Kubota Excavator U50-5 Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota U50-5 Excavator
Number of Pages: 457 Pages
U50-5
U50-5 Frequently Used Items Frequently Used Items Frequently Used Items Frequently
U50-5 Motor Engine Kurbelghaeuse Crankcase
U50-5 Motor Engine Oelwanne Oil Pan
U50-5 Motor Engine Oelfilter Oil Filter
U50-5 Motor Engine Oelmessstab Und Fuehrung Dipstick And Guide
U50-5 Motor Engine Zylinderkopf Cylinder Head
U50-5 Motor Engine Einlassventil Und Auslassventil Inlet Valve And Exhaust Valve
U50-5 Motor Engine Kippenarmwelle Rocker Arm Shaft
U50-5 Motor Engine Deckel Oben Head Cover
U50-5 Motor Engine Getriebe Gehaeuse Gear Case
U50-5 Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
U50-5 Motor Engine Hauptlagergehaeuse Main Bearing Case
U50-5 Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle Gear
U50-5 Motor Engine Schwungrad Flywheel
U50-5 Motor Engine Einspritzenpumpe Injection Pump
U50-5 Motor Engine Kraftstoffnockenwelle Fuel Camshaft
U50-5 Motor Engine Versorgungsmaterial-Pumpe Supply Pump
U50-5 Motor Engine Duesenhalter Gluehkerze Injector And Glow Plug
U50-5 Motor Engine Einspritzung-Rohr Injection Pipe
U50-5 Motor Engine Allgemeine Schiene Common Rail
U50-5 Motor Engine Lichtmaschine Alternator
U50-5 Motor Engine Lichtmaschine (Einzel-Teil) Alternator (Component Parts)
U50-5 Motor Engine Anlasser Starter
U50-5 Motor Engine Anlasser (Einzel-Teil) Starter (Component Parts)
U50-5 Motor Engine Oelschalter Thermometer Oil Switch Thermometer
U50-5 Motor Engine Wasserflansch Und Thermostat Water Flange And Thermostat
U50-5 Motor Engine Wasserpumpe Water Pump
U50-5 Motor Engine Wasserrohr Water Pipe
U50-5 Motor Engine Wasserrohr (Carrosserie) Water Pipe (Body)
U50-5 Motor Engine Kuehler Radiator
U50-5 Motor Engine Ausgleichbehaelter Reserve Tank
U50-5 Motor Engine Ventilator Cooler Fan
U50-5 Motor Engine Einlasskruemmer Inlet Manifold
U50-5 Motor Engine Auspuffrummer Exhaust Manifold
U50-5 Motor Engine Egr Ventil Egr Valve
U50-5 Motor Engine Egr Kuehlsystem Egr Cooler
U50-5 Motor Engine Turbineladung Turbo Charger
U50-5 Motor Engine Luftfilter Air Cleaner
U50-5 Motor Engine Dieselpartikelfilter Auspuffdämpfer Diesel Particulate Filter
Motor Engine Schalldämpferhalterung Des Dieselpartikelfilters Diesel Particulate Filter
U50-5 Motor Engine Abblasdampfer-Sensor Diesel Particulate Filter Muffler Sensor
Motor Engine Differenzdruckleitung Des Dieselpartikelfilters Diesel Particulate Filter
U50-5 Motor Engine Schalldämpferrohr Des Dieselpartikelfilters Diesel Particulate Filter
5 Motor Engine Schalldämpferabdeckung Des Dieselpartikelfilters Diesel Particulate
U50-5 Motor Engine Ölabscheider Oil Separator
U50-5 Motor Engine Ölabscheiderrohr Oil Separator Pipe
U50-5 Motor Engine Oelpomr (Turbineladung) Oil Pipe (Turbo Charger)
U50-5 Motor Engine Oelkuehler Oil Cooler
U50-5 Motor Engine Kabelgeschirr Halter Wire Harness Bracket
U50-5 Motor Engine Motor Traeger Engine Bracket
U50-5 Brennstoff System Fuel System Kraftstoffleitungen (1) Fuel Pump And Piping
U50-5 Brennstoff System Fuel System Kraftstoffleitungen (2) Fuel Pump And Piping
U50-5 Brennstoff System Fuel System Kraftstoffleitungen (3) Fuel Pump And Piping
U50-5 Brennstoff System Fuel System Kraftstoffilter (Einzel-Teil) Fuel Filter (Component
U50-5 Brennstoff System Fuel System Wasserabscheider (Einzel-Teil) Separator (Component
U50-5 Brennstoff System Fuel System Kraftstofftank Fuel Tank
U50-5 Elektrisch System Electrical System Batterie Battery
U50-5 Elektrisch System Electrical System Hupe Horn
U50-5 Elektrisch System Electrical System Schalter, Zaehler Switch And Meter
U50-5 Elektrisch System Electrical System Lampe Lamp
U50-5 Elektrisch System Electrical System Kabelgeschirr Wire Harness
U50-5 Elektrisch System Electrical System Diebstahlwarnanlage Anti-Theft Alarm
U50-5 Pumpe Motor System Pump Motor System Pumpengehaeuse Housing Pump
U50-5 Pumpe Motor System Pump Motor System Kolbenpumpe Piston Pump
U50-5 Pumpe Motor System Pump Motor System Kolbenpumpe (Einzel-Teil) Piston Pump (
