Kubota Excavator U10-3 10001-49999 Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota U10-3 Excavator
Serial Number: 10001-49999
Number of Pages: 479 Pages
U10-3(S N;10001-49999)
N;10001-49999) Frequently Used Items Frequently Used Items Frequently Used Items
U10-3(S N;10001-49999) Motor Engine Kurbelghaeuse Crankcase
U10-3(S N;10001-49999) Motor Engine Oelwanne Oil Pan
N;10001-49999) Motor Engine Zylinderkopf Cylinder Head ## S.Nr. =5z9999 S.No.; =5z9999 S.No. =
Zylinderkopf Cylinder Head ## S.Nr. =6a0001 Note Order By Ref.No.030,110 New Parts(Set) S.No. =
Motor Engine Getriebe Gehaeuse Gear Case ## S.Nr. =8zz999 S.No.; =8zz999 S.No. =
Motor Engine Getriebe Gehaeuse Gear Case ## S.Nr. =9a0001 S.No.; =9a0001 S.No. =
S N;10001-49999) Motor Engine Ventildeckel Head Cover ## S.Nr. =5z9999 S.No.; =5z9999 S.No. =
S N;10001-49999) Motor Engine Ventildeckel Head Cover ## S.Nr. =6a0001 S.No.; =6a0001 S.No. =
U10-3(S N;10001-49999) Motor Engine Motor Traeger Engine Bracket
Engine Hauptlagergehaeuse Main Bearing Case ## Achtung Bestellen Sie Bitte Pos.015 Neue
U10-3(S N;10001-49999) Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And
U10-3(S N;10001-49999) Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
U10-3(S N;10001-49999) Motor Engine Schwungrad Flywheel
U10-3(S N;10001-49999) Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And
U10-3(S N;10001-49999) Motor Engine Abstellhubmagnet Stop Solenoid
U10-3(S N;10001-49999) Motor Engine Einspritzpumpe Injection Pump
N;10001-49999) Motor Engine Zylinderkopf Governor ## S.Nr. =4jk0001 S.No.; =4jk0001 S.No. =
N;10001-49999) Motor Engine Regler Governor ## S.Nr. =4jl0001 S.No.; =4jl0001 S.No. =4jl0001
U10-3(S N;10001-49999) Motor Engine Geschwindigkeitskontroll Platte Speed Control
Gluehkerze Nozzle Holder And Glow Plug ## S.Nr. =9hz999 Note Order By Fig.No. Ref.No.060 & 065 New
Motor Engine Duesenhalter Gluehkerze Nozzle Holder And Glow Plug ## S.Nr. =9j0001 S.No.; =
Teil) Nozzle Holder (Component Parts) ## S.Nr. =9hz999 Note Order By Fig.No. Ref.No.060 & 065 New
020702 Duesenhalter (Einzel-Teil) Nozzle Holder (Component Parts) ## S.Nr. =9j0001 To Adz999 S.No.; =9j0001
Motor Engine Duesenhalter (Einzel-Teil) Nozzle Holder (Component Parts) ## S.Nr. =Ae0001 S.
U10-3(S N;10001-49999) Motor Engine Ventilator, Dynamo Fan And Dynamo
U10-3(S N;10001-49999) Motor Engine Dynamo (Einzel-Teil) Dynamo (Component Parts)
U10-3(S N;10001-49999) Motor Engine Anlasser Starter
U10-3(S N;10001-49999) Motor Engine Anlasser (Einzel-Teil) Starter (Component Parts)
U10-3(S N;10001-49999) Motor Engine Wasserflansch Und Thermostat Water Flange And
U10-3(S N;10001-49999) Motor Engine Wasserpumpe Water Pump
U10-3(S N;10001-49999) Motor Engine Kuehler Radiator
U10-3(S N;10001-49999) Motor Engine Wasserrohr Water Pipe
49999) Motor Engine Ventile Und Kipphebel Valve And Rocker Arm ## S.Nr. =5z9999 S.No.; =5z9999
49999) Motor Engine Ventile Und Kipphebel Valve And Rocker Arm ## S.Nr. =6a0001 S.No.; =6a0001
U10-3(S N;10001-49999) Motor Engine Einlasskruemmer Inlet Manifold
U10-3(S N;10001-49999) Motor Engine Auslasskruemmer Exhaust Manifold
U10-3(S N;10001-49999) Motor Engine Luftfilter Air Cleaner
U10-3(S N;10001-49999) Motor Engine Auspufftopf Muffler ## [Except Rops] [Except
U10-3(S N;10001-49999) Motor Engine Auspufftopf Muffler ## [Rops] [Rops]
Motor Engine Oberdichtung Installationssatz Upper Gasket Kit ## S.Nr. =5z9999 S.No.; =
Motor Engine Oberdichtung Installationssatz Upper Gasket Kit ## S.Nr. =6a0001 S.No.; =
Motor Engine Unterdichtung Installationssatz Lower Gasket Kit ## S.Nr. =4a0001 S.No.; =
U10-3(S N;10001-49999) Brennstoff System Fuel System Beschleunigerhebel Accelerator
U10-3(S N;10001-49999) Brennstoff System Fuel System Kraftstoffleitungen Fuel
System Fuel System Kraftstoffilter (Einzel-Teil) Fuel Filter (Component Parts) ## S.Nr. =
U10-3(S N;10001-49999) Brennstoff System Fuel System Kraftstofftank Fuel Tank
U10-3(S N;10001-49999) Elektrisch System Electrical System Batterie Battery
U10-3(S N;10001-49999) Elektrisch System Electrical System Relais Und Hupe Relay And
