118
6,911
Kubota Excavator U48-4 50006- Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota U48-4 Excavator
Serial Number: 50006-
Number of Pages: 746 Pages
U48-4 (S N 50006-54261)
N 50006-54261) Haeufig Verwendete Teile Frequently Used Items Haeufig Verwendete Teile
U48-4 (S N 50006-54261) Motor Engine Kurbelgehaeuse Crank Case
U48-4 (S N 50006-54261) Motor Engine Oelwanne Oil Pan
U48-4 (S N 50006-54261) Motor Engine Oelmessstab Und Fuehrung Dipstick And Guide
Zylinderkopf Cylinder Head ## Note Order By Ref No.040(1j701-0303-6) & 01754-50820 Flange Bolt(Q'ty) Note
Auslassventil Inlet Valve And Exhaust Valve ## Note Order By Ref No.010(1j701-0303-6) & 01754-50820 Flange
U48-4 (S N 50006-54261) Motor Engine Kippenarmwelle Rocker Arm Shaft
U48-4 (S N 50006-54261) Motor Engine Ventildeckel Head Cover
U48-4 (S N 50006-54261) Motor Engine Vorderdeckel Front Cover
Kolben Und Kurbelwelle Piston And Crankshaft ## Hinweis Bestellung Nach Ref.Nr.160,170 Neues
U48-4 (S N 50006-54261) Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And
U48-4 (S N 50006-54261) Motor Engine Schwungrad Flywheel
U48-4 (S N 50006-54261) Motor Engine Einspritzpumpe-Masseinheit Injection Pump Unit
U48-4 (S N 50006-54261) Motor Engine Gehaeuse Einspritzenpumpe Injection Pump
U48-4 (S N 50006-54261) Motor Engine Einspritzpumpe Injection Pump
U48-4 (S N 50006-54261) Motor Engine Fraftstoffnockenwelle Fuel Camshaft
U48-4 (S N 50006-54261) Motor Engine Regler Governor
U48-4 (S N 50006-54261) Motor Engine Heibel-Gabel (Regler) Fork Lever (Governor)
U48-4 (S N 50006-54261) Motor Engine Beschraenkung Schraubbolzen Restriction Adjusting
U48-4 (S N 50006-54261) Motor Engine Kraftstoffrohr Fuel Piping
U48-4 (S N 50006-54261) Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And
U48-4 (S N 50006-54261) Motor Engine Einspritzung-Rohr Injection Pipe
U48-4 (S N 50006-54261) Motor Engine Lichtmaschine Alternator
U48-4 (S N 50006-54261) Motor Engine Lichtmaschine (Einzel-Teile) Alternator (Component
U48-4 (S N 50006-54261) Motor Engine Anlasser Starter
U48-4 (S N 50006-54261) Motor Engine Anlasser (Einzel-Teil) Starter (Component Parts)
U48-4 (S N 50006-54261) Motor Engine Abstellhubmagnet Stop Solenoid
U48-4 (S N 50006-54261) Motor Engine Oelschalter Thermometer Oil Switch Thermometer
U48-4 (S N 50006-54261) Motor Engine Wasserflansch Und Thermostat Water Flange And
U48-4 (S N 50006-54261) Motor Engine Wasserpumpe Water Pump
U48-4 (S N 50006-54261) Motor Engine Wasserrohr (Carrosserie) Water Pipe (Body)
U48-4 (S N 50006-54261) Motor Engine Kuehler Radiator
U48-4 (S N 50006-54261) Motor Engine Reservebehaelter Reserve Tank
U48-4 (S N 50006-54261) Motor Engine Ventilator Fan
U48-4 (S N 50006-54261) Motor Engine Einlasskruemmer Inlet Manifold
U48-4 (S N 50006-54261) Motor Engine Auslasskruemmer Exhaust Manifold
U48-4 (S N 50006-54261) Motor Engine Luftfilter Air Cleaner
Auspuff Muffler ## S.Nr. =53168 Achtung Bestellen Sie Bitte Pos.040 +20 Neue Teile (Set) S.No. =
U48-4 (S N 50006-54261) Motor Engine Auspuff Muffler ## S.Nr. =53169 S.No.; =53169 S.No. =53169
U48-4 (S N 50006-54261) Motor Engine Oelkuehler Oil Cooler
U48-4 (S N 50006-54261) Motor Engine Motor Traeger Engine Bracket
U48-4 (S N 50006-54261) Motor Engine Zylinderkopfdichtsatz Upper Gasket Kit ## [Option]
U48-4 (S N 50006-54261) Motor Engine Dichtungssatz Motorblock Lower Gasket Kit ## [Option]
U48-4 (S N 50006-54261) Kraftstoff System Fuel System Automatischer Freilauf Auto Idle
U48-4 (S N 50006-54261) Kraftstoff System Fuel System Kraftstoffleitungen Fuel Pump
