Kubota Excavator U27-4 HI Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota U27-4 HI Excavator
Number of Pages: 469 Pages
U27-4 Hi
U27-4 Hi Motor Engine Kurbelghaeuse Crankcase
U27-4 Hi Motor Engine Ol-Fanger Oil Pan
U27-4 Hi Motor Engine Zylinderkopf Cylinder Head
U27-4 Hi Motor Engine Getriebegehaeuse Gear Case
U27-4 Hi Motor Engine Zylinderkopf-Deckel Head Cover
U27-4 Hi Motor Engine Motor Traeger Engine Bracket
U27-4 Hi Motor Engine Hauptlagergehäuse Main Bearing Case
U27-4 Hi Motor Engine Nockenwelle Und Welle,Freilaufgetr Camshaft And Idle Gear
U27-4 Hi Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
U27-4 Hi Motor Engine Schwungrad Flywheel
U27-4 Hi Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And Governor
U27-4 Hi Motor Engine Stop Solenoid Stop Solenoid
U27-4 Hi Motor Engine Einspritzpumpe Injection Pump
U27-4 Hi Motor Engine Zylinderkopf Governor
U27-4 Hi Motor Engine Geschwindigkeitskontrolle Nockenhohn Speed Control
U27-4 Hi Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow Plug
U27-4 Hi Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder (Component Parts)
U27-4 Hi Motor Engine Wechselstrommaschine Alternator
U27-4 Hi Motor Engine Lichtmaschine (Einzel-Teil) Alternator (Component Parts)
U27-4 Hi Motor Engine Anlasser Starter
U27-4 Hi Motor Engine Anlsser (Einzel-Teil) Starter (Component Parts)
U27-4 Hi Motor Engine Kuehlwasserflansch Water Flange And Thermostat
U27-4 Hi Motor Engine Wasserpumpe Water Pump
U27-4 Hi Motor Engine Spannscheibe Tension Pulley
U27-4 Hi Motor Engine Kuehler Radiator
U27-4 Hi Motor Engine Wasserrohr Water Pipe And Reserve Tank
U27-4 Hi Motor Engine Kipphebel Und Ventile Valve And Rocker Arm
U27-4 Hi Motor Engine Ansaugrohr Inlet Manifold
U27-4 Hi Motor Engine Auspuffrummer Exhaust Manifold
U27-4 Hi Motor Engine Luftreinheit Air Cleaner
U27-4 Hi Motor Engine Auspuff Muffler
U27-4 Hi Motor Engine Juego De Juntas Superior Upper Gasket Kit
U27-4 Hi Motor Engine Niederdichtungentasche Lower Gasket Kit
U27-4 Hi Brennstoff System Fuel System Beschleunigerhebel Accelerator Lever
U27-4 Hi Brennstoff System Fuel System Kraftstoffleitungen Fuel Pump And Piping
U27-4 Hi Brennstoff System Fuel System Kraftstoffilter (Einzel-Teil) Fuel Filter (Component
U27-4 Hi Brennstoff System Fuel System Trennstueck (Einzel-Teil) Separator (Component
U27-4 Hi Brennstoff System Fuel System Kraftstofftank Fuel Tank
U27-4 Hi Elektrisch System Electrical System Batterie Battery
U27-4 Hi Elektrisch System Electrical System Fahren Alarm Travel Alarm
U27-4 Hi Elektrisch System Electrical System Schalter, Zaehler Switch And Meter
U27-4 Hi Elektrisch System Electrical System Lampe Light
U27-4 Hi Elektrisch System Electrical System Elektrische Ausrustung Wire Harness
U27-4 Hi Elektrisch System Electrical System Elektrische Ausrustung Electrical
U27-4 Hi Pumpe Motor System Pump Motor System Pumpengehaeuse Housing Pump
4 Hi Pumpe Motor System Pump Motor System Kolbenpumpe Und Einzel-Teil Piston Pump And
U27-4 Hi Pumpe Motor System Pump Motor System Motor Drive Moter
Pumpe Motor System Pump Motor System Schwingungmotor Und Einzel-Teil Swivel Motor
U27-4 Hi Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary Joint
4 Hi Pumpe Motor System Pump Motor System Drehgelenkstueck (Einzel-Teil) Rotary Joint (
U27-4 Hi Pumpe Motor System Pump Motor System Oeltank Oil Tank
U27-4 Hi Regelungsventil Control Valve Kontrollventil (1) Control Valve (1)
U27-4 Hi Regelungsventil Control Valve Kontrollventil (2) Control Valve (2)
U27-4 Hi Regelungsventil Control Valve Spulensektion (Ausleger Schwenken) Section (
U27-4 Hi Regelungsventil Control Valve Spulensektion (Planierschild) Section (