U10-3(S N;10001-49999) Elektrisch System Electrical System Schalter, Zaehler Switch
U10-3(S N;10001-49999) Elektrisch System Electrical System Lampe Light
U10-3(S N;10001-49999) Elektrisch System Electrical System Elektrische Ausruestung
U10-3(S N;10001-49999) Pumpe Motor System Pump Motor System Pumpengehaeuse Pump
N;10001-49999) Pumpe Motor System Pump Motor System Getriebepumpe (Einzel-Teil) Gear Pump
U10-3(S N;10001-49999) Pumpe Motor System Pump Motor System Hydraulikpumpe Hydraulic
System Pump Motor System Hydraulikpumpe (Einzel-Teil) Hydraulic Pump (Component Parts)
Pump Motor System Oeldruckregulator Pumpe (Einzel-Teil) Hydraulic Pump (Component
Pumpe Motor System Pump Motor System Fahrmotor Und Einzelteile Drive Motor And Component
System Pump Motor System Schwingungmotor Und Einzel-Teil Swivel Motor And Component
Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary Joint ## [
N;10001-49999) Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary Joint
U10-3(S N;10001-49999) Pumpe Motor System Pump Motor System Oeltank Oil Tank
S N;10001-49999) Kontrollventil Control Valve Regelungsventil Control Valve ## [Except
U10-3(S N;10001-49999) Kontrollventil Control Valve Regelungsventil Control Valve ## [
Kontrollventil Control Valve Regelungsventil (Einzel-Teil) Control Valve (Component
49999) Kontrollventil Control Valve Regelungsventil (Einzel-Teil) Control Valve (Component
N;10001-49999) Kontrollventil Control Valve Spulensektion (Fahren) Spool Section (Travel
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (Drehen) Spool Section
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (Arm) Spool Section
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (Fahren Ls) Spool Section
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (Planierschild) Spool
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (S P) Spool Section
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (Fahren Rs) Spool Section
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (Schwung) Spool Section
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (Kuebel) Spool Section
U10-3(S N;10001-49999) Kontrollventil Control Valve Spulensektion (Ausleger) Spool Section
U10-3(S N;10001-49999) Kontrollventil Control Valve Entladerventil Unload Valve
N;10001-49999) Kontrollventil Control Valve Entladerventil (Einzel-Teil) Unload Valve (
U10-3(S N;10001-49999) Kontrollventil Control Valve Aenderungventil Change Valve
U10-3(S N;10001-49999) Kontrollventil Control Valve Super Aenderungsventil Super Change
49999) Kontrollventil Control Valve Super Aenderungsventil (Einzel-Teil) Super Change
U10-3(S N;10001-49999) Kontrollventil Control Valve Entlastungsventil Relief Valve
Verteiler (1) Manifold (1) ## Achtung Bestellen Sie Bitte Pos.010 Neue Teile Und 01123-60820
U10-3(S N;10001-49999) Kontrollventil Control Valve Verteiler (2) Manifold (2)
N;10001-49999) Kontrollrahmen Control Lever Kontrollrahmen (Rahmen, Kontroll) Control
U10-3(S N;10001-49999) Kontrollrahmen Control Lever Kontrollrahmen (Hebel Ls) Control
N;10001-49999) Kontrollrahmen Control Lever Vordusenventil (Einzel-Teil) Pilot Valve (
U10-3(S N;10001-49999) Kontrollrahmen Control Lever Kontrollhebel (Hebel Rs) Control Lever
S N;10001-49999) Kontrollrahmen Control Lever Vorduesenventil (Einzelteile) Pilot Valve (
U10-3(S N;10001-49999) Kontrollrahmen Control Lever Kontrollhebel (Fahren Ls) Control Lever
U10-3(S N;10001-49999) Kontrollrahmen Control Lever Kontrollhebel (Fahren Rs) Control Lever
N;10001-49999) Kontrollrahmen Control Lever Pedal, Fahrgeschwindigkeit Control Travel
U10-3(S N;10001-49999) Kontrollrahmen Control Lever Kontrollpedal (Schwung) Control
U10-3(S N;10001-49999) Kontrollrahmen Control Lever Kontrollhebel (Planierschild) Control
U10-3(S N;10001-49999) Kontrollrahmen Control Lever Kontrollhebel (S P) Control Lever
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (Suction)
Oelleitungen Oil Piping Oel Leitung (Akkumulator) Oil Piping (Accumulator) ## [Rops] S.No.;
N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return) ## [Except
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (Return) ##
