Kubota Excavator KX71 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX71 Excavator
Number of Pages: 309 Pages
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Air Cleaner Inlet Manifold
Muffler Exhaust Manifold
Nozzle Holder Glow Plug
Piston Crankshaft
Nozzle Holder (Component Parts)
Speed Control Plate
Speed Control Plate
Stop Solenoid
Governor
Injection Pump Camshaft (1)
Injection Pump (Component Parts)
Injection Pump Camshaft (2)
Accel Lever
Fuel Piping
Water Flange
Water Pipe
Flywheel Starter
Starter (Component Parts)
Dynamo
Dynamo
Dynamo (Component Parts)
Battery
Regulator Horn
Switch Meter
Electrical Wiring
Pump Housing
Gear Pump & Component Parts
Hydraulic Pump & Component Parts
Drive Motor & Component Parts 1
Drive Motor & Component Parts 2
Swivel Motor & Component Parts
Rotary Joint
Oil Tank
Control Valve (1)
Control Valve (1) (Component Parts)
Spool Section (Travel Rh)
Spool Section (Boom)
Spool Section (Bucket)
Spool Section
Spool Section (Travel Lh)
Spool Section (Arm)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Speed 2nd)
Spacer Section
Control Valve (3)
Control Valve (3) (Component Parts)
Spool Section (Swivel)
Spool Section (Swing)
Spool Section (Blade)
Change Valve
Control Lever (Frame)
Control Lever (Box Lh)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Regulator Horn
Control Lever (Box Rh)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change) / Control Pedal (Swivel/Swing Change)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Third Line)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Unload Valve) (Component Parts)
Oil Piping (Return C/V Tank) / Oil Piping (Return C/V Tank)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel / Swing) / Oil Piping (Swivel / Swing)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Blade)
Oil Piping (Confluence)
Oil Piping (Cushion)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder & Component Parts
Arm Cylinder & Component Parts
Bucket Cylinder & Component Parts
Blade Cylinder & Component Parts
Swing Cylinder & Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Truck Frame
Idler
Truck Roller
Crawler
Swivel Frame
Swivel Gear Case
Swivel Gear
Camshaft
Swivel Bearing
Floor Plate (1)
Floor Plate (2)
Bonnet
Sponge (1) [Ke Kdg Kuk M.E.]
Sponge (1) [Ktc Kcl Kta]
Sponge (2)
Sponge (3) [H.P.]
Weight
Canopy [Ke Kdg Kuk M.E.]
Canopy (Rops) [Ktc Kcl Kta]
Cabin (Body) [Ke Kdg Kuk M.E.]
Cabin (Rops) (Body) [Ktc Kcl Kta]
Cabin (Door) [Ke Kdg Kuk M.E.]
Cabin (Rops) (Door) [Ktc Kcl Kta]
Cabin (Front Window) [Ke Kdg Kuk M.E.]
Cabin (Rops) (Front Window) [Ktc Kcl Kta]
Cabin (Window) [Ke Kdg Kuk M.E.]
Cabin (Rops) (Window) [Ktc Kcl Kta]
Cabin (Sponge) [Ke Kdg Kuk M.E.]
Cabin (Rops) (Sponge) [Ktc Kcl Kta]
Instrument Panel
Seat [Ke Kdg Kuk]
Seat [Ke Kdg Kuk]
Seat [Ktc Kcl M.E. Kta]
Cabin (Electrical)
Cabin (Wiper Motor)
Cabin (Defroster)
Cabin (Heater)
Light
Label [Ke Kdg Kuk M.E.]
Label [Ktc Kcl Kta]
