Kubota Excavator KX91-3 55001-69999 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX91-3 Excavator
Serial Number: 55001-69999
Number of Pages: 283 Pages
Accesorios / Accessories
Pal.Ctrol (Trasl.Izda.) 1 / Control Lever(Travel Lh) 1
Pal.Ctrol (Trasl.Izda.) 2 / Control Lever(Travel Lh) 2
Pal.Ctrol (Trasl.Dcha.) 1 / Control Lever(Travel Rh) 1
Pal.Ctrol (Trasl.Dcha.) 2 / Control Lever(Travel Rh) 2
Pedal De Trasl.De Control / Control Travel Pedal
Palanca Control (Seguridad) / Control Lever(Safety Lock Lever)
Ped.Ctrol (Giro/Oscil.1) / Control Pedal(Swivel/Swing Change 1)
Ped.Ctrol (Giro/Oscil.2) / Control Pedal(Swivel/Swing Change 2)
Palanca De Control (Hoja) / Control Lever(Blade)
Pedal (S/P) / Pedal(S/P)
Valvula De Control / Control Valve
Valv.Control (Componentes) / Control Valve(Component Parts)
Secc.De Bobina (Rotacion) / Spool Section(Swivel)
Sec.De Bobina (Oscilacion) / Spool Section(Swing)
Seccion De La Bobina (Hoja) / Spool Section(Blade)
Sec.Bobina (Trasl.Recta) / Spool Section(Boom) 1
Seccion De La Bobina (S/P) / Spool Section(S/P)
Secc.De La Bobina (Brazo) / Spool Section(Arm)
Secc.Bobina (Trasl.Izda.) / Spool Section(Travel Lh)
Secc.Bobina (Trasl.Dcha.) / Spool Section(Travel Rh)
Secc.Bobina (Brazo Pr.) 2 / Spool Section(Boom) 2
Secc.Bobina (Brazo Pr.) 3 / Spool Section(Boom) 3
Seccion De La Bobina (Cazo) / Spool Section(Bucket)
Grupo De Alimentacion / Supply Unit
Grupo Alimen.(Componentes) / Supply Unit(Component Parts)
Trasl.De Palanca De Paro / Stop Lever Travel
Palanca Ctrol (Lado Izdo.) / Control Lever(Lever Lh)
Valv.Aux.(Componentes) Li / Pilot Valve(Component Parts) Lh
Palanca Ctrol (Lado Dcho.) / Control Lever(Lever Rh)
Valv.Aux.(Componentes) Ld / Pilot Valve(Component Parts) Rh
Cilind.Brazo Prin. (Componentes) / Boom Cylinder And Component Parts
Cilindro Brazo (Componentes) / Arm Cylinder And Component Parts
Cil.Brazo Telesc. (Componentes) / Arm Cylinder.Telescopic(Comp.Parts)
Cilind.De Cazo (Componentes) / Bucket Cylinder And Component Parts
Cil.Cazo Telesc. (Componentes) / Bucket Cylinder.Telescopic(Comp.Parts)
Cilind.Hoja (Componentes) / Blade Cylinder And Component Parts
Cil.Brazo Oscil. (Componentes) / Swing Cylinder And Component Parts
Temp. Boc. Rele (No.S.<=55328) / Timer Horn Relay(S.No.<=55328)
Temp Boc Rel Ai (No.S.>=55329) / Timer Horn Relay Ai(S.No.>=55329)
Interr.Ymed.(No.S.<=55328) / Switch And Meter(S.No.<=55328)
Interr.Y Med.(No.S.>=55329) / Switch And Meter(S.No.>=55329)
Luces / Light
Cableado Electrico / Electrical Wiring
Carter / Crankcase
Carter De Aceite / Oil Pan
Culata / Cylinder Head
Tapa De La Culata / Head Cover
Soporte Del Motor / Engine Bracket
Cojinete Del Ciguenal / Main Bearing Case
Arbol Levas Y Eje Vel.Dir. / Camshaft And Idle Gear Shaft
Piston Y Ciguenal / Piston And Crankshaft
Volante Motor / Flywheel
Palanca De Paro Del Motor / Engine Stop Lever
Bomba De Inyeccion / Injection Pump
Placa De Control De Veloc. / Speed Control Plate
Motor De Arranque / Starter
Motor Arranq.(Componentes) / Starter(Component Parts)
Alternador Y Polea / Alternator And Pulley
Alternador (Componentes) / Alternator(Component Parts)
Brida De Agua Y Termostato / Water Flange And Thermostat