Oelleitungen Oil Piping Oel Leitung(Kontroll Ls) Oil Piping(Control Lh) ## [Except
N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Kontroll Ls) Oil Piping (Control Lh) ##
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Kontroll Rs) Oil Piping (Control
N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel Lh) ## [Except
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel Lh) ## [
N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel Rh) ## [Except
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel Rh) ##
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Schwung) Oil Piping (Swing)
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Kuebel) Oil Piping (Bucket)
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Planierschild) Oil Piping (
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (Spur) Oil Piping (Track)
U10-3(S N;10001-49999) Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P)
N;10001-49999) Zylinder Cylinder Auslegerzylinder Und Einzel-Teil Boom Cylinder And
U10-3(S N;10001-49999) Zylinder Cylinder Arm Zylinder Und Einzel-Teil Arm Cylinder And
N;10001-49999) Zylinder Cylinder Kuebel Zylinder Und Einzel-Teil Bucket Cylinder And
S N;10001-49999) Zylinder Cylinder Planierschild Zylinder Und Einzel-Teil Blade Cylinder And
N;10001-49999) Zylinder Cylinder Schwenkzylinder Und Einzel-Teil Swing Cylinder And
U10-3(S N;10001-49999) Zylinder Cylinder Spur Zylinder Und Einzel-Teil Track Cylinder And
U10-3(S N;10001-49999) Anhaften Von Stirn Front Attachments Schwenkblock Swing
U10-3(S N;10001-49999) Anhaften Von Stirn Front Attachments Ausleger Boom
U10-3(S N;10001-49999) Anhaften Von Stirn Front Attachments Arm Arm
U10-3(S N;10001-49999) Anhaften Von Stirn Front Attachments Loeffelverbindungsstueck
U10-3(S N;10001-49999) Anhaften Von Stirn Front Attachments Loeffel Bucket
U10-3(S N;10001-49999) Anhaften Von Stirn Front Attachments Planierschild Blade
U10-3(S N;10001-49999) Spurrahmen Track Frame Spurrahmen Track Frame
U10-3(S N;10001-49999) Spurrahmen Track Frame Spannrad Idler
U10-3(S N;10001-49999) Spurrahmen Track Frame Laufrollen Track Roller
Von Drehen Swivel Frame ## Note Order By Ref.No.010 New Part & Fig.No. Ref.No.240,260 New Parts
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Schwing Antriebszahnrad-Gehaeuse Swivel
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Drehkranz Swivel Bearing
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Tritt Step ## [Except Rops] [Except
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Tritt Step ## [Rops] [Rops]
(Vorne) Cover (Front) ## [Except Rops] Note Order By Ref.No.020 New Part & Rd431-4491-0 Cap,Switch(Q'ty
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Deckel (Vorne) Cover (Front) ## [Rops]
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Motorhaube Bonnet
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Schaumgummi Sponge
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Gewicht Weight
U10-3(S N;10001-49999) Drehrahmen Swivel Frame Sitz Seat
U10-3(S N;10001-49999) Kabinenhaube Canopy Kabinenhaube Canopy
U10-3(S N;10001-49999) Aufkleber Labels Aufkleber Label
U10-3(S N;10001-49999) Zubehoer Accessories Zubehoer Accessories
U10-3(S N;10001-49999) Option Option Kit Steckkupplung Kit Plug-In Coupler
U10-3(S N;10001-49999) Option Option Kit-Wege-Zusatzkreis Kit Sp-Way
U10-3(S N;10001-49999) Option Option Kit Cat-Rental Kit Cat-Rental
U10-3(S N;10001-49999) Option Option Retromatic Schnellwechsler Serie01(Ke) Retromatic
U10-3(S N;10001-49999) Option Option Löffel, Schnellkupplung Bucket, Quick-Coupler
U10-3(S N;10001-49999) Option Option Löffel, Schnellkupplung(Kbd) Bucket, Quick-
U10-3(S N;10001-49999) Option Option Kit Hydraulikhammer Kit Hydraulic Breaker
U10-3(S N;10001-49999) Option Option Kit Black Box Kit Black Box
U10-3(S N;10001-49999) Option Option Kit Kabel Rundumleuchte Kit Cable Beacon Light
U10-3(S N;10001-49999) Option Option Anbauplatten - Km55 Mounting Brackets - Km55
U10-3(S N;10001-49999) Option Option Seitenhebel,Kit[Option] Side Lever Kit[Option]
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
