600 Pages
U55-4(S N;80001 )
4(S N;80001 ) Frequently Used Items Frequently Used Items Haeufig Verwendete Teile
U55-4(S N;80001 ) Motor Engine Kurbelgehaeuse Crank Case
U55-4(S N;80001 ) Motor Engine Oelwanne Oil Pan
U55-4(S N;80001 ) Motor Engine Oelmessstab Und Fuehrung Dipstick And Guide
U55-4(S N;80001 ) Motor Engine Zylinderkopf Cylinder Head
U55-4(S N;80001 ) Motor Engine Einlassventil Und Auslassventil Inlet Valve And Exhaust
U55-4(S N;80001 ) Motor Engine Kippenarmwelle Rocker Arm Shaft
U55-4(S N;80001 ) Motor Engine Zylinderkopf-Deckel Head Cover
U55-4(S N;80001 ) Motor Engine Vorderseitedeckel Front Cover
511000 Kolben Und Kurbelwelle Piston And Crankshaft ## Achtung Bestellen Sie Bitte Pos.160 +70 Neue
U55-4(S N;80001 ) Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle
U55-4(S N;80001 ) Motor Engine Schwungrad Flywheel
U55-4(S N;80001 ) Motor Engine Einspritzpumpe-Masseinheit Injection Pump Unit
U55-4(S N;80001 ) Motor Engine Gehaeuse Einspritzenpumpe Injection Pump Housing
U55-4(S N;80001 ) Motor Engine Einspritzpumpe Injection Pump
U55-4(S N;80001 ) Motor Engine Kraftstoffnockenwelle Fuel Camshaft
U55-4(S N;80001 ) Motor Engine Regler Governor
U55-4(S N;80001 ) Motor Engine Heibel-Gabel(Regler) Fork Lever (Governor)
U55-4(S N;80001 ) Motor Engine Beschraenkung Schraubbolzen Restriction Adjusting
U55-4(S N;80001 ) Motor Engine Kraftstoffrohr Fuel Piping
U55-4(S N;80001 ) Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow
U55-4(S N;80001 ) Motor Engine Einspritzung-Rohr Injection Pipe
U55-4(S N;80001 ) Motor Engine Lichtmaschine Alternator
U55-4(S N;80001 ) Motor Engine Lichtmaschine (Einzel-Teil) Alternator (Component
U55-4(S N;80001 ) Motor Engine Anlasser Starter
U55-4(S N;80001 ) Motor Engine Anlasser (Einzel-Teil) Starter (Component Parts)
U55-4(S N;80001 ) Motor Engine Abstellsolenoid Stop Solenoid
U55-4(S N;80001 ) Motor Engine Oelschalter Thermometer Oil Switch Thermometer
U55-4(S N;80001 ) Motor Engine Wasserflansch Und Thermostat Water Flange And
U55-4(S N;80001 ) Motor Engine Wasserpumpe Water Pump
U55-4(S N;80001 ) Motor Engine Wasserrohr (Carrosserie) Water Pipe (Body)
U55-4(S N;80001 ) Motor Engine Kuehler Radiator
U55-4(S N;80001 ) Motor Engine Reservebehaelter Reserve Tank
U55-4(S N;80001 ) Motor Engine Ventilator Fan
U55-4(S N;80001 ) Motor Engine Ansaugenleitung Inlet Manifold
U55-4(S N;80001 ) Motor Engine Auspuffruemmer Exhaust Manifold
U55-4(S N;80001 ) Motor Engine Luftfilter Air Cleaner
U55-4(S N;80001 ) Motor Engine Auspufftopf Muffler
U55-4(S N;80001 ) Motor Engine Oelkuehler Oil Cooler
U55-4(S N;80001 ) Motor Engine Motor Traeger Engine Bracket
U55-4(S N;80001 ) Motor Engine Dichtungssatz Zylinderkopf [Option] Upper Gasket Kit
U55-4(S N;80001 ) Motor Engine Dichtungssatz Motorblock [Option] Lower Gasket Kit [
U55-4(S N;80001 ) Brennstoff System Fuel System Autofreilauf Motor Auto Idle
4(S N;80001 ) Brennstoff System Fuel System Kraftstoffpumpe Und Kraftstoffleitung Fuel
U55-4(S N;80001 ) Brennstoff System Fuel System Kraftstoffilter (Einzel-Teile) Fuel Filter (
S N;80001 ) Brennstoff System Fuel System Wasserseparator (Einzel-Teil) Water Separator
U55-4(S N;80001 ) Brennstoff System Fuel System Kraftstofftank Fuel Tank
U55-4(S N;80001 ) Elektrisch System Electrical System Batterie Battery
U55-4(S N;80001 ) Elektrisch System Electrical System Hupe Horn
