118
6,911
Kubota Excavator R420 Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota R420 Excavator
Number of Pages: 358 Pages
R420
R420 Motor Engine Kurbelghaeuse Crankcase
R420 Motor Engine Oelwanne Oil Pan
R420 Motor Engine Oelleitung, Turbolader Oil Pipe (Turbo Charger)
R420 Motor Engine Kolben Kurbelwelle Piston Crankshaft
R420 Motor Engine Hauptlagergehaeuse Main Bearing Case
R420 Motor Engine Nockenwelle Camshaft
R420 Motor Engine Zylinderkopf Cylinder Head
R420 Motor Engine Ventile Kipphebel Valve Rocker Arm
R420 Motor Engine Ventildeckel Cylinder Head Cover
R420 Motor Engine Getriebe Gehaeuse Gear Case
R420 Motor Engine Turbolader Turbo Charger
R420 Motor Engine Einlasskruemmer Inlet Manifold
R420 Motor Engine Auslasskruemmer Exhaust Manifold
R420 Motor Engine Duesenhalter Nozzle Holder Glow Plug
R420 Motor Engine Kraftstoff Nockenwelle Fuel Camshaft
R420 Motor Engine Einspritzpumpe Injection Pump
Engine S017-1 Einspritzpumpe (Einzelteile) (Alter Type) Injection Pump [Component Parts] [Old Type]
R420 Motor Engine Motorabstellhebel Engine Stop Lever
R420 Motor Engine Geschwindigkeitskontroll Platte Speed Control Plate
R420 Motor Engine Zylinderkopf Governor
R420 Motor Engine Loeffel (Ohne Schnellkupplung) (Option) Water Pump
R420 Motor Engine Wasserflansch Und Thermostat Water Flange Thermostat
R420 Motor Engine Ventilator Lichtmaschine Fan Alternator
R420 Motor Engine Lichtmaschine [Einzel-Teil] Alternator [Component Parts]
R420 Motor Engine Schwungrad Anlasser Flywheel Starter
Motor Engine S026-1 Anlasser [Einzel-Teil] [Alter Typ] Starter [Component Parts] [Old Type] ## S.Nr. =
Motor Engine S026-2 Anlasser [Einzel-Teil] [Neuer Typ] Starter [Component Parts] [New Type] ## S.
R420 Motor Engine Motortraeger Engine Bracket
R420 Motor Engine S052-1 Luftfilter [Alter Typ] Air Cleaner [Old Type] ## S.Nr. =50148 S.No. =
R420 Motor Engine S052-3 Luftfilter [Neuer Typ] Air Cleaner [New Type] ## S.Nr. =50149 S.No. =
R420 Motor Engine S053-1 Auspufftopf Muffler
R420 Motor Engine S053-2 Auspuff Muffler
R420 Motor Engine Kuehler Radiator
R420 Motor Engine Wasserrohr Water Pipe
R420 Kraftstoff System Fuel System Abstellhubmagnet Solenoid
R420 Kraftstoff System Fuel System Kraftstofftank Fuel Tank
R420 Kraftstoff System Fuel System Kraftstoff Rohr Fuel Pipe
R420 Kraftstoff System Fuel System Abscheider Sedimenter
R420 Kraftstoff System Fuel System Kraftstoffsieb Fuel Filter
R420 Elektrisches System Electrical System Batterie Battery
R420 Elektrisches System Electrical System Zaehler Meter
R420 Elektrisches System Electrical System Hauptschalter Switch
R420 Elektrisches System Electrical System Light Light
R420 Elektrisches System Electrical System Ruecklicht Tail Light
Wire Harness ## Achtung Bestellen Sie Bitte Pos.020 Neue Teile, Fig.No.S063 Pos.010 Und 030 Bis 050 Neue
R420 Transmission Transmission Getriebe-Gehaeuse Mission Case
R420 Transmission Transmission Vorderachs Gehaeuse Front Axle Case
R420 Transmission Transmission Vorderachse Front Axle
