702,019
Kubota Excavator KX91-2 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX91-2 Excavator
Region: Australia
Number of Pages: 347 Pages
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Piston And Crankshaft
Engine _ Main Bearing Case
Engine _ Camshaft
Engine _ Cylinder Head
Engine _ Valve And Rocker Arm
Engine _ Cylinder Head Cover
Engine _ Gear Case
Engine _ Engine Bracket
Engine _ Air Cleaner,Inlet Manifold
Engine _ Muffler,Exhaust Manifold
Fuel System _ Nozzle Holder,Glow Plug
Fuel System _ Nozzle Holder [Component Parts]
Fuel System _ Speed Control Plate
Fuel System _ Stop Solenoid
Fuel System _ Governor
Fuel System _ Injection Pump
Fuel System _ Fuel Camshaft
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter [Component Parts]
Fuel System _ Fuel Tank
Cooling Water System _ Water Flange
Cooling Water System _ Water Pump
Cooling Water System _ Radiator
Cooling Water System _ Water Pipe
Electrical System _ Flywheel,Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Battery
Electrical System _ Timer,Horn
Electrical System _ Switch,Meter
Electrical System _ Light
Hydraulic System _ Pump Housing
Hydraulic System _ S039-1 Piston Pump And Component Parts ## S.No._=12592 S.No.;A_=12592
Hydraulic System _ S039-2 Piston Pump And Component Parts ## S.No._=12593 S.No.;A_=12593
Hydraulic System _ Hydraulic Pump And Component Parts ## S.No._=12592 S.No.;A_=12592
Hydraulic System _ S041-1 Drive Motor And Component Parts
Hydraulic System _ S041-2 Drive Motor And Component Parts
Hydraulic System _ Swivel Motor And Component Parts
Hydraulic System _ Rotary Joint
Hydraulic System _ Oil Tank
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts]
Hydraulic System _ S047-1 Spool Section (Bucket)
Hydraulic System _ S047-2 Spool Section (Boom)
Hydraulic System _ S047-3 Spool Section (Travel Rh)
Hydraulic System _ S047-4 Spool Section (Travel Lh)
Hydraulic System _ S047-5 Spool Section (Arm)
Hydraulic System _ S047-6 Spool Section (S_P)
Hydraulic System _ S047-7 Spool Section (Travel Straight)
Hydraulic System _ S047-8 Spool Section (Swing_Blade)
Hydraulic System _ S047-9 Spool Section (Swivel)
Hydraulic System _ Change Valve
Hydraulic System _ S049-1 Change Valve [Component Parts] ## S.No._=12592 S.No.;A_=12592
Hydraulic System _ S049-2 Change Valve [Component Parts] ## S.No._=12593 S.No.;A_=12593
Hydraulic System _ S050-1 Multi Valve ## S.No._=12152
Hydraulic System _ S050-2 Tpss Valve ## S.No._=12153
Hydraulic System _ S051-1 Multi Valve [Component Parts] ## S.No._=12152
Hydraulic System _ S051-2 Tpss Valve [Component Parts] ## S.No._=12153
Hydraulic System _ Control Lever (Frame)
Hydraulic System _ Control Lever (Lever Lh)
Hydraulic System _ Control Lever (Lever Rh)
Hydraulic System _ Pilot Valve [Component Parts]
Hydraulic System _ Control Lever (Travel Lh)
Hydraulic System _ Control Lever (Travel Rh)
Hydraulic System _ Control Travel Pedal
Hydraulic System _ Control Lever (Safety Lock Lever)
Hydraulic System _ Control Pedal (Swivel_Swing Change)
Hydraulic System _ S061-1 Control Lever (Tpss) ## S.No._=12152
Hydraulic System _ S061-2 Control Lever (Tpss) ## S.No._=12153
Hydraulic System _ Control Lever (Blade)
Hydraulic System _ Control Lever (S_P 1)
Hydraulic System _ Control Lever (S_P 2)
Hydraulic System _ Oil Piping (Suction)
Hydraulic System _ Oil Piping (Delivery)
Hydraulic System _ Oil Piping (Return)
Hydraulic System _ Oil Piping (Oil Cooler)
Hydraulic System _ Oil Piping (Travel Lh)
Hydraulic System _ Oil Piping (Travel Rh)
Hydraulic System _ S071-1 Oil Piping (Swivel 1)
Hydraulic System _ S071-2 Oil Piping (Swivel 1) ## S.No._=12152
Hydraulic System _ S071-3 Oil Piping (Swivel 1) ## S.No._=12153
Hydraulic System _ Oil Piping (Swivel 2)
Hydraulic System _ Oil Piping (Swing)
Hydraulic System _ Oil Piping (Lock)
Hydraulic System _ S075-1 Oil Piping (Boom 1)
Hydraulic System _ S075-2 Oil Piping (Boom 1) ## S.No._=12152
Hydraulic System _ S075-3 Oil Piping (Boom 1) ## S.No._=12153
Hydraulic System _ Oil Piping (Boom 2)
Hydraulic System _ S077-1 Oil Piping (Arm 1)
Hydraulic System _ S077-2 Oil Piping (Arm 1) ## S.No._=12152
Hydraulic System _ S077-3 Oil Piping (Arm 1) ## S.No._=12153
Hydraulic System _ Oil Piping (Arm 2)
Hydraulic System _ S079-1 Oil Piping (Bucket 1) ## S.No._=12152
Hydraulic System _ S079-2 Oil Piping (Bucket 1) ## S.No.[Kta] _=10001,[Ktc Kcl] _=12153
Hydraulic System _ Oil Piping (Bucket 2)
Hydraulic System _ Oil Piping (Blade)
Hydraulic System _ Oil Piping (Clamp)
Hydraulic System _ Oil Piping (S_P)
Hydraulic System _ Boom Cylinder And Component Parts
Hydraulic System _ Arm Cylinder And Component Parts
Hydraulic System _ Bucket Cylinder And Component Parts
Hydraulic System _ Blade Cylinder And Component Parts
Hydraulic System _ Swing Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ S092-1 Arm
Front Attachments _ S092-2 Arm (Telescopic)
Front Attachments _ S092-3 Telescopic Cylinder [Component Parts]
Front Attachments _ S093-1 Bucket Link
Front Attachments _ S093-2 Bucket Link (Telescopic)
Front Attachments _ Bucket
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Swivel Gear Case
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ S105-1 Step
Swivel Frame _ S105-2 Step
Swivel Frame _ Cover (Left)
Swivel Frame _ Cover (Tank)
Swivel Frame _ Instrument Panel
Swivel Frame _ Bonnet
Swivel Frame _ Sponge (1)
Swivel Frame _ Sponge (2)
Swivel Frame _ S112-1 Weight
Swivel Frame _ S112-2 Weight (Telescopic)
Operator's Platform _ Seat
Operator's Platform _ Canopy
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Sponge)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Heater)
Operator's Platform _ Cabin (Defroster)
Operator's Platform _ Label
Accessories _ Accessories
Accessories _ Weight Kit [Option]
Accessories _ Label Kit [Option]
