Kubota Excavator U10-3 70001- Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota U10-3 Excavator
Serial Number: 70001-
Number of Pages: 342 Pages
U10-3(S N;70001-)
U10-3(S N;70001-) Frequently Used Items Frequently Used Items Frequently Used Items Frequently
U10-3(S N;70001-) Motor Engine Kurbelghaeuse Crankcase
U10-3(S N;70001-) Motor Engine Oelwanne Oil Pan
U10-3(S N;70001-) Motor Engine Zylinderkopf Cylinder Head
U10-3(S N;70001-) Motor Engine Getriebe Gehaeuse Gear Case
U10-3(S N;70001-) Motor Engine Deckel Oben Head Cover
U10-3(S N;70001-) Motor Engine Motor Traeger Engine Bracket
U10-3(S N;70001-) Motor Engine Hauptlagergehaeuse Main Bearing Case
U10-3(S N;70001-) Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle
U10-3(S N;70001-) Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
U10-3(S N;70001-) Motor Engine Schwungrad Flywheel
U10-3(S N;70001-) Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And
U10-3(S N;70001-) Motor Engine Abstellhubmagnet Stop Solenoid
U10-3(S N;70001-) Motor Engine Einspritzpumpe Injection Pump
U10-3(S N;70001-) Motor Engine Zylinderkopf Governor
U10-3(S N;70001-) Motor Engine Geschwindigkeitskontroll Platte Speed Control
U10-3(S N;70001-) Motor Engine Duesenhalter Gluehkerze Nozzle Holder And Glow
U10-3(S N;70001-) Motor Engine Duesenhalter (Einzel-Teil) Nozzle Holder (Component
U10-3(S N;70001-) Motor Engine Ventilator, Dynamo Fan And Dynamo
U10-3(S N;70001-) Motor Engine Dynamo (Einzel-Teil) Dynamo (Component Parts)
U10-3(S N;70001-) Motor Engine Anlasser Starter
U10-3(S N;70001-) Motor Engine Anlasser (Einzel-Teil) Starter (Component Parts)
U10-3(S N;70001-) Motor Engine Wasserflansch Und Thermostat Water Flange And
U10-3(S N;70001-) Motor Engine Wasserpumpe Water Pump
U10-3(S N;70001-) Motor Engine Kuehler Radiator
U10-3(S N;70001-) Motor Engine Wasserrohr Water Pipe
U10-3(S N;70001-) Motor Engine Ventil Kipparmwelle Valve And Rocker Arm
U10-3(S N;70001-) Motor Engine Einlasskruemmer Inlet Manifold
U10-3(S N;70001-) Motor Engine Auslasskruemmer Exhaust Manifold
U10-3(S N;70001-) Motor Engine Luftfilter Air Cleaner
U10-3(S N;70001-) Motor Engine Auspufftopf Muffler
U10-3(S N;70001-) Motor Engine Oberdichtung Installationssatz Upper Gasket Kit
U10-3(S N;70001-) Motor Engine Unterdichtung Installationssatz Lower Gasket Kit
Brennstoff System Fuel System Beschleunigerhebel Accelerator Lever ## [Except Unload
70001-) Brennstoff System Fuel System Beschleunigerhebel Accelerator Lever ## [Unload
U10-3(S N;70001-) Brennstoff System Fuel System Kraftstoffleitungen Fuel Piping
U10-3(S N;70001-) Brennstoff System Fuel System Kraftstoffilter (Einzel-Teil) Fuel Filter (
U10-3(S N;70001-) Brennstoff System Fuel System Kraftstofftank Fuel Tank
U10-3(S N;70001-) Elektrisch System Electrical System Batterie Battery
U10-3(S N;70001-) Elektrisch System Electrical System Relais Und Hupe Relay And
U10-3(S N;70001-) Elektrisch System Electrical System Schalter, Zaehler Switch And
U10-3(S N;70001-) Elektrisch System Electrical System Lampe Light
Elektrisch System Electrical System Kabelgeschirr Wire Harness ## [Except Unload
S N;70001-) Elektrisch System Electrical System Kabelgeschirr Wire Harness ## [Unload
U10-3(S N;70001-) Pumpe Motor System Pump Motor System Pumpengehaeuse Pump
S N;70001-) Pumpe Motor System Pump Motor System Getriebepumpe (Einzel-Teil) Gear Pump
U10-3(S N;70001-) Pumpe Motor System Pump Motor System Hydraulikpumpe Hydraulic
N;70001-) Pumpe Motor System Pump Motor System Hydraulikpumpe (Einzel-Teil) Hydraulic
N;70001-) Pumpe Motor System Pump Motor System Fahrmotor Und Einzelteile Drive Motor