R420 Transmission Transmission Frontdifferential Gehaeuse Front Differential
R420 Transmission Transmission Zahnrad Planetary Gear (Front)
R420 Transmission Transmission Frontdifferential Front Differential
R420 Transmission Transmission Achsgehaeuse Rear Axle Case
R420 Transmission Transmission Abstuetzung Rechts Vorne Rear Axle
R420 Transmission Transmission Hinterachsdifferential Gehaeuse Rear Front Differential
R420 Transmission Transmission Zahnrad Planetary Gear (Rear)
R420 Transmission Transmission Hinterdifferential Rear Differential
R420 Transmission Transmission Abstuetzung Rechts Vorne Propeller Shaft
R420 Bereifung Wheel Tire S079-1 Rad Reifen Wheel Tire
R420 Lenkgestaenge Steering Lenkrad Steering Handle
R420 Lenkgestaenge Steering Hydraulik-Kreislauf (Lenkrad) Hydraulic Oil Line (
R420 Lenkgestaenge Steering Hebel-Hilfe Accelerator Support
R420 Lenkgestaenge Steering Hilfskraftlenkung Steering Controller
Steering S084-1 Hilfskraftlenkung [Einzel-Teil] [Alter Typ] Steering Controller [Component Parts]
Steering S084-2 Hilfskraftlenkung [Einzel-Teil] [Neuer Typ] Steering Controller [Component Parts]
R420 Lenkgestaenge Steering Ventil Priority Valve
R420 Bremse Brake Bremspedal Brake Pedal
R420 Bremse Brake Bremse, Bedienung Brake Operation
R420 Bremse Brake Bremsleitung Brake Piping
R420 Bremse Brake Bremse Brake
R420 Hydraulik System Hydraulic System Pumpengehaeuse Pump Housing
R420 Hydraulik System Hydraulic System Rohr, Entwaesserung Drain Piping
R420 Hydraulik System Hydraulic System Lst Pumpen Lst Pump
R420 Hydraulik System Hydraulic System Lst Pumpen [Einzel-Teil] Lst Pump [Component
R420 Hydraulik System Hydraulic System Kolben Pumpe [Einzel-Teil] Piston Pump [Component
R420 Hydraulik System Hydraulic System Rotor [Einzel-Teil] Rotary [Component
R420 Hydraulik System Hydraulic System Zylinder [Einzel-Teil] Cylinder [Component
R420 Hydraulik System Hydraulic System Rotor Deckel (Einzelteile) Rotary Cover [Component
Hydraulik System Hydraulic System Hochdruck Ventile [Einzel-Teil] High Pressure Valve [
Hydraulik System Hydraulic System Niederdruck Ventile [Einzel-Teil] Low Pressure Valve
R420 Hydraulik System Hydraulic System Kontrollsektion (Einzelteile) Section Control [
R420 Hydraulik System Hydraulic System Da Ventile [Einzel-Teil] Da Valve [Component
R420 Hydraulik System Hydraulic System Getriebepumpe (Einzelteile) Gear Pump [Component
Hydraulik System Hydraulic System Dichtungen (Lst Pumpe) [Einzel-Teil] Seal Kit (Lst Pump)
R420 Hydraulik System Hydraulic System Lst Pumpe Lst Pump
R420 Hydraulik System Hydraulic System Lst Pump (Ueberdruckventil) Lst Pump (Relife
R420 Hydraulik System Hydraulic System Lst Motor Lst Motor
R420 Hydraulik System Hydraulic System Lst Motor [Einzel-Teil] Lst Motor [Component
R420 Hydraulik System Hydraulic System Kontrolle [Einzel-Teil] Control [Component
R420 Hydraulik System Hydraulic System Dichtung (Lst Motor) Seal Kit (Lst Motor)
