Kubota Excavator U36-4 Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota U36-4 Excavator
Number of Pages: 584 Pages
U36-4
U36-4 Frequently Used Items Frequently Used Items Frequently Used Items Frequently
U36-4 Motor Engine Kurbelghaeuse Crankcase
U36-4 Motor Engine Oelwanne Oil Pan
U36-4 Motor Engine Zylinderkopf Cylinder Head
Motor Engine Getriebe Gehaeuse Gear Case ## Note Order By Part No.1g171-5966-0 Note Order
U36-4 Motor Engine Deckel Oben Head Cover
U36-4 Motor Engine Oelfilter Oil Filter
U36-4 Motor Engine Einfuellsflansch Oil Filler Flange
U36-4 Motor Engine Motor Traeger Engine Bracket
U36-4 Motor Engine Hauptlagergehaeuse Main Bearing Case
U36-4 Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle Gear
U36-4 Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
U36-4 Motor Engine Schwungrad Flywheel
U36-4 Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And Governor
U36-4 Motor Engine Motorabstellhebel Engine Stop Lever
U36-4 Motor Engine Einspritzenpumpe Injection Pump
U36-4 Motor Engine Regler Governor
U36-4 Motor Engine Geschwindigkeits-Regler Platte Speed Control Plate
U36-4 Motor Engine Duesenhalter Gluehkerze Nozzle Holder And Glow Plug
U36-4 Motor Engine Wechselstrommaschine Alternator ## [Except A C] [Except A
U36-4 Motor Engine Wechselstrommaschine Alternator ## [A C] [A C]
U36-4 Motor Engine Lichtmaschine (Einzel-Teil) Alternator (Component Parts)
U36-4 Motor Engine Anlasser Starter
U36-4 Motor Engine Anlasser (Einzel-Teil) Starter (Component Parts)
U36-4 Motor Engine Wasserflansch Und Thermostat Water Flange And Thermostat
U36-4 Motor Engine Wasserpumpe Water Pump
U36-4 Motor Engine Spannscheibe Pulley,Tension
U36-4 Motor Engine Kuehler Radiator
U36-4 Motor Engine Wasserrohr Water Pipe And Reserve Tank
U36-4 Motor Engine Ventil Kipparmwelle Valve And Rocker Arm
U36-4 Motor Engine Einlasskruemmer Inlet Manifold
U36-4 Motor Engine Auspuffrummer Exhaust Manifold
U36-4 Motor Engine Luftfilter Air Cleaner
U36-4 Motor Engine Auspufftopf Muffler
U36-4 Motor Engine Dichtung-Geraet [Option] Upper Gasket Kit [Option]
U36-4 Motor Engine Dichtung-Geraet Lower Gasket Kit [Option]
U36-4 Brennstoff System Fuel System Kraftstoffleitungen Fuel Pump And Piping ## [Except
U36-4 Brennstoff System Fuel System Kraftstoffleitungen Fuel Pump And Piping ## [A
U36-4 Brennstoff System Fuel System Kraftstoffilter (Einzel-Teil) Fuel Filter (Component
U36-4 Brennstoff System Fuel System Wasserabscheider (Einzel-Teil) Water Separator (
U36-4 Brennstoff System Fuel System Kraftstofftank Fuel Tank
U36-4 Elektrisch System Electrical System Batterie Battery
U36-4 Elektrisch System Electrical System Zeitzeichengeber, Hupe Timer And Horn
U36-4 Elektrisch System Electrical System Schalter, Zaehler Switch And Meter
U36-4 Elektrisch System Electrical System Lampe Light
U36-4 Elektrisch System Electrical System Elektrische Ausrustung Electrical
U36-4 Elektrisch System Electrical System Diebstahlwarnanlage Anti-Theft Alarm
U36-4 Pumpe Motor System Pump Motor System Pumpengehaeuse Pump Housing
U36-4 Pumpe Motor System Pump Motor System Kolbenpumpe Und Einzel-Teil Piston
Motor System Pump Motor System Kolbenpumpe (Einzel-Teil) Piston Pump (Component Parts)
Pumpe Motor System Pump Motor System Kolbenpumpe (Einzel-Teil) Piston Pump (Component
U36-4 Pumpe Motor System Pump Motor System Motor Drive Moter
