Kubota Excavator U-45 U-45KTA Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota U-45 U-45KTA Excavator
Region: Australia
Number of Pages: 270 Pages
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Engine Bracket
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Engine Stop Lever
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Alternator
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Water Pump
Engine _ Radiator
Engine _ Water Pipe
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Timer And Horn
Electrical System _ Switch And Meter
Pump_Motor System _ Pump Housing
Pump_Motor System _ Piston Pump (Component Parts)
Pump_Motor System _ Drive Motor And Component Parts
Pump_Motor System _ Swivel Motor And Component Parts
Pump_Motor System _ Rotary Joint
Pump_Motor System _ Oil Tank
Control Valve _ Control Valve
Control Valve _ Control Valve (Component Parts)
Control Valve _ Spool Section (Bucket)
Control Valve _ Spool Section (Boom)
Control Valve _ Spool Section (Travel Rh_Spacer)
Control Valve _ Spool Section (Travel Lh)
Control Valve _ Spool Section (Arm)
Control Valve _ Spool Section (S_P)
Control Valve _ Spool Section (Travel Straight)
Control Valve _ Spool Section (Blade_Swing)
Control Valve _ Spool Section (Swivel)
Control Valve _ Unload Valve
Control Valve _ Unload Valve (Component Parts)
Control Lever _ Control Lever (Frame)
Control Lever _ Control Lever (Lever Lh) ## [_=Jan.2001]
Control Lever _ Pilot Valve (Component Parts) ## [_=Jan.2001]
Control Lever _ Control Lever (Lever Rh)
Control Lever _ Control Lever (Travel Lh)
Control Lever _ Control Lever (Travel Rh)
Control Lever _ Control Travel Pedal
Control Lever _ Control Lever (Safety Lock Lever)
Control Lever _ Control Pedal (Swivel_Swing Change)
Control Lever _ Control Lever (Blade)
Control Lever _ Control Lever (S_P 1)
Control Lever _ Control Lever (S_P 2)
Hydraulic System _ Oil Piping (Suction)
Hydraulic System _ Oil Piping (Delivery)
Hydraulic System _ Oil Piping (Return)
Hydraulic System _ Oil Piping (Oil Cooler)
Hydraulic System _ Oil Piping (Control Lh)
Hydraulic System _ Oil Piping (Control Rh)
Hydraulic System _ Oil Piping (Travel Lh)
Hydraulic System _ Oil Piping (Travel Rh)
Hydraulic System _ Oil Piping (Swivel)
Hydraulic System _ Oil Piping (Swing)
Hydraulic System _ Oil Piping (Boom)
Hydraulic System _ Oil Piping (Arm)
Hydraulic System _ Oil Piping (Bucket)
Hydraulic System _ Oil Piping (Blade)
Hydraulic System _ Oil Piping (Clamp)
Hydraulic System _ Oil Piping (S_P)
Front Attachments _ Boom Cylinder And Component Parts
Front Attachments _ Arm Cylinder And Component Parts
Front Attachments _ Bucket Cylinder And Component Parts
Front Attachments _ Blade Cylinder And Component Parts
Front Attachments _ Swing Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Bucket Link
Front Attachments _ Bucket Pin
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Arch Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step
Swivel Frame _ Cover (Lh)
Swivel Frame _ Cover (Rh)
Swivel Frame _ Cover (Tank)
Swivel Frame _ Bonnet
Swivel Frame _ Sponge
Swivel Frame _ Weight
Swivel Frame _ Seat
Operator's Platform _ Canopy
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Door Lock 1)
Operator's Platform _ Cabin (Door Lock 2)
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Sponge)
Operator's Platform _ Cabin (Seal Rubber)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Heater)
Labels _ Label ## # Rev.Feb.28 '01
Accessories _ Accessories
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Head Cover
Engine _ Flywheel
Engine _ Governor
Engine _ Alternator
Engine _ Starter
Engine _ Water Pump
Engine _ Radiator
Engine _ Water Pipe
Engine _ Muffler
Track Frame _ Idler
Swivel Frame _ Step
Swivel Frame _ Seat