4 (S N 50006-54261) Kraftstoff System Fuel System Kraftstoffilter (Einzel-Teil) Fuel Filter (
N 50006-54261) Kraftstoff System Fuel System Wasserseparator (Einzel-Teil) Water Separator
U48-4 (S N 50006-54261) Kraftstoff System Fuel System Kraftstofftank Fuel Tank
U48-4 (S N 50006-54261) Elektrisches System Electrical System Batterie Battery
U48-4 (S N 50006-54261) Elektrisches System Electrical System Hupe Horn
U48-4 (S N 50006-54261) Elektrisches System Electrical System Schalter, Zaehler Switch
U48-4 (S N 50006-54261) Elektrisches System Electrical System Lampe Light
4 (S N 50006-54261) Elektrisches System Electrical System Elektrische Ausruestung (Kabine)
U48-4 (S N 50006-54261) Elektrisches System Electrical System Elektrische Ausruestung
U48-4 (S N 50006-54261) Elektrisches System Electrical System Diebstahlwarnanlage Anti-Theft
U48-4 (S N 50006-54261) Pumpe Motor System Pump Motor System Pumpengehaeuse Pump
U48-4 (S N 50006-54261) Pumpe Motor System Pump Motor System Kolbenpumpe Piston
N 50006-54261) Pumpe Motor System Pump Motor System Kolbenpumpe (Einzel-Teil) Piston Pump
U48-4 (S N 50006-54261) Pumpe Motor System Pump Motor System Motor Und Einzel-Teil Drive
S N 50006-54261) Pumpe Motor System Pump Motor System Fahrmotor (Einzel-Teil) Drive Moter
4 (S N 50006-54261) Pumpe Motor System Pump Motor System Motor (Einzel-Teil) Drive Moter (
U48-4 (S N 50006-54261) Pumpe Motor System Pump Motor System Schwenkmotor Swivel
System Pump Motor System Schwenkmotor (Einzelteile) Swivel Motor (Component Parts)
System Pump Motor System Schwingungmotor (Einzel-Teil) Swivel Motor (Component Parts)
50006-54261) Pumpe Motor System Pump Motor System Schwenkmotor (Einzelteile) Swivel
U48-4 (S N 50006-54261) Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary
50006-54261) Pumpe Motor System Pump Motor System Drehgelenkstueck (Einzel-Teile) Rotary
U48-4 (S N 50006-54261) Pumpe Motor System Pump Motor System Oeltank (1) Oil Tank
U48-4 (S N 50006-54261) Pumpe Motor System Pump Motor System Oeltank (2) Oil Tank
U48-4 (S N 50006-54261) Pumpe Motor System Pump Motor System Oelfilter Oil Filter
U48-4 (S N 50006-54261) Kontrollventil Control Valve Regelungsventil (1) Control Valve
U48-4 (S N 50006-54261) Kontrollventil Control Valve Regelungsventil (2) Control Valve
U48-4 (S N 50006-54261) Kontrollventil Control Valve Regelungsventil (3) Control Valve
(S N 50006-54261) Kontrollventil Control Valve Kontrollventil (Einzel-Teil) Control Valve (
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Ausfluss) Spool Section
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Ax1) Spool Section
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Drehen) Spool Section
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Loeffel) Spool Section
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Arm) Spool Section
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Ausleger) Spool Section
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Fahren Rs) Spool Section
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Fahren Ls) Spool Section
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Schwenken) Spool
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Planierschild) Spool
U48-4 (S N 50006-54261) Kontrollventil Control Valve Spulensektion (Ax2) Spool Section
54261) Kontrollventil Control Valve Ueberstroemventil Unload Valve ## S.Nr. =56102 S.No.; =
54261) Kontrollventil Control Valve Ueberstroemventil Unload Valve ## S.Nr. =56103 S.No.; =
S N 50006-54261) Kontrollventil Control Valve Ueberstroemventil (Einzelteile) Unload Valve