U50-5 Pumpe Motor System Pump Motor System Motor Drive Moter
U50-5 Pumpe Motor System Pump Motor System Fahrmotor (Einzel-Teile) Drive Motor (
U50-5 Pumpe Motor System Pump Motor System Schwingungmotor Swivel Motor
5 Pumpe Motor System Pump Motor System Schwingungmotor (Einzel-Teil) Swivel Motor (
U50-5 Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary Joint
5 Pumpe Motor System Pump Motor System Drehgelenkstueck (Einzel-Teil) Rotary Joint (
U50-5 Pumpe Motor System Pump Motor System Oeltank (1) Oil Tank (1)
U50-5 Pumpe Motor System Pump Motor System Oeltank (2) Oil Tank (2)
U50-5 Pumpe Motor System Pump Motor System Ölfilter Oil Filter
U50-5 Regelungsventil Control Valve Regelungsventil (1) Control Valve (1)
U50-5 Regelungsventil Control Valve Regelungsventil (2) Control Valve (2)
U50-5 Regelungsventil Control Valve Regelungsventil (3) Control Valve (3)
U50-5 Regelungsventil Control Valve Kontrollventil (Einzel-Teil) Control Valve (Component
U50-5 Regelungsventil Control Valve Spulensektion (Ausfluss) Section (Outlet)
U50-5 Regelungsventil Control Valve Spulensektion (Ax1) Section (Ax1)
U50-5 Regelungsventil Control Valve Spulensektion (Drehen) Section (Swivel)
U50-5 Regelungsventil Control Valve Spulensektion (Loeffel) Section (Bucket)
U50-5 Regelungsventil Control Valve Spulensektion (Arm) Section (Arm)
U50-5 Regelungsventil Control Valve Spulensektion (Ausleger) Section (Boom)
U50-5 Regelungsventil Control Valve Spulensektion (Fahren Rs) Section (Travel
U50-5 Regelungsventil Control Valve Spulensektion (Fahren Ls) Section (Travel
U50-5 Regelungsventil Control Valve Spulensektion (Schwung) Section (Swing)
U50-5 Regelungsventil Control Valve Spulensektion (Planierschild) Section (Blade)
U50-5 Regelungsventil Control Valve Spulensektion (Ax2) Section (Ax2)
U50-5 Regelungsventil Control Valve Entladerventil Unload Valve
U50-5 Regelungsventil Control Valve Entladerventil (Einzel-Teil) Unload Valve (Component
U50-5 Regelungsventil Control Valve S P Solenoidventil S P Solenoid Valve ## [Aux1]
U50-5 Regelungsventil Control Valve S P Solenoidventil S P Solenoid Valve ## [Aux1&2]
U50-5 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Ls) Control Lever (Lever
Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Lh) (Component
Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Lh) (Component Parts)
U50-5 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Rs) Control Lever (Lever
U50-5 Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Rh) (Component
U50-5 Kontrollrahmen Control Lever Kontrollrahmen (Fahren) Control Lever (
U50-5 Kontrollrahmen Control Lever Vordusenventil (Fahren) Pilot Valve (Travel)
Kontrollrahmen Control Lever Vordusenventil (Fahren) (Enzel-Teil) Pilot Valve (Travel) (
U50-5 Kontrollrahmen Control Lever Schwungpedal Swing Pedal
U50-5 Kontrollrahmen Control Lever Vordusenventil (Schwung) Pilot Valve (Swing)
Kontrollrahmen Control Lever Vordusenventil (Schwung) (Enzel-Teil) Pilot Valve (Swing)
5 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Von Schloss) Control Lever (
U50-5 Kontrollrahmen Control Lever Vordusenventil (Erdschieber) Control Lever (
U50-5 Kontrollrahmen Control Lever Vordusenventil (Erdschieber) Pilot Valve (
Kontrollrahmen Control Lever Vordusenventil (Erdschieber) (Einzel-Teil) Pilot Valve (Blade)
U50-5 Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (Suction)
U50-5 Oelleitungen Oil Piping Oel Leitung (Befreitung) Oil Piping (Delivery)
U50-5 Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return)
U50-5 Oelleitungen Oil Piping Oel Leitung (Oelkuehler) Oil Piping (Oil Cooler)
U50-5 Oelleitungen Oil Piping Oel Leitung (Kontroll Ls) Oil Piping (Control Lh)
U50-5 Oelleitungen Oil Piping Oel Leitung (Kontroll Rs) Oil Piping (Control Rh)
U50-5 Oelleitungen Oil Piping Oel Leitung (Pilot P) Oil Piping (Pilot P)
U50-5 Oelleitungen Oil Piping Oel Leitung (Pilot T) Oil Piping (Pilot T)
U50-5 Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel Lh)
U50-5 Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel Rh)