U27-4 Hi Regelungsventil Control Valve Spulensektion (Drehen) Section (Swivel)
U27-4 Hi Regelungsventil Control Valve Spulensektion (Zusammenfluss) Section (
U27-4 Hi Regelungsventil Control Valve Spulensektion (Zusatzkreis) Section (Aux)
U27-4 Hi Regelungsventil Control Valve Spulensektion (Loeffelstiel) Section (
U27-4 Hi Regelungsventil Control Valve Spulensektion (Fahren L) Section (Travel,
U27-4 Hi Regelungsventil Control Valve Spulensektion (Einlass) Section (Inlet)
U27-4 Hi Regelungsventil Control Valve Spulensektion (Fahren R) Section (Travel,
U27-4 Hi Regelungsventil Control Valve Spulensektion (Ausleger) Section (Boom)
U27-4 Hi Regelungsventil Control Valve Spulensektion (Schaufel) Section (Bucket)
U27-4 Hi Regelungsventil Control Valve Entladerventil Unload Valve
U27-4 Hi Regelungsventil Control Valve Entladerventil (Einzel-Teil) Unload Valve (Component
U27-4 Hi Kontrollrahmen Control Lever Kontrollrahmen (Rahmen, Kontroll) Control
U27-4 Hi Kontrollrahmen Control Lever Kontrollrahmen (Hebel Ls) Control Lever (
U27-4 Hi Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Lh) (
U27-4 Hi Kontrollrahmen Control Lever Kontrollrahmen (Hebel Rs) Control Lever (
U27-4 Hi Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (Rh) (
U27-4 Hi Kontrollrahmen Control Lever Kontrollrahmen (Fahren Ls) Control Lever (
4 Hi Kontrollrahmen Control Lever Kontrollrahmen (Hebel Von Schloss) Control Lever (
U27-4 Hi Kontrollrahmen Control Lever Kontrollrahmen (Erdschieber) Control Lever
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (Suction)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Befreitung) Oil Piping (Delivery)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Oelkuehler) Oil Piping (Oil Cooler)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Kontroll Ls) Oil Piping (Control Lh)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Kontroll Rs) Oil Piping (Control Rh)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel Lh)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel Rh)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Schwung) Oil Piping (Swing)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Kuebel) Oil Piping (Bucket)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Erdschieber) Oil Piping (Blade)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Klammer) Oil Piping (Clamp)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (S P1) Oil Piping (S P1)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (S P2) Oil Piping (S P2)
U27-4 Hi Oelleitungen Oil Piping Oel Leitung (Dritte Ruecklaufleitung) Oil Piping (Third Line
U27-4 Hi Zylinder Cylinder Auslegerzylinder Boom Cylinder
U27-4 Hi Zylinder Cylinder Armzylinder Arm Cylinder
U27-4 Hi Zylinder Cylinder Kuebelzylinder Bucket Cylinder
U27-4 Hi Zylinder Cylinder Erdschieberzylinder Blade Cylinder
U27-4 Hi Zylinder Cylinder Schwenkzylinder Swing Cylinder
U27-4 Hi Anhaften Von Stirn Front Attachments Lagerung Ausleger Swing Bracket
U27-4 Hi Anhaften Von Stirn Front Attachments Ausleger Boom
U27-4 Hi Anhaften Von Stirn Front Attachments Abdeckung (Ausleger) Cylinder Cover
U27-4 Hi Anhaften Von Stirn Front Attachments Arm Arm
U27-4 Hi Anhaften Von Stirn Front Attachments Verbindungestueck, Kuebel Bucket
U27-4 Hi Anhaften Von Stirn Front Attachments Kuebel Bucket
U27-4 Hi Anhaften Von Stirn Front Attachments Erdschieber Blade
U27-4 Hi Spurrahmen Track Frame Spurrahmen Track Frame
U27-4 Hi Spurrahmen Track Frame Spannrad Idler
U27-4 Hi Spurrahmen Track Frame Laufrollen Track Roller
U27-4 Hi Spurrahmen Track Frame Laufketten Crawler
U27-4 Hi Rahmen Von Drehen Swivel Frame Rahmen Von Drehen (1) Swivel Frame (1)