U48-4 (S N 50006-54261) Kontrollventil Control Valve S P Solenoidventil S P Solenoid Valve ##
Kontrollhebel (Hebel Ls) Control Lever (Lever Lh) ## Note Order By Ref.No.010 & Fig.No. Ref.No.050,120,130
54261) Kontrollrahmen Control Lever Vorduesenventil (Ls) (Einzelteil) Pilot Valve (Lh) (
U48-4 (S N 50006-54261) Kontrollrahmen Control Lever Kontrollhebel (Hebel Rs) Control Lever
50006-54261) Kontrollrahmen Control Lever Vorduesenventil (Rs) (Einzelteil) Pilot Valve (
U48-4 (S N 50006-54261) Kontrollrahmen Control Lever Kontrollhebel (Fahren) Control
U48-4 (S N 50006-54261) Kontrollrahmen Control Lever Vorduesenventil (Fahren) Pilot Valve
(Fahren) (Einzelteile) Pilot Valve (Travel) (Component Parts) ## Note Order By Part No.Rd451-9786-3 And
U48-4 (S N 50006-54261) Kontrollrahmen Control Lever Schwenkpedal Swing Pedal
U48-4 (S N 50006-54261) Kontrollrahmen Control Lever Vorduesenventil (Schwenken) Pilot
54261) Kontrollrahmen Control Lever Vorduesenventil (Schwenken) (Einzelteile) Pilot Valve
50006-54261) Kontrollrahmen Control Lever Kontrollrahmen (Hebel Von Schloss) Control
4 (S N 50006-54261) Kontrollrahmen Control Lever Kontrollrahmen (Planierschild) Control
U48-4 (S N 50006-54261) Kontrollrahmen Control Lever Vorduesenventil (Planierschild) Pilot
54261) Kontrollrahmen Control Lever Vorduesenventil (Planierschild) (Einzelteile) Pilot
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (Suction)
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Befreitung) Oil Piping (
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Oelkuehler) Oil Piping (Oil
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Kontroll Ls) Oil Piping (Control
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Kontroll Rs) Oil Piping (Control
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Pilot P) Oil Piping (Pilot
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Pilot T) Oil Piping (Pilot
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oelleitung (Schwenken) Oil Piping (
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oelleitung (Loeffel) Oil Piping (Bucket)
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oelleitung (Planierschild) Oil Piping (
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (Klammer) Oil Piping (Clamp)
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P)
U48-4 (S N 50006-54261) Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P) ## [Aux1&
50006-54261) Oelleitungen Oil Piping Oel Leitung (Dritte Ruecklaufleitung) Oil Piping (Third
Auslegerzylinder Boom Cylinder ## Note Order By Ref.No.010 New Part & Fig.No. Ref.No.010,020,030,060,070 Set
U48-4 (S N 50006-54261) Zylinder Cylinder Armzylinder Arm Cylinder
U48-4 (S N 50006-54261) Zylinder Cylinder Loeffelzylinder Bucket Cylinder
50006-54261) Zylinder Cylinder Planierschildzylinder Blade Cylinder ## S.Nr. =55685 S.No.; =55685
50006-54261) Zylinder Cylinder Planierschildzylinder Blade Cylinder ## S.Nr. =55686 S.No.; =55686
U48-4 (S N 50006-54261) Zylinder Cylinder Schwenkzylinder Swing Cylinder
U48-4 (S N 50006-54261) Frontanbau Komponenten Front Attachments Schwenkbock Swing
U48-4 (S N 50006-54261) Frontanbau Komponenten Front Attachments Ausleger Boom
4 (S N 50006-54261) Frontanbau Komponenten Front Attachments Abdeckung (Ausleger) Cylinder
U48-4 (S N 50006-54261) Frontanbau Komponenten Front Attachments Arm Arm
U48-4 (S N 50006-54261) Frontanbau Komponenten Front Attachments Loeffelverbindungsstueck
Front Attachments Planierschild Blade ## Note Order By Ref.No.010 New Part & Ref.No.
