Kubota Excavator U45-3 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota U45-3 Excavator
Region: Australia
Number of Pages: 329 Pages
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover ## [V2203-M-Ebh-2(3)_S.No.;_=3z9999]
Engine _ Head Cover ## [V2203-M-Ebh-2(3)_S.No.;_=4a0001]
Engine _ Engine Bracket
Engine _ Main Bearing Case ## S.No._=3t9999
Engine _ Main Bearing Case ## S.No._=3u0001
Engine _ Piston And Crankshaft ## S.No._=3t9999
Engine _ Piston And Crankshaft ## S.No._=3u0001
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Engine Stop Lever
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Alternator
Engine _ Alternator (Component Parts) [Except A_C]
Engine _ Alternator (Component Parts) [A_C]
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Water Pump
Engine _ Radiator
Engine _ Water Pipe
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold ## [V2203-M-Ebh-2(3)_S.No.;_=3z9999]
Engine _ Inlet Manifold ## [V2203-M-Ebh-2(3)_S.No.;_=4a0001]
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Gasket Kit
Engine _ Gasket Kit
Fuel System _ Auto Idle Motor
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Timer And Horn
Electrical System _ Switch And Meter
Electrical System _ Light
Electrical System _ Electrical Wiring [Except A_C]
Electrical System _ Electrical Wiring [A_C]
Pump_Motor System _ Pump Housing
Pump_Motor System _ Piston Pump Component Parts
Pump_Motor System _ Drive Motor And Component Parts
Pump_Motor System _ Swivel Motor And Component Parts
Pump_Motor System _ Rotary Joint
Pump_Motor System _ Oil Tank
Control Valve _ Control Valve
Control Valve _ Control Valve (Component Parts)
Control Valve _ Spool Section (Inlet)
Control Valve _ Spool Section (Swivel)
Control Valve _ Spool Section (Travel Lh)
Control Valve _ Spool Section (Travel Rh)
Control Valve _ Spool Section (Blade)
Control Valve _ Spool Section (Arm)
Control Valve _ Spool Section (Boom)
Control Valve _ Spool Section (Bucket)
Control Valve _ Spool Section (Swing)
Control Valve _ Spool Section (S_P)
Control Valve _ Change Valve
Control Valve _ Change Valve (Component Parts)
Control Valve _ TPSS Valve
Control Valve _ TPSS Valve (Component Parts)
Control Lever _ Control Lever (Lever Lh)
Control Lever _ Pilot Valve (Component Parts)
Control Lever _ Control Lever (Lever Rh)
Control Lever _ Control Lever (Travel Lh 1)
Control Lever _ Control Lever (Travel Lh 2)
Control Lever _ Control Lever (Travel Rh 1)
Control Lever _ Control Lever (Travel Rh 2)
Control Lever _ Control Lever (Travel Lock)
Control Lever _ Control Travel Pedal
Control Lever _ Control Lever (Safety Lock Lever)
Control Lever _ Control Pedal (Swivel_Swing Change 1)
Control Lever _ Control Pedal (Swivel_Swing Change 2)
Control Lever _ TPSS Lever
Control Lever _ Control Lever (Blade)
Control Lever _ Control Lever (S_P)
Oil Piping _ Oil Piping (Suction)
Oil Piping _ Oil Piping (Delivery)
Oil Piping _ Oil Piping (Return)
Oil Piping _ Oil Piping (Oil Cooler)
Oil Piping _ Oil Piping (Control Lh)
Oil Piping _ Oil Piping (Control Rh)
Oil Piping _ Oil Piping (Travel Lh)
Oil Piping _ Oil Piping (Travel Rh)
Oil Piping _ Oil Piping (Swivel)
Oil Piping _ Oil Piping (Swing)
Oil Piping _ Oil Piping (Boom)
Oil Piping _ Oil Piping (Arm)
Oil Piping _ Oil Piping (Bucket)
Oil Piping _ Oil Piping (Blade)
Oil Piping _ Oil Piping (Clamp)
Oil Piping _ Oil Piping (S_P)
Cylinder _ Boom Cylinder And Component Parts
Cylinder _ Arm Cylinder And Component Parts
Cylinder _ Bucket Cylinder And Component Parts
Cylinder _ Blade Cylinder And Component Parts
Cylinder _ Swing Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Arch Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support [Except A_C]
Swivel Frame _ Seat Support [A_C]
Swivel Frame _ Step [Except A_C]
Swivel Frame _ Step [A_C]
Swivel Frame _ Cover (Lh)
Swivel Frame _ Cover (Rh)
Swivel Frame _ Bonnet Lh [Except A_C]
Swivel Frame _ Bonnet Lh [A_C]
Swivel Frame _ Bonnet Rh
Swivel Frame _ Bonnet Rear
Swivel Frame _ Sponge
Swivel Frame _ Weight
Swivel Frame _ Seat
Swivel Frame _ Seat (Component Parts)
Operator's Platform _ Canopy
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Door Lock)
Operator's Platform _ Cabin (Window)
Operator's Platform _ Cabin (Window Front)
Operator's Platform _ Cabin (Seal Rubber)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Heater) [Except A_C]
Operator's Platform _ Cabin (Heater) [A_C]
Operator's Platform _ Cabin (Defroster)
Operator's Platform _ Cabin (A_C 1) [A_C]
Operator's Platform _ Cabin (A_C 2) [A_C]
Operator's Platform _ Cabin (A_C 3) [A_C]
Operator's Platform _ Cabin (A_C 4) [A_C]
Labels _ Label
Accessories _ Accessories
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Flywheel
Engine _ Governor
Engine _ Alternator
Engine _ Starter
Engine _ Water Pump
Engine _ Radiator
Engine _ Water Pipe
Engine _ Muffler
Engine _ Gasket Kit
Engine _ Gasket Kit
Track Frame _ Idler
Swivel Frame _ Seat
Labels _ Label