70001-) Pumpe Motor System Pump Motor System Schwingungmotor Und Einzel-Teil Swivel Motor
U10-3(S N;70001-) Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary
U10-3(S N;70001-) Pumpe Motor System Pump Motor System Oeltank Oil Tank
U10-3(S N;70001-) Kontrollventil Control Valve Regelungsventil Control Valve
N;70001-) Kontrollventil Control Valve Regelungsventil (Einzel-Teil) Control Valve (
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Fahren) Spool Section (
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Drehen) Spool Section
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Arm) Spool Section (
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Fahren Ls) Spool Section (
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Planierschild) Spool Section
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (S P) Spool Section (
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Fahren Rs) Spool Section (
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Schwung) Spool Section
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Kuebel) Spool Section (
U10-3(S N;70001-) Kontrollventil Control Valve Spulensektion (Ausleger) Spool Section
70001-) Kontrollventil Control Valve Entladerventil Unload Valve ## [Except Unload Lever]
N;70001-) Kontrollventil Control Valve Entladerventil Unload Valve ## [Unload Lever]
U10-3(S N;70001-) Kontrollventil Control Valve Entladerventil (Einzel-Teil) Unload Valve (
U10-3(S N;70001-) Kontrollventil Control Valve Aenderungventil Change Valve
U10-3(S N;70001-) Kontrollventil Control Valve Super Aenderungsventil Super Change
70001-) Kontrollventil Control Valve Super Aenderungsventil (Einzel-Teil) Super Change
U10-3(S N;70001-) Kontrollventil Control Valve Entlastungsventil Relief Valve
U10-3(S N;70001-) Kontrollventil Control Valve Zylinderspulenventil Solenoid Valve
S N;70001-) Kontrollventil Control Valve Zylinderspulenventil (Einzel-Teil) Solenoid Valve
U10-3(S N;70001-) Kontrollventil Control Valve Verteiler (1) Manifold (1)
U10-3(S N;70001-) Kontrollventil Control Valve Verteiler (2) Manifold (2)
Kontrollrahmen Control Lever Kontrollrahmen (Rahmen, Kontroll) Control Lever (Frame) ## [Except
U10-3(S N;70001-) Kontrollrahmen Control Lever Kontrollrahmen (Hebel Ls) Control Lever
U10-3(S N;70001-) Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (
U10-3(S N;70001-) Kontrollrahmen Control Lever Kontrollhebel (Hebel Rs) Control Lever
N;70001-) Kontrollrahmen Control Lever Vorduesenventil (Einzelteile) Pilot Valve (
U10-3(S N;70001-) Kontrollrahmen Control Lever Kontrollhebel (Fahren Ls) Control Lever
U10-3(S N;70001-) Kontrollrahmen Control Lever Kontrollhebel (Fahren Rs) Control Lever
U10-3(S N;70001-) Kontrollrahmen Control Lever Pedal, Fahrgeschwindigkeit Control
U10-3(S N;70001-) Kontrollrahmen Control Lever Kontrollrahmen (Entlader) Control Lever
U10-3(S N;70001-) Kontrollrahmen Control Lever Kontrollpedal (Schwung) Control Pedal
Kontrollrahmen Control Lever Kontrollrahmen (Erdschieber) Control Lever (Blade) ## [Except
U10-3(S N;70001-) Kontrollrahmen Control Lever Kontrollhebel (S P) Control Lever
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (Suction)
Oelleitungen Oil Piping Oel Leitung (Akkumulator) Oil Piping (Accumulator) ## [Except Unload
70001-) Oelleitungen Oil Piping Oel Leitung (Akkumulator) Oil Piping (Accumulator) ## [Unload
Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return) ## [Except Unload
N;70001-) Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return) ## [Unload
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Kontroll Ls) Oil Piping (Control