Track Frame Spurrahmen Track Frame ## Note Order By Ref.No.040,045,050 New Parts(Set)
U48-4 (S N 50006-54261) Spurrahmen Track Frame Spannrad Idler
U48-4 (S N 50006-54261) Spurrahmen Track Frame Laufrollen Track Roller
U48-4 (S N 50006-54261) Spurrahmen Track Frame Laufketten Crawler
Von Drehen (1) Swivel Frame (1) ## Note Order By Ref.No.200 And Fig.No. Ref.No.160,180,190 New Parts
U48-4 (S N 50006-54261) Drehrahmen Swivel Frame Drehrahmen (2) Swivel Frame (2)
U48-4 (S N 50006-54261) Drehrahmen Swivel Frame Bogenrahmen (1) Arch Frame (1) ## [Except A
U48-4 (S N 50006-54261) Drehrahmen Swivel Frame Bogenrahmen (1) Arch Frame (1) ## [A C]
U48-4 (S N 50006-54261) Drehrahmen Swivel Frame Bogenrahmen (2) Arch Frame (2)
U48-4 (S N 50006-54261) Drehrahmen Swivel Frame Drehkranz Swivel Bearing
Sitz Traeger Seat Support ## Note Order By Ref.No.050,120,130 & Fig. No. Ref.No.010 New Parts (Set)
U48-4 (S N 50006-54261) Drehrahmen Swivel Frame Tritt Step
U48-4 (S N 50006-54261) Motorhaube Sitz Gewicht External Upholstery Deckel (Ls) Cover
## Note Order By Ref.No.010 & Ref.No.130 To20 New Parts(Set)Note Order By Part No.Rd158-4478-0 & Ref.
U48-4 (S N 50006-54261) Motorhaube Sitz Gewicht External Upholstery Motorhaube (Ls)
Upholstery Motorhaube (Rs) Bonnet (Rh) ## Note Order By Ref.No.110 & Fig.No. Ref.No.150
Upholstery Motorhaube (Rs) Bonnet (Rh) ## Note Order By Ref.No.150 & Fig.No. Ref.No.110
U48-4 (S N 50006-54261) Motorhaube Sitz Gewicht External Upholstery Motorhaube (Hinter)
4 (S N 50006-54261) Motorhaube Sitz Gewicht External Upholstery Motorhaube (Zentrum)
U48-4 (S N 50006-54261) Motorhaube Sitz Gewicht External Upholstery Daemmstoff (1)
U48-4 (S N 50006-54261) Motorhaube Sitz Gewicht External Upholstery Daemmstoff (2)
U48-4 (S N 50006-54261) Motorhaube Sitz Gewicht External Upholstery Daemmstoff (3)
U48-4 (S N 50006-54261) Motorhaube Sitz Gewicht External Upholstery Gewicht Weight
54261) Motorhaube Sitz Gewicht External Upholstery Sitz Seat ## S.Nr. =51492 S.No.; =51492
54261) Motorhaube Sitz Gewicht External Upholstery Sitz Seat ## S.Nr. =51493 S.No.; =51493
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Rahmen) Cabin (Body)
4 (S N 50006-54261) Kabine Cabin Kabine (Tuer) Cabin (Door) ## S.Nr. =54079 S.No.; =54079 S.No. =
4 (S N 50006-54261) Kabine Cabin Kabine (Tuer) Cabin (Door) ## S.Nr. =54080 S.No.; =54080 S.No. =
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Fenster) Cabin (Window)
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Deckel Und Trimm) Cabin (Cover And Trim)
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Futter) Cabin (Lining)