Bomba De Agua / Water Pump
Conducto De Agua / Water Pipe
Valvula Y Balancin / Valve And Rocker Arm
Colect.Adm. Colect.Esc. / Inlet Manifold Exhaust Manifold
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Soporte Brazo De Oscilacion / Swing Bracket
Brazo Principal / Boom
Cub.Cilindro (Brazo Pr.) / Cylinder Cover(Boom)
Brazo / Arm
Brazo (Telescopico) / Arm(Telescopic)
Articulacion Del Cazo / Bucket Link
Articul.Cazo (Telescopica) / Bucket Link(Telescopic)
Cazo / Bucket
Hoja / Blade
Pal.Acel(No.S.<=55328) / Accel Lever(S.No.<=55328)
Conductos Del Combustible / Fuel Piping
Filtro Comb.(Componentes) / Fuel Filter(Component Parts)
Tanque De Combustible / Fuel Tank
Conductos De Aceite (Succion) / Oil Piping(Suction)
Conductos De Aceite (Suminis.) / Oil Piping(Delivery)
Conductos De Aceite (Retorno) / Oil Piping(Return)
Conductos De Aceite (Retorno 2) / Oil Piping(Return 2)
Conductos De Aceite (Enf) (No.S.<=55328) / Oil Piping(Oil Cooler) (S.No.<=55328)
Conductos De Aceite (Enf) (No.S.>=55329) / Oil Piping(Oil Cooler) (S.No.>=55329)
Conductos De Aceite (Func.Izdo.) / Oil Piping(Operation Lh)
Conductos De Aceite (Func.Dcho.) / Oil Piping(Operation Rh)
Conductos De Aceite (Trasl.Izda.) / Oil Piping(Travel Lh)
Conductos De Aceite (Trasl.Dcha.) / Oil Piping(Travel Rh)
Conductos De Aceite (Rotacion 1) / Oil Piping(Swivel 1)
Conductos De Aceite (Oscilacion) / Oil Piping(Swing)
Conductos De Aceite (Brazo Pr.1) / Oil Piping(Boom 1)
Conductos De Aceite (Brazo 1) / Oil Piping(Arm 1)
Conductos De Aceite (Cazo 1) / Oil Piping(Bucket 1)
Conductos De Aceite (Hoja) / Oil Piping(Blade)
Mordaza (Conductos Aceite) / Clamp(Oil Piping)
Conductos De Aceite (S/P) / Oil Piping(S/P)
Etiqueta / Label
Maintenance Parts
Marcotecho / Canopy
Cabina (Esponja) / Cabin(Sponge)
Cabina (Ventanilla 1) / Cabin(Window 1)
Cabina (Ventanilla 2) / Cabin(Window 2)
Cabina (Puerta) / Cabin(Door)
Cabina (Motor Limpiaparab.) / Cabin(Wiper Motor)
Cabina (Accesorios) / Cabin(Accessories)
Cabina (Calefaccion) / Cabin(Heater)
Caja De La Bomba De Aceite / Pump Housing
Bomba Hidr.Y Componentes / Hydraulic Pump And Component Parts
Motor Acc.Y Componentes (1) / Drive Moter And Component Parts(1)
Motor Acc.Y Componentes (2) / Drive Moter And Component Parts(2)
Motor De Rotac.Y Componentes (1) / Swivel Motor And Component Parts(1)
Motor De Rotac.Y Componentes (2) / Swivel Motor And Component Parts(2)
Junta Giratoria / Rotary Joint
Tanque De Aceite / Oil Tank
Bastidor De Rotacion / Swivel Frame
Estructura De Arco / Arch Frame
Cojinete De Rotacion / Swivel Bearing
Soporte Del Asiento / Seat Support
Peldano / Step
Cubierta (Lado Izdo.) / Cover(Lh)
Cubierta (Lado Dcho.) / Cover(Rh)
Capot (Lado Izdo.) / Bonnet(Lh)
Capot (Lado Dcho.) / Bonnet(Rh)
Capot (Posterior) / Bonnet(Back)
Esponja (1) / Sponge (1)
Esponja (2) / Sponge (2)
Peso / Weight
Asiento / Seat
Chasis Del Montacargas / Track Frame
Rodillo / Idler
Rodillo Inferior / Track Roller
Oruga / Crawler
Luces / Light
Carter / Crankcase
Brazo / Arm
Cazo / Bucket
Hoja / Blade
Etiqueta / Label
Maintenance Parts
Marcotecho / Canopy
Peldano / Step
Peso / Weight
Asiento / Seat
Rodillo / Idler
Oruga / Crawler