U36-4 Pumpe Motor System Pump Motor System Motor (Einzel-Teil) Drive Motor (Component
U36-4 Pumpe Motor System Pump Motor System Schwingungmotor Und Einzel-Teil Swivel
4 Pumpe Motor System Pump Motor System Schwingungmotor (Einzel-Teil) Swivel Motor (
U36-4 Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary Joint
4 Pumpe Motor System Pump Motor System Drehgelenkstueck (Einzel-Teil) Rotary Joint (
U36-4 Pumpe Motor System Pump Motor System Oeltank Oil Tank (1)
U36-4 Pumpe Motor System Pump Motor System Oeltank (2) Oil Tank (2)
U36-4 Pumpe Motor System Pump Motor System Ölfilter Oil Filter
U36-4 Regelungsventil Control Valve Regelungsventil (1) Control Valve (1) ## [Aux1]
U36-4 Regelungsventil Control Valve Regelungsventil (2) Control Valve (2) ## [Aux1&2]
U36-4 Regelungsventil Control Valve Regelungsventil Control Valve
Regelungsventil Control Valve Regelungsventil (Einzel-Teile) Control Valve (Component
U36-4 Regelungsventil Control Valve Spulensektion (Kuebel) Spool Section (Bucket)
U36-4 Regelungsventil Control Valve Spulensektion (Ausleger) Spool Section (
U36-4 Regelungsventil Control Valve Spulensektion (Fahren Rs) Spool Section (Travel
U36-4 Regelungsventil Control Valve Spulensektion (Abstandshalter) Spool Section
U36-4 Regelungsventil Control Valve Spulensektion (Fahren Ls) Spool Section (Travel
U36-4 Regelungsventil Control Valve Spulensektion (Arm) Spool Section (Arm)
U36-4 Regelungsventil Control Valve Spulensektion (Ax1) Spool Section (Ax1)
U36-4 Regelungsventil Control Valve Spulensektion (Blei) Spool Section (Lead)
U36-4 Regelungsventil Control Valve Spulensektion (Planierschild) Spool Section (
U36-4 Regelungsventil Control Valve Spulensektion (Schwung) Spool Section (
U36-4 Regelungsventil Control Valve Spulensektion (Drehen) Spool Section (Swivel)
U36-4 Regelungsventil Control Valve Spulensektion (Ausleger2) Spool Section (Boom2) ##
U36-4 Regelungsventil Control Valve Spulensektion (Ausleger2) Spool Section (Boom2) ## [
U36-4 Regelungsventil Control Valve Spulensektion (Ax2) Spool Section (Ax2) ## [Aux1&
U36-4 Regelungsventil Control Valve Spulensektion (Ausfluss) Spool Section (
U36-4 Regelungsventil Control Valve Entladerventil Unload Valve
U36-4 Regelungsventil Control Valve Entladerventil (Einzel-Teil) Unload Valve (Component
U36-4 Regelungsventil Control Valve Magnetischventil Magnetic Valve ## [Aux1] [
U36-4 Regelungsventil Control Valve Magnetischventil Magnetic Valve ## [Aux1&2]
Regelungsventil Control Valve Magnetischventil (Enzel-Teil) Magnetic Valve (Component
U36-4 Regelungsventil Control Valve Zylinderspulenventil Solenoid Valve ## [A C]
Regelungsventil Control Valve Zylinderspulenventil (Einzel-Teil) Solenoid Valve (Component
U36-4 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Ls) Control Lever (Lever
Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve Lh (Component
U36-4 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Rs) Control Lever (Lever
U36-4 Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Rh) (Component
U36-4 Kontrollrahmen Control Lever Kontrollhebel (Fahren) Control Lever (Travel)
U36-4 Kontrollrahmen Control Lever Vordusenventil(Fahren) Pilot Valve (Travel)
Kontrollrahmen Control Lever Vordusenventil (Fahren) (Enzel-Teil) Pilot Valve (Travel) (
U36-4 Kontrollrahmen Control Lever Schwungpedal Swing Pedal
4 Kontrollrahmen Control Lever Kontrollrahmen (Hebel Von Schloss) Control Lever (
