704,032
Kubota Excavator U-15 U-15KTA Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota U-15 U-15KTA Excavator
Region: Australia
Number of Pages: 263 Pages
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Engine Bracket
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Nozzle Holder (Component Parts)
Engine _ Fan And Dynamo
Engine _ Dynamo (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Water Pump
Engine _ Radiator
Engine _ Water Pipe
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Timer And Horn
Electrical System _ Switch And Meter
Electrical System _ Light
Pump_Motor System _ Pump Housing
Pump_Motor System _ Piston Pump Component Parts
Pump_Motor System _ Drive Motor And Component Parts
Pump_Motor System _ Swivel Motor And Component Parts
Pump_Motor System _ Rotary Joint
Pump_Motor System _ Oil Tank
Control Valve _ Control Valve
Control Valve _ Control Valve (Component Parts)
Control Valve _ Spool Section (Swing)
Control Valve _ Spool Section (Blade)
Control Valve _ Spool Section (Swivel)
Control Valve _ Spool Section (Spacer)
Control Valve _ Spool Section (Boom)
Control Valve _ Spool Section (Bucket)
Control Valve _ Spool Section (Travel Lh)
Control Valve _ Spool Section (Travel Straight)
Control Valve _ Spool Section (S_P)
Control Valve _ Spool Section (Travel Rh)
Control Valve _ Spool Section (Arm)
Control Valve _ Unload Valve
Control Valve _ Unload Valve (Component Parts)
Control Valve _ Change Valve
Control Valve _ Change Valve (Component Parts)
Control Lever _ Control Lever (Bracket)
Control Lever _ Control Lever (Lever Lh)
Control Lever _ Pilot Valve (Component Parts)
Control Lever _ Control Lever (Lever Rh)
Control Lever _ Control Lever (Travel Lh)
Control Lever _ Control Lever (Travel Rh)
Control Lever _ Control Travel Pedal
Control Lever _ Control Lever (Safety Lock Lever)
Control Lever _ Control Pedal (Swivel_Swing Change)
Control Lever _ Control Lever (Blade)
Control Lever _ Control Lever (S_P 1)
Oil Piping _ Oil Piping (Suction)
Oil Piping _ Oil Piping (Delivery)
Oil Piping _ Oil Piping (Return)
Oil Piping _ Oil Piping (Oil Cooler)
Oil Piping _ Oil Piping (Control Lh)
Oil Piping _ Oil Piping (Control Rh)
Oil Piping _ Oil Piping (Travel Lh)
Oil Piping _ Oil Piping (Travel Rh)
Oil Piping _ Oil Piping (Swivel)
Oil Piping _ Oil Piping (Swing)
Oil Piping _ Oil Piping (Boom)
Oil Piping _ Oil Piping (Arm)
Oil Piping _ Oil Piping (Bucket)
Oil Piping _ Oil Piping (Blade)
Oil Piping _ Oil Piping (Track)
Oil Piping _ Oil Piping (Clamp)
Oil Piping _ Oil Piping (S_P)
Cylinder _ Boom Cylinder And Component Parts
Cylinder _ Arm Cylinder And Component Parts
Cylinder _ Bucket Cylinder And Component Parts
Cylinder _ Blade Cylinder And Component Parts
Cylinder _ Swing Cylinder And Component Parts
Cylinder _ Track Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Bucket Pin [Option]
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Step
Swivel Frame _ Cover (Rh)
Swivel Frame _ Bonnet
Swivel Frame _ Sponge
Swivel Frame _ Weight
Swivel Frame _ Seat
Operator's Platform _ Canopy
Labels _ Label
Accessories _ Accessories
