Kubota Excavator U27-4 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota U27-4 Excavator
Region: Australia
Number of Pages: 313 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Engine Bracket
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Nozzle Holder (Component Parts)
Engine _ Alternator
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Water Pump
Engine _ Tension Pulley
Engine _ Radiator
Engine _ Water Pipe And Reserve Tank
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Upper Gasket Kit
Engine _ Lower Gasket Kit
Fuel System _ Accelerator Lever
Fuel System _ Fuel Pump And Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Separator (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Travel Alarm
Electrical System _ Switch And Meter
Electrical System _ Lamp (1)
Electrical System _ Lamp (2)
Electrical System _ Wire Harness
Pump_Motor System _ Housing Pump
Pump_Motor System _ Piston Pump And Component Parts
Pump_Motor System _ Swivel Motor And Component Parts
Pump_Motor System _ Rotary Joint
Pump_Motor System _ Rotary Joint (Component Parts)
Pump_Motor System _ Oil Tank
Hydraulic System _ Drive Motor
Control Valve _ Control Valve (1)
Control Valve _ Control Valve (2)
Control Valve _ Section (Boom_Swing)
Control Valve _ Section (Dozer)
Control Valve _ Section (Swivel)
Control Valve _ Section (Confluence)
Control Valve _ Section (Aux)
Control Valve _ Section (Arm)
Control Valve _ Section (Travel,L)
Control Valve _ Section (Inlet)
Control Valve _ Section (Travel,R)
Control Valve _ Section (Boom)
Control Valve _ Section (Boom 2)
Control Valve _ Section (Bucket)
Control Valve _ Unload Valve
Control Valve _ Unload Valve (Component Parts)
Control Valve _ TPSS Valve
Control Valve _ TPSS Valve (Component Parts)
Control Lever _ Control Lever (Frame)
Control Lever _ Control Lever (Lever Lh)
Control Lever _ Pilot Valve (Lh) (Component Parts)
Control Lever _ Control Lever (Lever Rh)
Control Lever _ Pilot Valve (Rh) (Component Parts)
Control Lever _ Control Lever (Travel)
Control Lever _ Control Lever (Safety Lock Lever)
Control Lever _ Control Lever (Blade)
Oil Piping _ Oil Piping (Suction)
Oil Piping _ Oil Piping (Delivery)
Oil Piping _ Oil Piping (Return)
Oil Piping _ Oil Piping (Oil Cooler)
Oil Piping _ Oil Piping (Control Lh)
Oil Piping _ Oil Piping (Control Rh)
Oil Piping _ Oil Piping (Travel Lh)
Oil Piping _ Oil Piping (Travel Rh)
Oil Piping _ Oil Piping (Swivel)
Oil Piping _ Oil Piping (Swing)
Oil Piping _ Oil Piping (Boom)
Oil Piping _ Oil Piping (Arm)
Oil Piping _ Oil Piping (Bucket)
Oil Piping _ Oil Piping (Blade)
Oil Piping _ Oil Piping (Clamp)
Oil Piping _ Oil Piping (S_P1)
Oil Piping _ Oil Piping (S_P2)
Oil Piping _ Oil Piping (Third Line Hydraulic Return)
Cylinder _ Boom Cylinder
Cylinder _ Arm Cylinder
Cylinder _ Bucket Cylinder
Cylinder _ Blade Cylinder
Cylinder _ Swing Cylinder
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame (1)
Swivel Frame _ Swivel Frame (2)
Swivel Frame _ Arch Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step
External_Upholstery _ Cover (Lh)
External_Upholstery _ Cover (Rh)
External_Upholstery _ Cover(Tank)
External_Upholstery _ Bonnet (Front)
External_Upholstery _ Bonnet (Lh)
External_Upholstery _ Bonnet (Rh)
External_Upholstery _ Bonnet (Rear)
External_Upholstery _ Sponge 1
External_Upholstery _ Sponge 2
External_Upholstery _ Sponge 3
External_Upholstery _ Sponge 4
External_Upholstery _ Weight
External_Upholstery _ Seat
Operator's Platform _ Canopy
Labels _ Label
Accessories _ Accessories
Option _ S00a00 Pipe-Break Valve_Boom
Option _ S00b00 Pipe-Break Valve_Arm
Option _ S00c00 Kit Switch_Isolator
Option _ S00d00 Kit Switch_Isolator
Option _ S00e00 Kit Pedal
Option _ S00f00 Kit Black Box
Region: Australia
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Head Cover
Engine _ Flywheel
Engine _ Governor
Engine _ Alternator
Engine _ Starter
Engine _ Water Pump
Engine _ Radiator
Engine _ Muffler
Track Frame _ Idler
Swivel Frame _ Step
Labels _ Label