U36-4 Kontrollrahmen Control Lever Kontrollrahmen (Erdschieber) Control Lever
U36-4 Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (Suction)
U36-4 Oelleitungen Oil Piping Oel Leitung (Befreitung) Oil Piping (Delivery)
U36-4 Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return)
U36-4 Oelleitungen Oil Piping Oel Leitung (Oelkuehler) Oil Piping (Oil Cooler)
U36-4 Oelleitungen Oil Piping Oel Leitung (Kontroll Ls) Oil Piping (Control Lh)
U36-4 Oelleitungen Oil Piping Oel Leitung (Kontroll Rs) Oil Piping (Control Rh)
U36-4 Oelleitungen Oil Piping Oel Leitung (Pilot P) Oil Piping (Pilot P)
U36-4 Oelleitungen Oil Piping Oel Leitung (Pilot T) Oil Piping (Pilot T)
U36-4 Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel Lh)
U36-4 Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel Rh)
U36-4 Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
U36-4 Oelleitungen Oil Piping Oel Leitung (Schwung) Oil Piping (Swing)
U36-4 Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
U36-4 Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
U36-4 Oelleitungen Oil Piping Oel Leitung (Kuebel) Oil Piping (Bucket)
U36-4 Oelleitungen Oil Piping Oel Leitung (Erdschieber) Oil Piping (Blade)
U36-4 Oelleitungen Oil Piping Oel Leitung (Klammer) Oil Piping (Clamp)
U36-4 Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P)
U36-4 Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P) ## [Aux2] [Aux2]
U36-4 Oelleitungen Oil Piping Oel Leitung (Dritte Ruecklaufleitung) Oil Piping (Third Line
U36-4 Zylinder Cylinder Auslegerzylinder Boom Cylinder
U36-4 Zylinder Cylinder Armzylinder Arm Cylinder
U36-4 Zylinder Cylinder Kuebelzylinder Bucket Cylinder
U36-4 Zylinder Cylinder Erdschieberzylinder Blade Cylinder
U36-4 Zylinder Cylinder Schwenkzylinder Swing Cylinder
U36-4 Anhaften Von Stirn Front Attachments Lagerung Ausleger Swing Bracket
U36-4 Anhaften Von Stirn Front Attachments Ausleger Boom
U36-4 Anhaften Von Stirn Front Attachments Abdeckung (Ausleger) Cylinder Cover
U36-4 Anhaften Von Stirn Front Attachments Arm Arm
U36-4 Anhaften Von Stirn Front Attachments Kuebelverbindungestueck Bucket
U36-4 Anhaften Von Stirn Front Attachments Erdschieber Blade
U36-4 Spurrahmen Track Frame Spurrahmen Track Frame
U36-4 Spurrahmen Track Frame Spannrad Idler
U36-4 Spurrahmen Track Frame Laufrollen Track Roller
U36-4 Spurrahmen Track Frame Laufketten Crawler
U36-4 Rahmen Von Drehen Swivel Frame Rahmen Von Drehen Swivel Frame ## [Canopy] [
U36-4 Rahmen Von Drehen Swivel Frame Rahmen Von Drehen Swivel Frame ## [Cabin] [
U36-4 Rahmen Von Drehen Swivel Frame Bogenrahmen Arch Frame ## [Except H T] [Except
U36-4 Rahmen Von Drehen Swivel Frame Bogenrahmen Arch Frame ## [H T] [H T]
U36-4 Rahmen Von Drehen Swivel Frame Lager, Drehen Swivel Bearing
U36-4 Rahmen Von Drehen Swivel Frame Sitz Traeger Seat Support
U36-4 Rahmen Von Drehen Swivel Frame Tritt Step ## [Canopy] [Canopy]
U36-4 Rahmen Von Drehen Swivel Frame Tritt Step ## [Cabin] [Cabin]
U36-4 Aubere Bauteile Polsterung External Upholstery Deckel (Ls) Cover (Lh)
U36-4 Aubere Bauteile Polsterung External Upholstery Deckel (Rs) Cover (Rh) ## [Canopy]
U36-4 Aubere Bauteile Polsterung External Upholstery Deckel (Rs) Cover (Rh) ## [Cabin]
U36-4 Aubere Bauteile Polsterung External Upholstery Motorhaube (Ls) Bonnet (
U36-4 Aubere Bauteile Polsterung External Upholstery Motorhaube (Rs) Bonnet (