U55-4(S N;80001 ) Elektrisch System Electrical System Schalter, Zaehler Switch And
U55-4(S N;80001 ) Elektrisch System Electrical System Lampe Light
U55-4(S N;80001 ) Elektrisch System Electrical System Elektrische Ausrustung Electrical
U55-4(S N;80001 ) Elektrisch System Electrical System Diebstahlwarnanlage Anti-Theft
U55-4(S N;80001 ) Pumpe Motor System Pump Motor System Pumpengehaeuse Pump
U55-4(S N;80001 ) Pumpe Motor System Pump Motor System Kolbenpumpe Piston
4(S N;80001 ) Pumpe Motor System Pump Motor System Kolbenpumpe (Einzel-Teil) Piston Pump
U55-4(S N;80001 ) Pumpe Motor System Pump Motor System Fahrmotor Drive Motor
4(S N;80001 ) Pumpe Motor System Pump Motor System Fahrmotor (Einzel-Teile) Drive Moter
U55-4(S N;80001 ) Pumpe Motor System Pump Motor System Schwingungmotor Swivel
80001 ) Pumpe Motor System Pump Motor System Schwingungmotor (Einzel-Teil) Swivel
U55-4(S N;80001 ) Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary
80001 ) Pumpe Motor System Pump Motor System Drehgelenkstueck (Einzel-Teil) Rotary
U55-4(S N;80001 ) Pumpe Motor System Pump Motor System Oeltank (1) Oil Tank (1)
U55-4(S N;80001 ) Pumpe Motor System Pump Motor System Oeltank (2) Oil Tank (2)
U55-4(S N;80001 ) Pumpe Motor System Pump Motor System Oelfilter Oil Filter
U55-4(S N;80001 ) Regelungsventil Control Valve Regelungsventil (1) Control Valve
U55-4(S N;80001 ) Regelungsventil Control Valve Regelungsventil (2) Control Valve
U55-4(S N;80001 ) Regelungsventil Control Valve Regelungsventil (3) Control Valve
4(S N;80001 ) Regelungsventil Control Valve Regelungsventil (Einzel-Teil) Control Valve (
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Ausfluss) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Ax1) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Drehen) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Kuebel) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Arm) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Ausleger) Spool Section
80001 ) Regelungsventil Control Valve Spulensektion (Fahren Unabhangigkeit) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Fahren Rs) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Fahren Ls) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Blei) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Schwung) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Planierschild) Spool
U55-4(S N;80001 ) Regelungsventil Control Valve Spulensektion (Ax2) Spool Section
U55-4(S N;80001 ) Regelungsventil Control Valve Entladerventil Unload Valve
4(S N;80001 ) Regelungsventil Control Valve Entladerventil (Einzel-Teil) Unload Valve (
U55-4(S N;80001 ) Regelungsventil Control Valve S P Solenoidventil S P Solenoid Valve ##
U55-4(S N;80001 ) Regelungsventil Control Valve S P Solenoidventil S P Solenoid Valve ## [
U55-4(S N;80001 ) Kontrollrahmen Control Lever Kontrollhebel (Hebel Ls) Control Lever
Kontrollrahmen Control Lever Vordusenventil (Ls) (Einzel-Teil) Pilot Valve (Lh) (Component
) Kontrollrahmen Control Lever Vordusenventil (Ls) (Einzel-Teil) Pilot Valve (Lh) (Component
U55-4(S N;80001 ) Kontrollrahmen Control Lever Kontrollhebel (Hebel Rs) Control Lever
S N;80001 ) Kontrollrahmen Control Lever Vordusenventil (Rs) (Einzel-Teil) Pilot Valve (Rh)
U55-4(S N;80001 ) Kontrollrahmen Control Lever Kontrollhebel (Fahren) Control Lever
U55-4(S N;80001 ) Kontrollrahmen Control Lever Vordusenventil(Fahren) Pilot Valve