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Gummiabdichtung) Cabin (Seal Rubber)
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Rueckspiegel) Cabin (Rearview Mirror)
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Scheibenwischermotor) Cabin (Wiper
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Kabelgeschirr) Cabin (Electrical Wiring)
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Heizkoerper) Cabin (Heater)
U48-4 (S N 50006-54261) Kabine Cabin Kabine (Klimaanlage) Cabin (Air Conditioner)
U48-4 (S N 50006-54261) Aufkleber Labels Aufkleber Label
U48-4 (S N 50006-54261) Zubehoer Accessories Zubehoer Accessories
U48-4 (S N 50006-54261) Option Option Kit Steinschlagschutz [Option] Kit Gravel Guard [
U48-4 (S N 50006-54261) Option Option Kit Rundumleuchte Kit Rotating Beacon
U48-4 (S N 50006-54261) Option Option Loeffel, Schnellkupplung (Kbd) Bucket, Quick-
U48-4 (S N 50006-54261) Option Option Kit Steckkupplung Kit Plug-In Coupler
U48-4 (S N 50006-54261) Option Option Kit Kupplung (Flachdichtend) Kit Flat-Face Coupler
U48-4 (S N 50006-54261) Option Option Kit Schraubkupplung Kit Screw-Type Coupler
Option Option Rohrbruchsicherung(Ausleger) Pipe-Break Valve Boom ## S.Nr. =55685 S.
Option Option Rohrbruchsicherung(Ausleger) Pipe-Break Valve Boom ## S.Nr. =55686 S.
U48-4 (S N 50006-54261) Option Option Rohrbruchsicherung(Arm) Pipe-Break Valve
Option Option Rohrbruchsicherung(Erdschieber) Pipe-Break Valve Dozer ## S.Nr. =55685 S.
Option Option Rohrbruchsicherung(Erdschieber) Pipe-Break Valve Dozer ## S.Nr. =55686 S.
U48-4 (S N 50006-54261) Option Option Gap-Kit (Kuk) Gap-Kit (Kuk)
U48-4 (S N 50006-54261) Option Option Kit Tiltmotor Kit Tiltmotor
U48-4 (S N 50006-54261) Option Option Greifer Kit Clamshell Kit
U48-4 (S N 50006-54261) Option Option Greifer-Kit Clamshell Kit
U48-4 (S N 50006-54261) Option Option Kit Schnellwechsler Hydraulisch Kit Quick Coupler
U48-4 (S N 50006-54261) Option Option Schnellkupplung (Einzelteile)(Kbd) Quick-Coupler (
U48-4 (S N 50006-54261) Option Option Anbauplatten - Km205 Mounting Brackets - Km205
U48-4 (S N 50006-54261) Option Option Kit Hydraulikhammer Kit Hydraulic Breaker
4 (S N 50006-54261) Option Option Kit Powertilt (Schnellwechsler Hydr.) Kit Powertilt (Quick
4 (S N 50006-54261) Option Option Kit Powertilt (Schnellwechsler Mech.) Kit Powertilt (Quick
U48-4 (S N 50006-54261) Option Option Anbauplatten - Km305 Mounting Brackets - Km305
U48-4 (S N 50006-54261) Option Option Löffel (Ohne Schnellkupplung) Bucket (No Quick-
U48-4 (S N 50006-54261) Option Option Löffel, Schnellkupplung Bucket, Quick-Coupler
U48-4 (S N 50006-54261) Option Option Kit Summer Kit Buzzer,Travel
