652
1,893,758
Kubota Excavator KX71 KX71H 50001-55000 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX71 ; KX71H Excavator
Serial Number: 50001-55000
Number of Pages: 281 Pages
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Gear Case
Engine Bracket
Water Flange
Water Pipe
Dynamo
Battery
Switch Meter
Boom
Arm
Bucket Link
Bucket
Blade
Stop Solenoid
Governor
Accel Lever
Fuel Piping
Pump Housing
Rotary Joint
Oil Tank
Spool Section
Change Valve
Canopy
Light
Label
Stop Solenoid
Swivel Frame
Swivel Gear Case
Engine Bracket
Swivel Gear
Swivel Bearing
Floor Plate (1)
Floor Plate (2)
Bonnet
Sponge (1)
Sponge (2)
Sponge (3)
Weight
Truck Frame
Idler
Truck Roller
Crawler
Spool Section (Travel Lh)
Spacer Section
Bucket Cylinder & Component Parts
Blade Cylinder & Component Parts
Swing Cylinder & Component Parts
Swing Bracket
Air Cleaner Inlet Manifold
Cylinder Cover (Boom)
Crawler
Crawler
Muffler Exhaust Manifold
Nozzle Holder Glow Plug
Cabin (Body)
Cabin (Door)
Cabin (Front Window)
Control Valve (3)
Cabin (Window)
Cabin (Window)
Cabin (Sponge)
Cabin (Electrical)
Cabin (Wiper Motor)
Control Valve (3)
Cabin (Defroster)
Cabin (Heater)
Nozzle Holder (Component Parts)
Cabin (Heater)
Instrument Panel
Speed Control Plate
Control Valve (3) (Component Parts)
Injection Pump Camshaft (1)
Injection Pump (Component Parts)
Injection Pump Camshaft (2)
Flywheel Starter
Starter (Component Parts)
Dynamo (Component Parts)
Regulator Horn
Electrical Wiring
Gear Pump & Component Parts
Spool Section (Swivel)
Hydraulic Pump & Component Parts
Drive Motor & Component Parts 1
Drive Motor & Component Parts 2
Swivel Motor & Component Parts
Control Valve (1)
Control Valve (1) (Component Parts)
Spool Section (Travel Rh)
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Swing)
Spool Section (Blade)
Control Lever (Frame)
Control Lever (Box Lh)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Box Rh)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Spool Section (Arm)
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change) / Control Pedal (Swivel/Swing Change)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Cylinder Head Cover
Oil Piping (Third Line)
Spool Section (Arm)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Unload Valve) (Component Parts)
Oil Piping (Return C/V Tank) / Oil Piping (Return C/V Tank)
Cylinder Head Cover
Spool Section (S/P) / Spool Section (S/P)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel / Swing) / Oil Piping (Swivel / Swing)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Spool Section (Travel Speed 2nd)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Blade)
Oil Piping (Confluence)
Oil Piping (Cushion)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder & Component Parts
Arm Cylinder & Component Parts
