Kubota Excavator U17-5 Spare Parts Catalog
Type of Machine: Excavator
Model: Kubota U17-5 Excavator
Number of Pages: 174 Pages
FREQUENTLY USED ITEMS
PAINT (SPOT COLOUR)
CRANKCASE
OIL PAN
CYLINDER HEAD
GEAR CASE
HEAD COVER
ENGINE BRACKET
MAIN BEARING CASE
CAMSHAFT AND IDLE GEAR SHAFT
PISTON AND CRANKSHAFT
FLYWHEEL
FUEL CAMSHAFT
STOP SOLENOID
INJECTION PUMP
GOVERNOR
SPEED CONTROL PLATE
NOZZLE HOLDER AND GLOW PLUG
NOZZLE HOLDER (COMPONENT PARTS)
ALTERNATOR
ALTERNATOR (COMPONENT PARTS)
STARTER
STARTER (COMPONENT PARTS)
WATER FLANGE AND THERMOSTAT
WATER PUMP
RADIATOR
WATER PIPE AND RESERVE TANK
VALVE AND ROCKER ARM
INLET MANIFOLD
EXHAUST MANIFOLD
AIR CLEANER
MUFFLER
MANUAL
UPPER GASKET KIT [OPTION]
LOWER GASKET KIT [OPTION]
OIL DRAIN HOSE
ACCELERATOR CABLE
FUEL TANK
FUEL PUMP AND PIPING
FUEL FILTER AND PIPING
SEPARATOR (COMPONENT PARTS)
AUTO IDLE MOTOR
BATTERY
HORN
ECU
SWITCH
METER
LAMP
WIRE HARNESS
WIRE HARNESS CLAMP
PUMP HOUSING
PISTON PUMP (COMPONENT PARTS)
DRIVE MOTOR
SWIVEL MOTOR
ROTARY JOINT
ROTARY JOINT (COMPONENT PARTS)
OIL TANK
OIL TANK (HYDRAULIC ADAPTER)
CONTROL VALVE
SPOOL SECTION (SWING)
SPOOL SECTION (DOZER)
SPOOL SECTION (SWIVEL)
SPOOL SECTION(CONFLUENCE)
SPOOL SECTION (AUX1)
SPOOL SECTION (ARM)
SPOOL SECTION (TRAVEL RH)
SPOOL SECTION (INLET)
SPOOL SECTION (TRAVEL LH)
SPOOL SECTION (BOOM)
SPOOL SECTION (ANTI DRIFT)
SPOOL SECTION (BUCKET)
CONTROL VALVE (HYD. ADAPTER) (SWINGDOZER)
CONTROL VALVE (HYD. ADAPTER) (SWIVELCONFLUENCE)
CONTROL VALVE (HYD. ADAPTER) (AUX1ARM)
CONTROL VALVE (HYD. ADAPTER) (TRAVEL RHINLET)
CONTROL VALVE (HYD. ADAPTER) (TRAVEL LHBOOM)
CONTROL VALVE (HYD. ADAPTER) (ANTI DRIFTBUCKET)
UNLOAD VALVE
UNLOAD VALVE (COMPONENT PARTS)
CHANGE VALVE
CHANGE VALVE (COMPONENT PARTS)
MAGNETIC SOLENOID VALVE
MAGNETIC SOLENOID VALVE (COMPONENT PARTS)
SELECT VALVE
SELECT VALVE (COMPONENT PARTS)
TPSS VALVE
TPSS VALVE (COMPONENT PARTS)
CONTROL LEVER (FRAME)
CONTROL LEVER (LEVER LH)
PILOT VALVE (COMPONENT PARTS)
CONTROL LEVER (LEVER RH)
WRIST REST
CONTROL LEVER (TRAVEL LH)
CONTROL LEVER (TRAVEL RH)
CONTROL PEDAL (SWING)
CONTROL LEVER (BLADE)
PEDAL (AUX)
OIL PIPING (SUCTION)