U36-4 Aubere Bauteile Polsterung External Upholstery Motorhaube Hintere Bonnet
U36-4 Aubere Bauteile Polsterung External Upholstery Motorhaube (Zentrum) Bonnet
U36-4 Aubere Bauteile Polsterung External Upholstery Schaumgummi Sponge
U36-4 Aubere Bauteile Polsterung External Upholstery Gewicht Weight
U36-4 Aubere Bauteile Polsterung External Upholstery Sitz Seat ## [Canopy] [
U36-4 Aubere Bauteile Polsterung External Upholstery Sitz Seat ## [Cabin] [Cabin]
U36-4 Buhne Von Fahrer Operator's Platform Kabinenhaube Canopy
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Koerper) Cabin (Body)
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Tuer) Cabin (Door)
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Fenster) Cabin (Window)
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Fenster Vorder) Cabin (Window
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Schaumgummi) Cabin (Cover And
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Futter) Cabin (Lining)
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Gummiabdichtung) Cabin (Seal
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Rueckspiegel) Cabin (Rearview
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Scheibenwischermotor) Cabin (Wiper
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Kabelgeschirr) Cabin (Electrical
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Heizkoerper) Cabin (Heater)
U36-4 Buhne Von Fahrer Operator's Platform Kabine (Klimaanlage) Cabin (Air Conditioner
U36-4 Kabinenhaube Canopy Kabinenhaube (Lampe) Canopy (Light)
U36-4 Aufkleber Labels Aufkleber Label
U36-4 Sontiges Zubehoer Und Service-Teile Accessories Sontiges Zubehoer Accessories
U36-4 Option Option Kit Steinschlagschutz [Option] Kit Gravel Guard [Option] ## [Canopy]
U36-4 Option Option Kit Steinschlagschutz [Option] Kit Gravel Guard [Option] ## [Cabin]
U36-4 Option Option Kit Steinschlagschutz 4 [Option] Kit Gravel Guard 4 [Option]
U36-4 Option Option Rohrbruchsicherung(Ausleger) Pipe-Break Valve Boom
U36-4 Option Option Rohrbruchsicherung(Arm) Pipe-Break Valve Arm
U36-4 Option Option Rohrbruchsicherung(Erdschieber) Pipe-Break Valve Dozer
U36-4 Option Option Kit Steckkupplung Kit Plug-In Coupler
U36-4 Option Option Kit Kupplung (Flachdichtend) Kit Flat-Face Coupler
U36-4 Option Option Kit Schraubkupplung Kit Screw-Type Coupler
U36-4 Option Option Kit Rundumleuchte Kit Rotating Beacon
U36-4 Option Option Kit Rundumleuchte (Haube) Kit Rotating Beacon (Canopy)
U36-4 Option Option Kit Key Kit Schluessel
U36-4 Option Option Löffel, Schnellkupplung Bucket, Quick-Coupler
U36-4 Option Option Kit Greifer Kit Clamshell
U36-4 Option Option Anbauplatten - Km205 Mounting Brackets - Km205
U36-4 Option Option Zubehoer Hydraulikhammer Accessory Hydraulic Breaker
U36-4 Option Option Kit Summer Kit Buzzer,Travel
U36-4 Option Option Schnellwechsler Hydraulisch Quick Coupler Hydraulic
U36-4 Option Option Kit Schnellwechsler Hydraulisch Kit Quick Coupler Hydraulic
U36-4 Option Option Powertilt (Schnellwechsler Hydr.) Powertilt (Quick Coupler
U36-4 Option Option Kit Powertilt Pts050(Schnellwechsler Hydr.) Kit Powertilt Pts050(Quick
U36-4 Option Option Powertilt (Schnellwechsler Mech.) (Quick Coupler Mech.)
U36-4 Option Option Kit Powertilt Pts050(Schnellwechsler Mech.) Kit Powertilt Pts050(Quick
U36-4
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
