Martin Welker
106
232,697
Kubota Excavator U17-3alpha Workshop Manual 97899-61952
Type of Machine: Excavator
Type of Manual: Workshop Manual
Model: Kubota U17-3alpha Excavator
Part Number: 97899-61952
Number of Pages: 722 Pages
Wsm_U17-3a_97899-61951
Contents
I. General
A. Body And Engine Identification Marks
B. Safety Precautions For Servicing, Disassembly And Reassembly
A. Safety Measures Before Starting Work
B. Safety Measures During Work
C. Preparation For Disassembly
D. Precautions For Disassembly And Reassembly
C. Important Safety Process And Critical Functional Process
D. Important Inspection Items After Reassembling
A. Piping
E. Maintenance Intervals
A. Eu-Version
B. Pp (KTC, KCL)-Version
C. KTA-Version
D. Hydraulic Oil Check For Machines With Hydraulic Breakers
E. Maintenance Items
F. Troubleshooting For Operators
G. Periodic Replacement Of Important Component Parts
H. Recommended Oils
I. Lifting Capacity
F. Product Information
A. U17-3a Development Concept
B. Why Minor Change?
C. Quick Chart
D. Major Sales Feature
E. Specifications Comparison
Ii. Machine Body (Mechanism Section)
A. Machine Specifications
A. Major Dimensions And Working Range (With Rubber Crawler)
B. Dimensions
C. Main Specifications
D. U17-3a Vs U17/U17-3
B. Machine Body Structure And Function
A. Overall Arrangement
B. Under Carriage Components
Ii. Machine Body (Service Section)
A. Specifications
A. Machine Weight
B. Main Specifications
C. Lever Stroke And Operating Force
D. Dimensions Of Parts
E. Quality Specifications
B. Front Attachment
A. Pin, Bush And Shim Installation
B. Instruction To Press In The Bushing
C. Greasing Points
C. Upper Structure
A. Swivel Bearing
B. Travel Lever
C. Accelerator Lever
D. Dozer Lever
F. Swing Pedal
G. Service Port Pedal
H. Pilot Control Valve
I. Limit Switch Installation
J. Seat And Seat Belt
K. Wrist Rest
L. Canopy
M. Weight
D. Undercarriage
A. Track Tension Device
B. Track Roller
Iii. Engine (Mechanism Section)
A. Engine Specifications
B. New Emissions Control Engines
A. Outline
B. Engine List For Minor Change
Iii. Engine (Service Section)
A. Engine Accessories
A. Engine Mount
B. Air Cleaner
C. Radiator
D. Thermostat
E. Muffler
F. Pump Coupling
G. Fuel Tank
H. Fuel Hoses
I. Engine Outlook
Engine Wsm : Sm-E3b Series
Iv. Hydraulic System (Mechanism Section)
A. Hydraulic System
A. Main Pump
B. Control Valve
C. Swivel Motor
D. Travel Motor (Wheel Motor)
E. Pilot Valve (Remote Control Valve)
F. Unload Valve
G. Selector Valve
H. Accessories Of Hydraulic Components
I. Service Port System
J. Tpss (Two Pattern Selection System) : Pp - Version
K. Hydraulic Components Layout: U17-3a, U17/U17-3
L. Hydraulic Circuit Diagram
Iv. Hydraulic System (Service Section)
A. Troubleshooting
A. Common Circuit
B. Hydraulics
C. Pump
D. Motor
E. Swivel Performance
F. Traveling Performance
B. Testing
A. Testing Instruments & Special Tools
B. Pump Flow
C. Pressure Measurement
D. Drain Measurement
E. Measurement Of Block Performance
F. Operating Speed
G. Straight Travel Performance
H. Swivel System Diagnosis
I. Travel System Diagnosis
J. Cylinder Natural Fall Amount
K. Control And Traveling Lever Operating Force
L. Lever Stroke
C. Specifications
A. Pump Specifications
B. Relief Valve
C. Swivel Performance
D. Traveling Performance
E. Cylinder
F. Service Port Flow Amount
G. Motor Oil Drain Amount Test Sample
D. Disassembling And Reassembling
A. Pump
B. Control Valve
C. Pilot Valve
D. Swivel Motor
E. Rotary Joint
F. Travel Motor
G. Cylinder
H. Change Valve (Dozer, Track)
I. Unload Valve
J. Accumulator
K. Oil Tank
L. Third Line
M. Tpss Valve (Pp-Version Only)
N. Hydraulic Hose
V. Electrical System (Mechanism Section)
A. General
A. New Functions Of Electrical System
B. Kubota Intelligent Control System (Kics)
A. Features Of Digital Meter
B. Operating Mode
C. Servide Mode Menues
D. Auto Idoling (Ai) Control System
E. Main Component’s Function
F. Failure Diagnosis
G. Service Mode Flow Chart
H. Electrical Component Layout
I. Electric Circuit Diagram
J. Electrical Wiring Diagram, Revised Version
V. Electrical System (Service Section)
A. Troubleshooting
A. General
B. Engine
C. Panel Relevant (Key Switch: On)
D. Panel Relevant (Engine Starting)
E. Others
C. Inspection
A. Coupler Check
B. Components Check
C. Fuse Inspection
D. Harness Check
E. Battery Check
F. Measuring Instruments And Special Tools
D. Wire Harness Installation
A. Precautions In Clamping The Electrical Cabling
B. Harness Layout, Overview
C. Engine's Back
D. Engine's Top
E. Cabling The Unload And Horn Switch
F. Routing The Front Electrical Cables
G. High-Speed Switch, Horn
H. Electrical Cabling (Engine Room, Fuel Sensor)
I. Electrical Cabling Route (Unload, Horn)
J. Electrical Cabling (Horn And Dual-Speed Wire Harnesses In Right-Hand Console)
E. Main Components Maintenance
A. Checking The Fuses
B. Checking The Battery
C. Checking The Horn
D. Checking The Glow Relay
E. Glow Plug
F. Unload Safety Switch
G. Hi-Low Travel Switch
H. Checking The Solenoid Valve
I. Checking The Fuel Pump
J. Checking The Fuel Sensor
K. Engine Stop Solenoid And Coil Commander
L. Checking The Water Temperature Gauge
M. Oil Switch
N. Relay
O. Installation Of Canopy Light For KTA
F. Anti-Theft System
A. Outline
B. Anti-Theft System
C. Troubleshooting: Display Indications