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Kontroll Rs) Oil Piping (Control
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Schwung) Oil Piping (Swing)
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Kuebel) Oil Piping (Bucket)
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Planierschild) Oil Piping (Blade)
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (Spur) Oil Piping (Track)
U10-3(S N;70001-) Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P)
U10-3(S N;70001-) Zylinder Cylinder Auslegerzylinder Und Einzel-Teil Boom Cylinder And
U10-3(S N;70001-) Zylinder Cylinder Arm Zylinder Und Einzel-Teil Arm Cylinder And Component
U10-3(S N;70001-) Zylinder Cylinder Kuebel Zylinder Und Einzel-Teil Bucket Cylinder And
N;70001-) Zylinder Cylinder Planierschild Zylinder Und Einzel-Teil Blade Cylinder And
U10-3(S N;70001-) Zylinder Cylinder Schwenkzylinder Und Einzel-Teil Swing Cylinder And
U10-3(S N;70001-) Zylinder Cylinder Spur Zylinder Und Einzel-Teil Track Cylinder And Component
U10-3(S N;70001-) Anhaften Von Stirn Front Attachments Schwenkblock Swing Bracket
U10-3(S N;70001-) Anhaften Von Stirn Front Attachments Ausleger Boom
U10-3(S N;70001-) Anhaften Von Stirn Front Attachments Arm Arm
U10-3(S N;70001-) Anhaften Von Stirn Front Attachments Loeffelverbindungsstueck
U10-3(S N;70001-) Anhaften Von Stirn Front Attachments Loeffel Bucket
U10-3(S N;70001-) Anhaften Von Stirn Front Attachments Planierschild Blade
U10-3(S N;70001-) Spurrahmen Track Frame Spurrahmen Track Frame
U10-3(S N;70001-) Spurrahmen Track Frame Spannrad Idler
U10-3(S N;70001-) Spurrahmen Track Frame Laufrollen Track Roller
Rahmen Von Drehen Swivel Frame Rahmen Von Drehen Swivel Frame ## [Except Unload
S N;70001-) Rahmen Von Drehen Swivel Frame Rahmen Von Drehen Swivel Frame ## [Unload
U10-3(S N;70001-) Rahmen Von Drehen Swivel Frame Schwing Antriebszahnrad-Gehaeuse Swivel
U10-3(S N;70001-) Rahmen Von Drehen Swivel Frame Drehkranz Swivel Bearing
U10-3(S N;70001-) Rahmen Von Drehen Swivel Frame Tritt Step
Aubere Bauteile Polsterung External Upholstery Deckel(Vorder) Cover (Front) ## [Except
U10-3(S N;70001-) Aubere Bauteile Polsterung External Upholstery Motorhaube
U10-3(S N;70001-) Aubere Bauteile Polsterung External Upholstery Schaumgummi
U10-3(S N;70001-) Aubere Bauteile Polsterung External Upholstery Gewicht Weight
U10-3(S N;70001-) Aubere Bauteile Polsterung External Upholstery Sitz Seat
U10-3(S N;70001-) Kabinenhaube Canopy Kabinenhaube Canopy
U10-3(S N;70001-) Aufkleber Labels Aufkleber Label ## [Except Unload Lever] [Except Unload
U10-3(S N;70001-) Aufkleber Labels Aufkleber Label ## [Unload Lever] [Unload Lever]
U10-3(S N;70001-) Zubehoer Accessories Zubehoer Accessories
U10-3(S N;70001-) Option Option Kit Steckkupplung Kit Plug-In Coupler
U10-3(S N;70001-) Option Option Kit-Wege-Zusatzkreis Kit Sp-Way
U10-3(S N;70001-) Option Option Kit Cat-Rental Kit Cat-Rental
U10-3(S N;70001-) Option Option Retromatic Schnellwechsler Serie01(Ke) Retromatic Qc-
U10-3(S N;70001-) Option Option Löffel, Schnellkupplung Bucket, Quick-Coupler
U10-3(S N;70001-) Option Option Löffel, Schnellkupplung(Kbd) Bucket, Quick-Coupler
U10-3(S N;70001-) Option Option Kit Hydraulikhammer Kit Hydraulic Breaker
U10-3(S N;70001-) Option Option Kit Black Box Kit Black Box
U10-3(S N;70001-) Option Option Kit Kabel Rundumleuchte Kit Cable Beacon Light
U10-3(S N;70001-) Option Option Palier - Km55 Mounting Brackets - Km55
U10-3(S N;70001-) Option Option Seitenhebel,Kit[Option] Side Lever Kit[Option]
U10-3(S N;70001-)
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
