Kubota Excavator U35-4 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota U35-4 Excavator
Region: Australia
Number of Pages: 424 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crankcase ## [Except A_C]
Engine _ Crankcase ## [A_C]
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter ## [Except A_C]
Engine _ Oil Filter ## [A_C]
Engine _ Oil Filler Flange
Engine _ Engine Bracket
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Engine Stop Lever
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Alternator ## [Except A_C]
Engine _ Alternator ## [A_C]
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Water Pump ## S.No._=7fdz999 S.No.;_=7fdz999
Engine _ Water Pump ## S.No._=7fe0001 S.No.;_=7fe0001
Engine _ Pulley,Tension
Engine _ Radiator
Engine _ Water Pipe And Reserve Tank ## [Except A_C]
Engine _ Water Pipe And Reserve Tank ## [A_C]
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler ## S.No._=11447 S.No.;_=11447
Engine _ Muffler ## S.No._=11448 S.No.;_=11448
Engine _ Oil Cooler ## [A_C]
Engine _ Upper Gasket Kit [Option]
Engine _ Lower Gasket Kit [Option]
Fuel System _ Auto Idle Motor
Fuel System _ Fuel Pump And Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Water Separator (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Travel Alarm And Horn
Electrical System _ Switch And Meter
Electrical System _ Light
Electrical System _ Anti-Theft Alarm System
Pump_Motor System _ Pump Housing
Pump_Motor System _ Piston Pump
Pump_Motor System _ Piston Pump (Component Parts) ## [Canopy]
Pump_Motor System _ Piston Pump (Component Parts) ## [Cabin]
Pump_Motor System _ Drive Motor
Pump_Motor System _ Drive Motor (Component Parts 1)
Pump_Motor System _ Drive Motor (Component Parts 2)
Pump_Motor System _ Drive Motor (Component Parts 3)
Pump_Motor System _ Swivel Motor
Pump_Motor System _ Swivel Motor (Component Parts 1)
Pump_Motor System _ Swivel Motor (Component Parts 2)
Pump_Motor System _ Rotary Joint
Pump_Motor System _ Rotary Joint (Component Parts)
Pump_Motor System _ Oil Tank (1)
Pump_Motor System _ Oil Tank (2)
Pump_Motor System _ Oil Filter
Control Valve _ Control Valve (1)
Control Valve _ Control Valve (2)
Control Valve _ Control Valve (Component Parts)
Control Valve _ Spool Section (Swivel)
Control Valve _ Spool Section (Swing)
Control Valve _ Spool Section (Blade)
Control Valve _ Spool Section (Travel Straight)
Control Valve _ Spool Section (S_P)
Control Valve _ Spool Section (Arm)
Control Valve _ Spool Section (Travel Lh)
Control Valve _ Spool Section (Travel Rh)
Control Valve _ Spool Section (Boom)
Control Valve _ Spool Section (Boom Lock)
Control Valve _ Spool Section (Bucket)
Control Valve _ Unload Valve
Control Valve _ Unload Valve (Component Parts)
Control Valve _ Magnetic Valve
Control Valve _ Magnetic Valve (Component Parts)
Control Valve _ Solenoid Valve ## [Cabin]
Control Valve _ Solenoid Valve (Component Parts) ## [Cabin]
Control Valve _ TPSS Valve
Control Lever _ Control Lever (Lever Lh)
Control Lever _ Pilot Valve (Lh) (Component Parts)
Control Lever _ Control Lever (Lever Rh)
Control Lever _ Pilot Valve (Rh) (Component Parts)
Control Lever _ Control Lever (Travel)
Control Lever _ Pilot Valve (Travel)
Control Lever _ Pilot Valve (Travel) (Component Parts)
Control Lever _ Swing Pedal
Control Lever _ Control Lever (Safety Lock Lever)
Control Lever _ TPSS Lever
Control Lever _ Control Lever (Blade)
Oil Piping _ Oil Piping (Suction)
Oil Piping _ Oil Piping (Delivery)
Oil Piping _ Oil Piping (Return)
Oil Piping _ Oil Piping (Oil Cooler)
Oil Piping _ Oil Piping (Control Lh)
Oil Piping _ Oil Piping (Control Rh)
Oil Piping _ Oil Piping (Pilot P)
Oil Piping _ Oil Piping (Pilot T)
Oil Piping _ Oil Piping (Travel Lh)
Oil Piping _ Oil Piping (Travel Rh)
Oil Piping _ Oil Piping (Swivel)
Oil Piping _ Oil Piping (Swing)
Oil Piping _ Oil Piping (Boom)
Oil Piping _ Oil Piping (Arm)
Oil Piping _ Oil Piping (Bucket)
Oil Piping _ Oil Piping (Blade)
Oil Piping _ Oil Piping (Clamp 1)
Oil Piping _ Oil Piping (Clamp 2)
Oil Piping _ Oil Piping (S_P)
Oil Piping _ Oil Piping (Third Line Hydraulic Return)
Cylinder _ Boom Cylinder
Cylinder _ Arm Cylinder
Cylinder _ Bucket Cylinder
Cylinder _ Blade Cylinder
Cylinder _ Swing Cylinder
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade ## Note _ Order By Ref.No.080,090,100 New Parts & 110 Set
Track Frame _ Track Frame ## Note _ Order By Ref.No.010 New Part And Fig.No.G50000 Ref.No
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame ## [Canopy]
Swivel Frame _ Swivel Frame ## [Cabin]
Swivel Frame _ Arch Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step ## [Canopy]
Swivel Frame _ Step ## [Cabin]
External_Upholstery _ Cover (Lh)
External_Upholstery _ Cover (Rh) ## [Canopy]Note_Order By Ref.No.010 & Ref.No
External_Upholstery _ Cover (Rh) ## [Cabin]Note_Order By Ref.No.010 & Ref.No
External_Upholstery _ Bonnet (Lh)
External_Upholstery _ Bonnet (Rh)
External_Upholstery _ Bonnet (Rear)
External_Upholstery _ Bonnet (Center)
External_Upholstery _ Sponge (1)
External_Upholstery _ Sponge (2)
External_Upholstery _ Weight
External_Upholstery _ Seat ## [Canopy]
External_Upholstery _ Seat ## [Cabin]
Operator's Platform _ Canopy
Operator's Platform _ Canopy (Light)
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Cover And Trim)
Operator's Platform _ Cabin (Lining)
Operator's Platform _ Cabin (Seal Rubber)
Operator's Platform _ Cabin (Rear View Mirror)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Heater)
Operator's Platform _ Cabin (Air Conditioner 1)
Operator's Platform _ Cabin (Air Conditioner 2) ## S.No._=16402 Note_Order By Fig.No
Operator's Platform _ Cabin (Air Conditioner 2) ## S.No._=16403 S.No.;_=16403
Operator's Platform _ Cabin (Air Conditioner 3)
Labels _ Label
Accessories _ Accessories