U27-4 Hi Rahmen Von Drehen Swivel Frame Rahmen Von Drehen (2) Swivel Frame (2)
U27-4 Hi Rahmen Von Drehen Swivel Frame Bogenrahmen Arch Frame
U27-4 Hi Rahmen Von Drehen Swivel Frame Lager, Drehen Swivel Bearing
U27-4 Hi Rahmen Von Drehen Swivel Frame Sitz Traeger Seat Support ## [Kabinenhaube]
U27-4 Hi Rahmen Von Drehen Swivel Frame Sitz Traeger Seat Support ## [Kabin] [
U27-4 Hi Rahmen Von Drehen Swivel Frame Tritt Step
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Deckel (Ls) Cover (Lh)
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Deckel (Rs) Cover (Rh)
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Deckel (Tank) Cover (
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Kuehlerhaube Bonnet (
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Motorhaube (Ls) Bonnet
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Motorhaube (Rs) Bonnet
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Motorhaube (Hinten) Bonnet
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Schaumgummi Sponge
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Schaumgummi 4 Sponge
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Gewicht Weight
U27-4 Hi Aubere Bauteile Polsterung External Upholstery Sitz Seat
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabinenhaube Canopy
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Koerper) Cabin (Body)
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Tuer) Cabin (Door)
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Fenster) Cabin (Window
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Fenster Vorder) Cabin (Window
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Schaumgummi) Cabin (Accessories
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Futter) Cabin (Accessories
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Gummiabdichtung) Cabin (Seal
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Kabelgeschirr) Cabin (Electrical
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine,Komp. Cab(Radio)
U27-4 Hi Buhne Von Fahrer Operator's Platform Kabine (Heizkoerper) Cabin (Heater)
U27-4 Hi Aufkleber Labels Aufkleber Label
U27-4 Hi Zubehoer Accessories Zubehoer Accessories
U27-4 Hi Option Option Rohrbruchsicherung(Ausleger) Pipe-Break Valve Boom
U27-4 Hi Option Option Rohrbruchsicherung(Arm) Pipe-Break Valve Arm
U27-4 Hi Option Option Rohrbruchsicherung(Erdschieber) Pipe-Break Valve Dozer
U27-4 Hi Option Option Kit Key Kit Schluessel
U27-4 Hi Option Option Kit Rundumleuchte Kit Rotating Beacon
U27-4 Hi Option Option Kit Fahrpedal Kit Travel Pedal
U27-4 Hi Option Option Kit Steinschlagschutz [Kabine] Kit Gravel Guard [Cabin]
U27-4 Hi Option Option Kit Black Box Kit Black Box
U27-4 Hi Option Option Löffel, Schnellkupplung (Kbd) Bucket, Quick-Coupler
U27-4 Hi Option Option Kit Steckkupplung Kit Plug-In Coupler
U27-4 Hi Option Option Kit Kupplung (Flachdichtend) Kit Flat-Face Coupler
U27-4 Hi Option Option Kit Schraubkupplung Kit Screw-Type Coupler
U27-4 Hi Option Option Kit Hydraulikhammer Kit Hydraulic Breaker
U27-4 Hi Option Option Kit Schnellwechsler Hydraulisch Kit Quick Coupler Hydraulic
U27-4 Hi Option Option Schnellkupplung (Kbd) Quick-Coupler
U27-4 Hi Option Option Kit Powertilt (Schnellwechsler Hydr.) Kit Powertilt (Quick Coupler
U27-4 Hi Option Option Powertilt (Schnellwechsler Hydr.) Powertilt (Quick Coupler
U27-4 Hi Option Option Kit Powertilt (Schnellwechsler Mech.) Kit Powertilt (Quick Coupler
U27-4 Hi Option Option Powertilt (Schnellwechsler Mech.) Powertilt (Quick Coupler
U27-4 Hi Option Option Löffel, Schnellkupplung Bucket, Quick-Coupler