R420 Hydraulik System Hydraulic System Kontrollventil Control Valve
R420 Hydraulik System Hydraulic System Kontroll Ventil [Einzel-Teil] Control Valve [
R420 Hydraulik System Hydraulic System Spulensektion (1) Spool Section (1)
R420 Hydraulik System Hydraulic System S115-1 Spulensektion (2) Spool Section (2)
R420 Hydraulik System Hydraulic System S115-2 Spulensektion (3) Spool Section (3)
R420 Hydraulik System Hydraulic System Ventil, Abstellhubmagnet Solenoid Valve
R420 Hydraulik System Hydraulic System Oeltank Oil Tank
R420 Hydraulik System Hydraulic System Oelfilter Oil Filter
R420 Hydraulik System Hydraulic System Oelkuehler Oil Coller
R420 Hydraulik System Hydraulic System Hydraulik-Kreislauf (Ansaugen) Hydraulic Oil
R420 Hydraulik System Hydraulic System Hydraulik-Kreislauf (Oelkuehler) Hydraulic Oil
R420 Hydraulik System Hydraulic System Hydraulik-Kreislauf (Ruecklauf) Hydraulic Oil
R420 Hydraulik System Hydraulic System Ruecklauffilter Return Filter
R420 Hydraulik System Hydraulic System Hochdruck-Kreislauf High Pressure Oil
R420 Hydraulik System Hydraulic System Ruecklaufleitung Oil Piping Return
R420 Hydraulik System Hydraulic System Kontroll Rahmen (Schaufel) Control Lever
Hydraulik System Hydraulic System Kontroll Rahmen (Schaufel) [Einzel-Teil] Control (Shovel)
Hydraulik System Hydraulic System Kontroll Rahmen (Sp) [Einzel-Teil] Control Lever (Sp) [
R420 Frontanbau Komponenten Front Attachments Schaufel Arm Shovel Arm
R420 Frontanbau Komponenten Front Attachments Neigungs Arm Tilt Arm
R420 Frontanbau Komponenten Front Attachments S131-1 Kuebel Bucket
R420 Frontanbau Komponenten Front Attachments Hubzylinder Lift Cylinder
R420 Frontanbau Komponenten Front Attachments Neigun Gs Zylinder Tilt Cylinder
R420 Frontanbau Komponenten Front Attachments Automatische Nivellierung Auto
Frontanbau Komponenten Front Attachments Verbindungssatange Lenkungszylinder
Frontanbau Komponenten Front Attachments S136-1 Lenkungszylinder [Einzel-Teil] Steering Cylinder
R420 Frontanbau Komponenten Front Attachments Hydraulik-Kreisalauf (Hub) Hydraulic
R420 Frontanbau Komponenten Front Attachments Hydraulik-Kreisalauf (Neigungs) Hydraulic
R420 Frontanbau Komponenten Front Attachments S140-1 Hydraulik-Kreisalauf (Sp) Hydraulic
R420 Rahmen Frame Vorderer Rahmen Front Frame
R420 Rahmen Frame Verbindungsrahmen Frame Connection
R420 Rahmen Frame Hinterer Rahmen Rear Frame
R420 Rahmen Frame Kotfluegel Hinten Rear Fender
R420 Rahmen Frame Kotfluegel Mud Guad
R420 Motorhaube Hood Bonnet Motorhaube Hood
R420 Motorhaube Hood Bonnet Schloss, Motorhaube Hood Lock
R420 Motorhaube Hood Bonnet Schalldaempeer Sound Absorber
R420 Motorhaube Hood Bonnet Rueckspiegel Ls + Rs Operation Stand
R420 Motorhaube Hood Bonnet Kotfluegel Fender
R420 Motorhaube Hood Bonnet Sitz Seat
R420 Motorhaube Hood Bonnet Gewcht Weight
R420 Getriebe System Speed Change Handhebel Hand Accel
R420 Aufkleber Labels Aufkleber Label
R420 Zubehoer Accessories Sonstiges Zubehoer Und Serviceteile Accessories And