U50-5 Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
U50-5 Oelleitungen Oil Piping Oel Leitung (Schwung) Oil Piping (Swing)
U50-5 Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
5 Oelleitungen Oil Piping Enthuelsungventil (Ausleger) (Einzel-Teil) Holding Valve (Boom) (
U50-5 Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
U50-5 Oelleitungen Oil Piping Enthuelsungventil (Arm) (Einzel-Teil) Holding Valve (Arm) (
U50-5 Oelleitungen Oil Piping Oel Leitung (Kuebel) Oil Piping (Bucket)
U50-5 Oelleitungen Oil Piping Oel Leitung (Erdschieber) Oil Piping (Blade)
U50-5 Oelleitungen Oil Piping Oel Leitung (Klammer) Oil Piping (Clamp)
U50-5 Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P) ## [Aux1] [Aux1]
U50-5 Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P) ## [Aux1&2] [Aux1&
Oil Piping Oel Leitung (Dritte Ruecklaufleitung) Oil Piping (Third Line Hydraulic Return)
U50-5 Zylinder Cylinder Auslegerzylinder Boom Cylinder
U50-5 Zylinder Cylinder Armzylinder Arm Cylinder
U50-5 Zylinder Cylinder Kuebelzylinder Bucket Cylinder
U50-5 Zylinder Cylinder Erdschieberzylinder Blade Cylinder
U50-5 Zylinder Cylinder Schwenkzylinder Swing Cylinder
U50-5 Anhaften Von Stirn Front Attachments Lagerung Ausleger Swing Bracket
U50-5 Anhaften Von Stirn Front Attachments Ausleger Boom
U50-5 Anhaften Von Stirn Front Attachments Abdeckung (Ausleger) Cylinder Cover
U50-5 Anhaften Von Stirn Front Attachments Arm Arm
U50-5 Anhaften Von Stirn Front Attachments Kuebelverbindungestueck Bucket
U50-5 Anhaften Von Stirn Front Attachments Erdschieber Blade
U50-5 Spurrahmen Track Frame Spurrahmen Track Frame
U50-5 Spurrahmen Track Frame Spannrad Idler
U50-5 Spurrahmen Track Frame Laufrollen Track Roller
U50-5 Spurrahmen Track Frame Laufketten Crawler
U50-5 Rahmen Von Drehen Swivel Frame Rahmen Von Drehen Swivel Frame
U50-5 Rahmen Von Drehen Swivel Frame Bogenrahmen (1) Arch Frame (1) ## [Except A C] [
U50-5 Rahmen Von Drehen Swivel Frame Bogenrahmen (1) Arch Frame (1) ## [A C] [A
U50-5 Rahmen Von Drehen Swivel Frame Bogenrahmen (2) Arch Frame (2)
U50-5 Rahmen Von Drehen Swivel Frame Lager, Drehen Swivel Bearing
U50-5 Rahmen Von Drehen Swivel Frame Sitz Traeger Seat Support
U50-5 Rahmen Von Drehen Swivel Frame Tritt Step
U50-5 Aubere Bauteile Polsterung External Upholstery Deckel (Ls) Cover (Lh)
U50-5 Aubere Bauteile Polsterung External Upholstery Deckel (Rs) Cover (Rh)
U50-5 Aubere Bauteile Polsterung External Upholstery Motorhaube (Rs) Bonnet (
U50-5 Aubere Bauteile Polsterung External Upholstery Motorhaube (Hinter) Bonnet
U50-5 Aubere Bauteile Polsterung External Upholstery Motorhaube (Zentrum) Bonnet
U50-5 Aubere Bauteile Polsterung External Upholstery Schaumgummi Sponge
U50-5 Aubere Bauteile Polsterung External Upholstery Gewicht Weight
U50-5 Aubere Bauteile Polsterung External Upholstery Sitz Seat
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Koerper) Cabin (Body)
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Tuer) Cabin (Door)
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Fenster) Cabin (Window)
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Deckel Und Trimm) Cabin (Cover
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Futter) Cabin (Lining)
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Gummiabdichtung) Cabin (Seal
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Rueckspiegel) Cabin (Rearview
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Scheibenwischermotor) Cabin (Wiper
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Kabelgeschirr) Cabin (Wire
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Heizkoerper) Cabin (Heater)
Fahrer Operator's Platform Kabine (Heizkoerper) (Einzel-Teil) Cabin (Heater) (Component
Buhne Von Fahrer Operator's Platform Kabine (Heizkoerper) (Einzel-Teil) Cabin (Heater) (Component
U50-5 Buhne Von Fahrer Operator's Platform Kabine (Klimaanlage) Cabin (Air Conditioner
U50-5 Aufkleber Labels Aufkleber Label
U50-5 Sontiges Zubehoer Accessories Sontiges Zubehoer Accessories
U50-5
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