OIL PIPING (DELIVERY)
OIL PIPING (ACCUMULATOR)
OIL PIPING (RETURN)
OIL PIPING (OIL COOLER)
OIL PIPING (CONTROL LH)
OIL PIPING (CONTROL RH)
OIL PIPING (TRAVEL LH)
OIL PIPING (TRAVEL RH)
OIL PIPING (SWIVEL)
OIL PIPING (SWING)
OIL PIPING (BOOM)
OIL PIPING (ARM)
OIL PIPING (BUCKET)
OIL PIPING (BLADE)
OIL PIPING (TRACK)
OIL PIPING (SOLENOID)
OIL PIPING (CLAMP)
OIL PIPING (AUX)
BOOM CYLINDER
ARM CYLINDER
BUCKET CYLINDER
BLADE CYLINDER
SWING CYLINDER
TRACK CYLINDER
SWING BRACKET
BOOM
ARM
BUCKET LINK
BUCKET CONNECTION
BLADE
TRACK FRAME
IDLER
TRACK ROLLER
CRAWLER
SWIVEL FRAME
ARCH FRAME
SWIVEL BEARING
STEP
COVER (LH)
COVER (RH)
BONNET (LH)
BONNET (RH)
HOOD (BONNET) REAR
BONNET (CENTER)
SPONGE 1
SPONGE 2
SPONGE 3
SPONGE 4
SPONGE 5
WEIGHT
SEAT
CANOPY
CANOPY (METER COVER)
LABEL (FRONT)
LABEL (OPERATION SECTION)
LABEL (REAR)
LABEL (BODY INSIDE)
ACCESSORIES
PAINT (SPOT COLOUR)
CRANKCASE
OIL PAN
CYLINDER HEAD
GEAR CASE
HEAD COVER
ENGINE BRACKET
MAIN BEARING CASE
FLYWHEEL
FUEL CAMSHAFT
STOP SOLENOID
INJECTION PUMP
GOVERNOR
SPEED CONTROL PLATE
ALTERNATOR
STARTER
WATER PUMP
RADIATOR
INLET MANIFOLD
EXHAUST MANIFOLD
AIR CLEANER
MUFFLER
MANUAL
OIL DRAIN HOSE
ACCELERATOR CABLE
FUEL TANK
AUTO IDLE MOTOR
BATTERY
HORN
ECU
SWITCH
METER
LAMP
WIRE HARNESS
WIRE HARNESS CLAMP
PUMP HOUSING
DRIVE MOTOR
SWIVEL MOTOR
ROTARY JOINT
OIL TANK
CONTROL VALVE
SPOOL SECTION (ARM)
UNLOAD VALVE
CHANGE VALVE
SELECT VALVE
TPSS VALVE
WRIST REST
PEDAL (AUX)
OIL PIPING (RETURN)
OIL PIPING (SWIVEL)
OIL PIPING (SWING)
OIL PIPING (BOOM)
OIL PIPING (ARM)
OIL PIPING (BUCKET)
OIL PIPING (BLADE)
OIL PIPING (TRACK)
OIL PIPING (CLAMP)
OIL PIPING (AUX)
BOOM CYLINDER
ARM CYLINDER
BUCKET CYLINDER
BLADE CYLINDER
SWING CYLINDER
TRACK CYLINDER
SWING BRACKET
BOOM
ARM
BUCKET LINK
BUCKET CONNECTION
BLADE
TRACK FRAME
IDLER
TRACK ROLLER
CRAWLER
SWIVEL FRAME
ARCH FRAME
SWIVEL BEARING
STEP
COVER (LH)
COVER (RH)
BONNET (LH)
BONNET (RH)
HOOD (BONNET) REAR
BONNET (CENTER)
SPONGE 1
SPONGE 2
SPONGE 3
SPONGE 4
SPONGE 5
WEIGHT
SEAT
CANOPY
LABEL (FRONT)
LABEL (REAR)
LABEL (BODY INSIDE)
ACCESSORIES
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