80001 ) Kontrollrahmen Control Lever Vordusenventil (Fahren) (Enzel-Teil) Pilot Valve (
U55-4(S N;80001 ) Kontrollrahmen Control Lever Schwungpedal Swing Pedal
U55-4(S N;80001 ) Kontrollrahmen Control Lever Vordusenventil(Schwung) Pilot Valve
80001 ) Kontrollrahmen Control Lever Vordusenventil (Schwung) (Enzel-Teil) Pilot Valve (
80001 ) Kontrollrahmen Control Lever Kontrollrahmen (Hebel Von Schloss) Control Lever
U55-4(S N;80001 ) Kontrollrahmen Control Lever Kontrollhebel (Planierschild) Control
U55-4(S N;80001 ) Kontrollrahmen Control Lever Vordusenventil (Planierschild) Pilot
Kontrollrahmen Control Lever Vordusenventil (Planierschild) (Einzel-Teil) Pilot Valve
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (Suction)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Befreitung) Oil Piping (Delivery)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Oelkuehler) Oil Piping (Oil
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Kontroll Ls) Oil Piping (Control
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Kontroll Rs) Oil Piping (Control
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Pilot P) Oil Piping (Pilot P)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Pilot T) Oil Piping (Pilot T)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Schwung) Oil Piping (Swing)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
U55-4(S N;80001 ) Oelleitungen Oil Piping Enthuelsungventil (Einzel-Teil) Holding Valve (
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Kuebel) Oil Piping (Bucket)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Planierschild) Oil Piping (
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Klammer) Oil Piping (Clamp)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P)
U55-4(S N;80001 ) Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P) ## [Aux1&2]
S N;80001 ) Oelleitungen Oil Piping Oel Leitung (Dritte Ruecklaufleitung) Oil Piping (Third Line
U55-4(S N;80001 ) Zylinder Cylinder Auslegerzylinder Boom Cylinder
U55-4(S N;80001 ) Zylinder Cylinder Armzylinder Arm Cylinder
U55-4(S N;80001 ) Zylinder Cylinder Kuebelzylinder Bucket Cylinder
U55-4(S N;80001 ) Zylinder Cylinder Erdschieberzylinder Blade Cylinder
U55-4(S N;80001 ) Zylinder Cylinder Schwenkzylinder Swing Cylinder
U55-4(S N;80001 ) Anhaften Von Stirn Front Attachments Schwenkhal Terung Swing
U55-4(S N;80001 ) Anhaften Von Stirn Front Attachments Ausleger Boom
U55-4(S N;80001 ) Anhaften Von Stirn Front Attachments Abdeckung (Ausleger) Cylinder
U55-4(S N;80001 ) Anhaften Von Stirn Front Attachments Arm Arm
U55-4(S N;80001 ) Anhaften Von Stirn Front Attachments Kuebel Gestange Bucket
Attachments Planierschild Blade ## Achtung Bitte Bestellen Sie Pos.010 Und Pos.100,110 Neue
U55-4(S N;80001 ) Spurrahmen Track Frame Spurrahmen Track Frame
U55-4(S N;80001 ) Spurrahmen Track Frame Spannrad Idler
U55-4(S N;80001 ) Spurrahmen Track Frame Laufrollen Track Roller
U55-4(S N;80001 ) Spurrahmen Track Frame Laufketten Crawler
U55-4(S N;80001 ) Rahmen Von Drehen Swivel Frame Rahmen Von Drehen (1) Swivel Frame
U55-4(S N;80001 ) Rahmen Von Drehen Swivel Frame Rahmen Von Drehen (2) Swivel Frame
U55-4(S N;80001 ) Rahmen Von Drehen Swivel Frame Bogenrahmen (1) Arch Frame (
U55-4(S N;80001 ) Rahmen Von Drehen Swivel Frame Bogenrahmen (2) Arch Frame (
U55-4(S N;80001 ) Rahmen Von Drehen Swivel Frame Lager, Drehen Swivel Bearing
U55-4(S N;80001 ) Rahmen Von Drehen Swivel Frame Sitz Traeger Seat Support
U55-4(S N;80001 ) Rahmen Von Drehen Swivel Frame Tritt Step
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Deckel (Ls) Cover
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Deckel (Rs) Cover
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Motorhaube (Ls)
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Motorhaube (Rs)
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Motorhaube (Hinter)
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Motorhaube (Zentrum)
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Schaumgummi (1)
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Schaumgummi (2)
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Schaumgummi (3)
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Gewicht Weight
U55-4(S N;80001 ) Aubere Bauteile Polsterung External Upholstery Sitz Seat
U55-4(S N;80001 ) Kabine Cabin Kabine (Koerper) Cabin (Body)
U55-4(S N;80001 ) Kabine Cabin Kabine (Tuer) Cabin (Door)
U55-4(S N;80001 ) Kabine Cabin Kabine (Fenster) Cabin (Window)
U55-4(S N;80001 ) Kabine Cabin Kabine (Deckel Und Trimm) Cabin (Cover And Trim)
U55-4(S N;80001 ) Kabine Cabin Kabine (Futter) Cabin (Lining)
U55-4(S N;80001 ) Kabine Cabin Kabine (Gummiabdichtung) Cabin (Seal Rubber)
U55-4(S N;80001 ) Kabine Cabin Kabine (Rueckspiegel) Cabin (Rearview Mirror)
U55-4(S N;80001 ) Kabine Cabin Kabine (Scheibenwischermotor) Cabin (Wiper Motor)
U55-4(S N;80001 ) Kabine Cabin Kabine (Kabelgeschirr) Cabin (Electrical Wiring)
U55-4(S N;80001 ) Kabine Cabin Kabine (Heizkoerper) Cabin (Heater)
U55-4(S N;80001 ) Aufkleber Labels Aufkleber Label
U55-4(S N;80001 ) Zubehoer Accessories Zubehoer Accessories
U55-4(S N;80001 ) Option Option Kit Steinschlagschutz [Option] Kit Gravel Guard [
U55-4(S N;80001 ) Option Option Greifer-Kit (Ohne Kupplung) (Kbd) Clamp Kit (Without Quick-
U55-4(S N;80001 ) Option Option Kit Rundumleuchte Kit Rotating Beacon
U55-4(S N;80001 ) Option Option Löffel, Schnellkupplung (Kbd) Bucket, Quick-Coupler
U55-4(S N;80001 ) Option Option Kit Steckkupplung Kit Plug-In Coupler
U55-4(S N;80001 ) Option Option Kit Kupplung (Flachdichtend) Kit Flat-Face Coupler
U55-4(S N;80001 ) Option Option Kit Schraubkupplung Kit Screw-Type Coupler
U55-4(S N;80001 ) Option Option Rohrbruchsicherung(Arm) Pipe-Break Valve Arm
U55-4(S N;80001 ) Option Option Rohrbruchsicherung(Erdschieber) Pipe-Break Valve
U55-4(S N;80001 ) Option Option Gap-Kit (Kuk) Gap-Kit (Kuk)
U55-4(S N;80001 ) Option Option Greifer-Kit Clamshell Kit
U55-4(S N;80001 ) Option Option Kit Tiltmotor Kit Tiltmotor
U55-4(S N;80001 ) Option Option Kit Schnellwechsler Hydraulisch Kit Quick Coupler
U55-4(S N;80001 ) Option Option Schnellkupplung (Einzelteile)(Kbd) Quick-Coupler (Component
U55-4(S N;80001 ) Option Option Anbauplatten - Km205 Mounting Brackets - Km205
U55-4(S N;80001 ) Option Option Kit Hydraulikhammer Kit Hydraulic Breaker
U55-4(S N;80001 ) Option Option Kit Powertilt (Schnellwechsler Hydr.) Kit Powertilt (Quick
U55-4(S N;80001 ) Option Option Kit Powertilt (Schnellwechsler Mech.) Kit Powertilt (Quick
U55-4(S N;80001 ) Option Option Anbauplatten - Km305 Mounting Brackets - Km305
U55-4(S N;80001 ) Option Option Löffel (Ohne Schnellkupplung) Bucket (No Quick-
U55-4(S N;80001 ) Option Option Löffel, Schnellkupplung Bucket, Quick-Coupler
U55-4(S N;80001 ) Option Option Kit Summer Kit Buzzer,Travel
